https://banggood.app.link/59jKUbJykY
This product is new from Xiaomi. It must work with gateway using zigbee protocol, but this device is not supported by Xiaomi bonding.How can I connect it with openhab?
It works with Zigbee binding: https://www.openhab.org/addons/bindings/zigbee/
Be careful, on some of these devices the hardware switch connections S1 and S2 are switched.
Thank you for replying.
I donât understand what you mean here.Do you mean that there is difference between switching the device physically or from the App?
The device has some physical inputs where you connect the wires. In my case (and for some others too), the input which is labeled âS1â on the case of the device actually is âS2â (and vice versa).
Okay
Thank you very much
Hi Martin,
What I have to do so it start working with zigbee ? Do I have to buy some zigbee receiver ? Or can I use xiaomi gateway with it ?
Hi, you can use a proprietary gateway (like xiaomi gatway or tradfri), but I am not familiar with this.
The other solution is to use the openhab zigbee binding. The explanation in openhab documentation is very detailed: https://www.openhab.org/addons/bindings/zigbee/
Basically you need a coordinator (~zigbee receiver) for you zigbee network (have a look at the documentation section âSuppported Coordinatorsâ). This is more or less a USB stick for your openhab machine.
Hi Martin,
USB zigbee arrived > flashed by firmware but still how to use and add item?
I need advice how to setup item in openhab. I have already added my new device LLKZMK11LM (supported), but i have no clue how to define item switch to turn it ON or OFF or getting power value. this is what i see in log:
Nov 20 21:24:34 openhab npm[18254]: zigbee2mqtt:info 2019-11-20T20:24:34: MQTT publish: topic âzigbee2mqtt/XiaomiAqaraRelaySwitchKitchenâ, payload â{âpowerâ:39.43,âconsumptionâ:0.06,âtemperatureâ:40,âlinkqualityâ:39,âstate_l1â:âONâ,âstate_l2â:âOFFâ}â
Please help.
Iâm sorry but I canât help you with zigbee2mqtt. I have no experience in connecting zigbee/Openhab like this. But there should be plenty of examples around?
So at the end i have figured out what to do:
I am using newest openhabian 2.5 image (which is broken and java has to be fixed manually during install ⊠that is shame)
- install and configure mosquito
- install and configure zigbee2mqtt
- flash FW on your cc2531 ordered from Aliexpress for 5euro solder 4 wire to your RPI and flash it via RPI if you forgot to order Debuger
(possible to flash with Debuger kit and Windows PC easy way but cost more)
- install mqtt binding in OH 2.5
- manually create mqtt Broker thing (localhost)
- open zigbee2mqtt logs
sudo journalctl -u zigbee2mqtt.service -f
reset your Xiaomi Relay Switch until you see it joined your
zigbee2mqtt (from now it will anly be accessible via OH and
dissapear from Mi Home)
- open zigbee2mqtt config and rename device to some friendly name
nano /opt/zigbee2mqtt/data/configuration.yaml
Restart service to apply
sudo systemctl restart zigbee2mqtt.service
Check Status of zigbee2mqtt service
sudo systemctl status zigbee2mqtt.service
- manually create generic mqtt Thing in paper UI (just select Broker Bridge Selection there should be only one)
add Channel to it (every channel will be one function of the relay):
switch1 - add channel
- Channel type: On/Off switch
- Channel id: xiaomirelayswitch1switch1
- MQTT state topic: zigbee2mqtt/
my friendly name is: XiaomiAqaraRelaySwitchKitchen
so my MQTT state topic is: zigbee2mqtt/XiaomiAqaraRelaySwitchKitchen
- MQTT command topic: zigbee2mqtt/XiaomiAqaraRelaySwitchKitchen/l1/set
- SHOW MORE >
- Incoming value transformation: JSONPATH:$.state_l1
- Retained ON
- Do not change anything else and SAVE
switch2
Add Channel type: On/Off switch
MQTT state topic: zigbee2mqtt/XiaomiAqaraRelaySwitchKitchen
MQTT command topic: zigbee2mqtt/XiaomiAqaraRelaySwitchKitchen/l2/set
Incoming value transformation: JSONPATH:$.state_l2
Retained ON
power
Add Channel type number:
Incoming value transformation: JSONPATH:$.power
consumption
Incoming value transformation: JSONPATH:$.consumption
now link every channel to appropriate item (switch to switch and number to text
maybe this will help someone lost as i am:)
PS: zigbee binding is not needed at all with this method
Wow Peter THANK YOU SO MUCH! that was EXACTELY what I needed and your great tutorial worked out o fthe box. As I never worked with mqtt, I would have never figured out the JSON transformation part
It works as mihome:ctrl_ln2.
