I just upgraded to openHAB 2.4 stable and with it came 2.4.0 of the Xiaomi Mi Smart Home Binding.
I’m using v2 of the Gateway (the one with the Radio, but without the Aqara-logo) and everything Comes online: Bridge, Gateway and the leak sensor. The Vibration sensor stays in Status: UNINITIALIZED - HANDLER_CONFIGURATION_PENDING
log:
2018-12-17 15:16:33.788 [hingStatusInfoChangedEvent] - 'mihome:sensor_vibration:7c49xxx:158d0yyy' changed from UNINITIALIZED (HANDLER_CONFIGURATION_PENDING) to UNINITIALIZED
2018-12-17 15:16:33.781 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.dispose()' on 'org.openhab.binding.mihome.internal.handler.XiaomiSensorVibrationHandler@1191e6a': null
2018-12-17 15:16:33.794 [ERROR] [core.thing.internal.ThingManagerImpl] - Exception occurred while disposing handler of thing 'mihome:sensor_vibration:7c49xxx:158d0yyy': null
2018-12-17 15:16:33.813 [hingStatusInfoChangedEvent] - 'mihome:sensor_vibration:7c49xxx:158d0yyy' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2018-12-17 15:18:23.731 [hingStatusInfoChangedEvent] - 'mihome:bridge:7c49xxx' changed from INITIALIZING to ONLINE
2018-12-17 15:18:22.742 [hingStatusInfoChangedEvent] - 'mihome:sensor_vibration:7c49xxx:158d0yyy' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2018-12-17 15:18:23.751 [hingStatusInfoChangedEvent] - 'mihome:sensor_vibration:7c49xxx:158d0yyy' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to UNINITIALIZED (HANDLER_CONFIGURATION_PENDING)
My configuration:
Bridge mihome:bridge:7c49xxx "Xiaomi Gateway PL12" @ "PL12" [ serialNumber="7c49xxx", ipAddress="192.168.xx.yy", port=9898, key="123", pollingInterval=1000 ]
Things:
gateway 7c49xxx "Xiaomi Mi Smart Home Gateway PL12" @ "PL12" [itemId="7c49xxx"]
sensor_wleak_aq1 158d0yyy "Xiaomi Water Leak Sensor Holzofen" @ "PL12 KG" [itemId="158d0yyy"]
sensor_vibration 158d0zzz "Xiaomi Vibration Sensor WoZi West" @ "PL12 WoZi" [itemID="158d0zzz"]
did I miss something in my config?
