I’ve a xiaomi gateway, and it works a couple of minutes, but after that the bridge goes offline, and I need to restart the thing to put it working again (for another couple of minutes).
Anybody can help?
Best Regards,
Fernando Gomes
Anybody can help?
Best Regards,
Fernando Gomes
Can you post the logs, please?
When I start it:
openhab.log:
2019-08-29 17:05:11.342 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘mihome.things’
2019-08-29 17:05:11.945 [DEBUG] [internal.handler.XiaomiBridgeHandler] - Having 1 Item Discovery listeners
2019-08-29 17:05:12.053 [DEBUG] [org.openhab.binding.mihome ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=417, service.bundleid=225, service.scope=singleton} - org.openhab.bi
nding.mihome
2019-08-29 17:05:12.127 [DEBUG] [org.openhab.binding.mihome ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.status.ConfigStatusProvider}={service.id=418, service.bundleid=225, service.scope=singleton} - org.open
hab.binding.mihome
2019-08-29 17:05:12.215 [DEBUG] [internal.handler.XiaomiBridgeHandler] - Init socket on Port: 9898
2019-08-29 17:05:12.215 [DEBUG] [e.internal.socket.XiaomiBridgeSocket] - Setup socket
2019-08-29 17:05:12.261 [DEBUG] [e.internal.socket.XiaomiBridgeSocket] - Initialized socket to null:-1 on 0.0.0.0/0.0.0.0:9898
2019-08-29 17:05:12.262 [DEBUG] [.mihome.internal.socket.XiaomiSocket] - There are 1 open sockets: {9898=java.net.MulticastSocket@1f2809d1}
2019-08-29 17:05:12.263 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Staring reveicer thread for socket on port 9898
2019-08-29 17:05:12.263 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Adding socket listener org.openhab.binding.mihome.internal.handler.XiaomiBridgeHandler@77e2424f
2019-08-29 17:05:12.277 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Thread Thread[Thread-451,5,main] waiting for data on port 9898
2019-08-29 17:05:13.264 [DEBUG] [internal.handler.XiaomiBridgeHandler] - Send to bridge mihome:bridge:7811dcfb2a9a: {“cmd”: “get_id_list”}
2019-08-29 17:05:13.265 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Sending message: {“cmd”: “get_id_list”} to /192.168.1.10:9898
2019-08-29 17:05:13.276 [DEBUG] [.mihome.internal.socket.XiaomiSocket] - Received Datagram from 192.168.1.10:9898 on Port 9898
2019-08-29 17:05:13.556 [TRACE] [internal.handler.XiaomiBridgeHandler] - Received message {“cmd”:“get_id_list_ack”,“sid”:“7811dcfb2a9a”,“token”:“1cTfehwly7RI6cZP”,“data”:“["158d00032141f1"]”}
2019-08-29 17:05:13.597 [TRACE] [internal.handler.XiaomiBridgeHandler] - Updated “last time seen” for device 7811dcfb2a9a
2019-08-29 17:05:13.675 [DEBUG] [internal.handler.XiaomiBridgeHandler] - Send to bridge mihome:bridge:7811dcfb2a9a: {“cmd”: “read”, “sid”: “158d00032141f1”}
2019-08-29 17:05:13.676 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Sending message: {“cmd”: “read”, “sid”: “158d00032141f1”} to /192.168.1.10:9898
2019-08-29 17:05:13.676 [DEBUG] [internal.handler.XiaomiBridgeHandler] - Send to bridge mihome:bridge:7811dcfb2a9a: {“cmd”: “read”, “sid”: “7811dcfb2a9a”}
2019-08-29 17:05:13.676 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Sending message: {“cmd”: “read”, “sid”: “7811dcfb2a9a”} to /192.168.1.10:9898
2019-08-29 17:05:13.676 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Data received and notified 1 listeners
2019-08-29 17:05:13.676 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Thread Thread[Thread-451,5,main] waiting for data on port 9898
2019-08-29 17:05:13.684 [DEBUG] [.mihome.internal.socket.XiaomiSocket] - Received Datagram from 192.168.1.10:9898 on Port 9898
2019-08-29 17:05:13.685 [TRACE] [internal.handler.XiaomiBridgeHandler] - Received message {“cmd”:“read_ack”,“model”:“weather.v1”,“sid”:“158d00032141f1”,“short_id”:48312,“data”:“{"voltage":2995,"temperature":"2579","humidity":"60
16","pressure":"98987"}”}
2019-08-29 17:05:13.685 [TRACE] [internal.handler.XiaomiBridgeHandler] - Updated “last time seen” for device 158d00032141f1
2019-08-29 17:05:13.732 [DEBUG] [internal.handler.XiaomiBridgeHandler] - Device 158d00032141f1 honored read request
2019-08-29 17:05:14.137 [DEBUG] [discovery.XiaomiItemDiscoveryService] - Discovered device - sid: 158d00032141f1 model: weather.v1
2019-08-29 17:05:14.875 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model ‘mihome.things’
2019-08-29 17:05:15.065 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘mihome:sensor_weather_v1:158d00032141f1’ to inbox.
