Hi all, the xiaomi gateway’s illumination channel is behaving weirdly (or is it normal?). It changes/updates the illumination level constantly (see below from the log) although the light of the gateway is not on. Also the on/off switch below brightness disappears from time to time in the paperUI and only comes back after stopping/starting openHAB (in basicUI no on/off switch at all).
openHAB 2.2.0 Build #1065
Any ideas/recommendations are greatly appreciated. Thank you!
2017-10-24 12:56:46.726 [vent.ItemStateChangedEvent] - gateway_34ce00xxxxxx_illumination changed from 859 to 857
2017-10-24 12:57:00.648 [vent.ItemStateChangedEvent] - gateway_34ce00xxxxxx_illumination changed from 857 to 841
2017-10-24 12:57:11.604 [vent.ItemStateChangedEvent] - gateway_34ce00xxxxxx_illumination changed from 841 to 920
Update: I also found this in openhab.log:
12:39:27.712 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model ‘xiaomi.things’ has errors, therefore ignoring it: [2,92]: mismatched input ‘’ expecting ‘}’
