Tried to set the mode and then an ON & OFF. Here is what I got:
17:43:18.548 [DEBUG] [iio.internal.handler.MiIoBasicHandler] - Sending command set_properties[2]
17:43:18.588 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:10793,“method”:“set_properties”,“params”:[2]} -> 192.xxx.xxx.218 (Device: 10212739 token: XXXXXXXXXXXXXXXX Queue: 13)
17:43:18.596 [DEBUG] [iio.internal.handler.MiIoBasicHandler] - Periodic update for ‘miio:generic:10212739’ (miio:basic)
17:43:18.645 [DEBUG] [.internal.handler.MiIoAbstractHandler] - Skipping periodic update for ‘miio:generic:10212739’. 13 elements in queue.
17:43:30.827 [DEBUG] [.internal.handler.MiIoAbstractHandler] - Received response for 10212739 type: SET_PROPERTIES, result: {}, fullresponse: {“id”:10793,“error”:{“code”:-9999,“message”:“user ack timeout”}}
17:43:30.833 [DEBUG] [.internal.handler.MiIoAbstractHandler] - Error received: {“code”:-9999,“message”:“user ack timeout”}
19:38:54.318 [DEBUG] [iio.internal.handler.MiIoBasicHandler] - Sending command set_properties[“false”]
19:38:54.330 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:2149,“method”:“set_properties”,“params”:[“false”]} -> 192.xxx.xxx.218 (Device: 10212739 token: XXXXXXXXXXXXXXXX Queue: 1)
19:38:58.480 [DEBUG] [.internal.handler.MiIoAbstractHandler] - Received response for 10212739 type: SET_PROPERTIES, result: {}, fullresponse: {“id”:2149,“error”:{“code”:-9999,“message”:“user ack timeout”}}
19:38:58.486 [DEBUG] [.internal.handler.MiIoAbstractHandler] - Error received: {“code”:-9999,“message”:“user ack timeout”}
19:39:00.223 [DEBUG] [iio.internal.handler.MiIoBasicHandler] - Sending command set_properties[“false”]
19:39:00.251 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:2178,“method”:“set_properties”,“params”:[“false”]} -> 192.xxx.xxx.218 (Device: 10212739 token: XXXXXXXXXXXXXXXX Queue: 24)
19:39:16.090 [DEBUG] [.internal.handler.MiIoAbstractHandler] - Received response for 10212739 type: SET_PROPERTIES, result: {}, fullresponse: {“id”:2178,“error”:{“code”:-9999,“message”:“user ack timeout”}}
19:39:16.097 [DEBUG] [.internal.handler.MiIoAbstractHandler] - Error received: {“code”:-9999,“message”:“user ack timeout”}
Should I remove the binding and the thing again and reinstall?