2019-08-29 17:05:15.076 [DEBUG] [internal.handler.XiaomiBridgeHandler] - Adding item listener for device 7811dcfb2a9a
2019-08-29 17:05:15.076 [DEBUG] [internal.handler.XiaomiBridgeHandler] - Having 1 Item listeners
2019-08-29 17:05:15.077 [DEBUG] [internal.handler.XiaomiBridgeHandler] - Adding item listener for device 158d00032141f1
2019-08-29 17:05:15.077 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Data received and notified 1 listeners
2019-08-29 17:05:15.077 [DEBUG] [internal.handler.XiaomiBridgeHandler] - Having 2 Item listeners
2019-08-29 17:05:15.077 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Thread Thread[Thread-451,5,main] waiting for data on port 9898
2019-08-29 17:05:15.077 [DEBUG] [.mihome.internal.socket.XiaomiSocket] - Received Datagram from 192.168.1.10:9898 on Port 9898
2019-08-29 17:05:15.080 [TRACE] [internal.handler.XiaomiBridgeHandler] - Received message {“cmd”:“read_ack”,“model”:“gateway”,“sid”:“7811dcfb2a9a”,“short_id”:0,“data”:“{"rgb":0,"illumination":815,"proto_version":"1.1.2"}”}
2019-08-29 17:05:15.081 [DEBUG] [rnal.handler.XiaomiDeviceBaseHandler] - Device 7811dcfb2a9a on channel mihome:gateway:7811dcfb2a9a:7811dcfb2a9a:brightness received command REFRESH
2019-08-29 17:05:15.081 [TRACE] [internal.handler.XiaomiBridgeHandler] - Updated “last time seen” for device 7811dcfb2a9a
2019-08-29 17:05:15.081 [DEBUG] [rnal.handler.XiaomiDeviceBaseHandler] - Device 7811dcfb2a9a on channel mihome:gateway:7811dcfb2a9a:7811dcfb2a9a:illumination received command REFRESH
2019-08-29 17:05:15.081 [DEBUG] [rnal.handler.XiaomiDeviceBaseHandler] - Device 7811dcfb2a9a on channel mihome:gateway:7811dcfb2a9a:7811dcfb2a9a:color received command REFRESH
2019-08-29 17:05:15.082 [DEBUG] [rnal.handler.XiaomiDeviceBaseHandler] - Device 7811dcfb2a9a on channel mihome:gateway:7811dcfb2a9a:7811dcfb2a9a:colorTemperature received command REFRESH
2019-08-29 17:05:15.082 [DEBUG] [rnal.handler.XiaomiDeviceBaseHandler] - Device 7811dcfb2a9a on channel mihome:gateway:7811dcfb2a9a:7811dcfb2a9a:enableSound received command REFRESH
2019-08-29 17:05:15.083 [DEBUG] [rnal.handler.XiaomiDeviceBaseHandler] - Device 7811dcfb2a9a on channel mihome:gateway:7811dcfb2a9a:7811dcfb2a9a:sound received command REFRESH
2019-08-29 17:05:15.084 [DEBUG] [rnal.handler.XiaomiDeviceBaseHandler] - Device 7811dcfb2a9a on channel mihome:gateway:7811dcfb2a9a:7811dcfb2a9a:volume received command REFRESH
2019-08-29 17:05:15.084 [DEBUG] [rnal.handler.XiaomiDeviceBaseHandler] - Device 158d00032141f1 on channel mihome:sensor_weather_v1:7811dcfb2a9a:158d00032141f1:temperature received command REFRESH
2019-08-29 17:05:15.084 [DEBUG] [rnal.handler.XiaomiDeviceBaseHandler] - Device 158d00032141f1 on channel mihome:sensor_weather_v1:7811dcfb2a9a:158d00032141f1:humidity received command REFRESH
2019-08-29 17:05:15.084 [DEBUG] [rnal.handler.XiaomiDeviceBaseHandler] - Update Item 158d00032141f1 with retented message
2019-08-29 17:05:15.084 [DEBUG] [rnal.handler.XiaomiDeviceBaseHandler] - Device 158d00032141f1 on channel mihome:sensor_weather_v1:7811dcfb2a9a:158d00032141f1:pressure received command REFRESH
2019-08-29 17:05:15.084 [DEBUG] [rnal.handler.XiaomiDeviceBaseHandler] - Item got update: {“cmd”:“read_ack”,“model”:“weather.v1”,“sid”:“158d00032141f1”,“short_id”:48312,“data”:“{"voltage":2995,"temperature":"2579","humidity":"60
2019-08-29 17:05:15.086 [DEBUG] [rnal.handler.XiaomiDeviceBaseHandler] - Device 158d00032141f1 on channel mihome:sensor_weather_v1:7811dcfb2a9a:158d00032141f1:batteryLevel received command REFRESH
