If the devices are ZigBee I would recommend to get a conbee stick or likewise instead. That way you can purchase devices from multiple vendor meaning you are not locked into one ecosystem
Then you can use the ZigBee binding or you can use zigbee2mqtt
The Xiaomi devices are not exactly ZigBee. They use their own proprietary features. I’ve not found them compatible with the ZigBee binding due to their not quite ZigBee issues.
Some of the other solutions might work as they have been specifically modified to work with Xiaomi.
I’ve been using the Xiaomi hub above with the Aqara devices and they work quite well. When I tried with the ZigBee binding, they kept falling off the network.
That’s super interesting because I’m using zigbee2mqtt and I have no issues with a xiaomi smart plug v2.
Would you be willing to test with it instead of the zigbee binding?? Could be a problem in the binding worthy of note.
(Note: I’d totally try the zigbee binding but I’m remodeling the apartment and everything is boxed )
I think the ZigBee binding developer is aware that there are these devices that are not compliant, but he’s not interested in adding a never ending stream of hacks to support these offshoots of the standard. SmartThings also has some non-compliant devices and I’m sure there are others. Our choices seem to be to either get true ZigBee compliant devices and use the ZigBee binding, or use one of the other methods such as this Xiaomi gateway or the conbee/zigbee2mqtt.
I understand the developer’s position, but it’s a shame that some of the best devices out there aren’t quite ZigBee compliant. I’ve never found a temperature sensor at the same price/size as the Aqara. They’re small, cheap, and work well.
Thanks for pointing out! I’ve already setup up a huge number of devices with that system, so switching will require some work – which I currently don’t have time for
Yes, the temperature sensors are really cheap and I have many of temp. Still, I needed a monitoring system for them since for some reason they sometimes just disappear or disconnect from the gateway.
Just now I’m having this issue with a newly bought sensor. Battery is fully charged, gateway is 2m away. Coupled the sensor, sensor worked for 1-2 days, then magically disappeared from gateway. Recoupled it next day, then the same happened a day later.
I meant no direspect of course. Hadn’t even thought about it like that, but i can understand the reason with that explanation.
Thank you for the context provided
My experience with a big net of zigbee devices (around 100) running under zigbee2mqtt (Aqara: water, contact and vibration sensors, Innr plugs, Lidl bulbs, Livolo light switches, Honeywell smoke sensors, moe heating valves, motion sensors…). It runs perfectly stable but the the routers are crucial (didn’t work well with osram plugs, now with innr it runs smooth).
As coordinator I use the zzh-stick.
