Xiaomi Gateway alarm OFF
I have the Xiaomi mihome binding up and running together with a bunch of sensors including fire/smoke detectors.
In the MiHome App I configured an alert for the MiSmoke, so if there’s smoke detected, the gateway will play the alarm. Is there a way to stop that alarm with the binding?
Switch Gateway_SoundSwitch <soundvolume_mute> { channel="mihome:gateway:<ID>:enableSound" }
it seems, that the “enableSound” won’t do the trick?
Works for me …
Did you try already:
Dimmer Gateway_SoundVolume <soundvolume> { channel="mihome:gateway:<id>:volume" }
and set it to zero?
It seemed, I had a typo in my items-file for enablesound. volume worked already and after the typo also the enablesound.
thanks!
