Marcel: many thanks! That worked perfectly!
(I had some trouble with the json syntax with missing the the “,” after the last “}” - I forgot the simple rule: do not copy the last item in a list, because it does not contain the item delimiter - this took me nearly two days )
I did not add specific values for the status, because 0 / 1 is not language specific.
Now the description file ended like this:
"property": "waterstatus",
"friendlyName": "Water Status",
"channel": "waterstatus",
"type": "Number",
"stateDescription": {
"pattern": "%.0f",
"readOnly": true
"refresh": true,
"actions": []
"property": "TemperatureValue",
"friendlyName": "Temperature",
"channel": "TemperatureValue",
"type": "Number",
"pattern": "%.0f",
"readOnly": true
"refresh": true,
"actions": []
And this is the result :
As a new user I cannot upload attachments and therefore cannot upload the adjusted json - file, but the modifications are pretty simple.
And as a hint for others: the conf/misc/miio - folder on an openhabian distribution is /etc/openhab/misc/miio - and you have to create the misc/ and misc/miio folder by yourself.
