Hi , I was wondering if Openhab supports or will support the X2D / X3D protocole used by Deltadore compagny , used in Home Automation.
I’d like to manage my Roller Shutters .
Zbase can manage it but I prefer Openhab.
Thanks for feedback
Alban
Thanks for feedback
Alban
Do you mean Zibase? If yes, then check out the following:
Understood , so OpenHab has no direct solution to bind with X2D/X3D using an USB stick , it has to deal with another RaspberryPi with ZiBase , correct ?
I though that OpenHab & Zibase would be concurrent .
Can Zibase & Openhab be installed on the same RaspberryPi 2 ?