2019-08-29 17:05:15.086 [DEBUG] [rnal.handler.XiaomiDeviceBaseHandler] - Device 158d00032141f1 on channel mihome:sensor_weather_v1:7811dcfb2a9a:158d00032141f1:lowBattery received command REFRESH
2019-08-29 17:05:15.087 [DEBUG] [internal.handler.XiaomiBridgeHandler] - Device 7811dcfb2a9a honored read request
2019-08-29 17:05:15.304 [DEBUG] [rnal.handler.XiaomiDeviceBaseHandler] - Item got update: {“cmd”:“read_ack”,“model”:“gateway”,“sid”:“7811dcfb2a9a”,“short_id”:0,“data”:“{"rgb":0,"illumination":815,"proto_version":"1.1.2"}”}
2019-08-29 17:05:15.305 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Data received and notified 1 listeners
2019-08-29 17:05:15.306 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Thread Thread[Thread-451,5,main] waiting for data on port 9898
events.log:
2019-08-29 17:04:58.768 [hingStatusInfoChangedEvent] - ‘mihome:gateway:7811dcfb2a9a:7811dcfb2a9a’ changed from OFFLINE (BRIDGE_OFFLINE) to UNINITIALIZED
2019-08-29 17:04:59.135 [hingStatusInfoChangedEvent] - ‘mihome:gateway:7811dcfb2a9a:7811dcfb2a9a’ changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2019-08-29 17:04:59.138 [hingStatusInfoChangedEvent] - ‘mihome:sensor_weather_v1:7811dcfb2a9a:158d00032141f1’ changed from OFFLINE (BRIDGE_OFFLINE) to UNINITIALIZED
2019-08-29 17:04:59.139 [hingStatusInfoChangedEvent] - ‘mihome:sensor_weather_v1:7811dcfb2a9a:158d00032141f1’ changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2019-08-29 17:04:59.154 [hingStatusInfoChangedEvent] - ‘mihome:bridge:7811dcfb2a9a’ changed from OFFLINE to UNINITIALIZED
2019-08-29 17:05:00.523 [hingStatusInfoChangedEvent] - ‘mihome:bridge:7811dcfb2a9a’ changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2019-08-29 17:05:12.174 [hingStatusInfoChangedEvent] - ‘mihome:bridge:7811dcfb2a9a’ changed from UNINITIALIZED to INITIALIZING
2019-08-29 17:05:12.267 [hingStatusInfoChangedEvent] - ‘mihome:gateway:7811dcfb2a9a:7811dcfb2a9a’ changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2019-08-29 17:05:12.270 [hingStatusInfoChangedEvent] - ‘mihome:sensor_weather_v1:7811dcfb2a9a:158d00032141f1’ changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2019-08-29 17:05:13.598 [hingStatusInfoChangedEvent] - ‘mihome:bridge:7811dcfb2a9a’ changed from INITIALIZING to ONLINE
2019-08-29 17:05:14.085 [hingStatusInfoChangedEvent] - ‘mihome:gateway:7811dcfb2a9a:7811dcfb2a9a’ changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2019-08-29 17:05:14.085 [hingStatusInfoChangedEvent] - ‘mihome:sensor_weather_v1:7811dcfb2a9a:158d00032141f1’ changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2019-08-29 17:05:15.066 [home.event.InboxAddedEvent] - Discovery Result with UID ‘mihome:sensor_weather_v1:158d00032141f1’ has been added.
2019-08-29 17:05:15.079 [hingStatusInfoChangedEvent] - ‘mihome:gateway:7811dcfb2a9a:7811dcfb2a9a’ changed from INITIALIZING to ONLINE
2019-08-29 17:05:15.080 [hingStatusInfoChangedEvent] - ‘mihome:sensor_weather_v1:7811dcfb2a9a:158d00032141f1’ changed from INITIALIZING to ONLINE
After 5 minutes:
2019-08-29 17:10:15.088 [hingStatusInfoChangedEvent] - ‘mihome:bridge:7811dcfb2a9a’ changed from ONLINE to OFFLINE
2019-08-29 17:10:15.091 [hingStatusInfoChangedEvent] - ‘mihome:gateway:7811dcfb2a9a:7811dcfb2a9a’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-08-29 17:10:15.092 [hingStatusInfoChangedEvent] - ‘mihome:sensor_weather_v1:7811dcfb2a9a:158d00032141f1’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
Thanks for the help,
Fernando
