Hi All,
I’ve read this thread but could not find anything that applies to my situation though the issue is similar.
Prior to upgrading to OpenHAB 2.3, I had a Xiaomi Cube rule that used to work fine but since upgrading it stopped and I get error entries in the log file.
Rule 'Xiaomi Cube': 'getEvent' is not a member of 'org.eclipse.smarthome.core.thing.events.ChannelTriggeredEvent';
I tested and the rule is triggered but “var actionName = receivedEvent.getEvent();” seems to cause the issue.
rule “Xiaomi Cube”
Channel ‘mihome:sensor_cube:xxxxx:xxxxxx:action’ triggered
logInfo(“RULE TEST”, “Cube event triggered”);
logInfo(“Cube”, actionName)
Hello all,
I don’t know what’s happened but restarting OpenHAB seems to have fixed the issue. I had done this a few times before while diagnosing the issue so I don’t understand what happened but the end result is that it is now working which is great.
I’ve been able to actually implement some actions instead of the simple test rule above.
