Xiaomi Mi Flora Plant Sensor MQTT Client/Daemon gives the same data
I followed this instruction and ran the script. But it always gives me the same information and none of the values (battery, conductivity, etc.) changes. This is my config file:
# Configuration file for Xiaomi Mi Flora Plant Sensor MQTT Client/Daemon
# Source: https://github.com/ThomDietrich/miflora-mqtt-daemon
# Uncomment and adapt all settings as needed.
[General]
# The operation mode of the program. Determines wether retrieved sensor data is published via MQTT or stdout/file.
# Currently supported:
#           mqtt-json - Publish to an MQTT broker in a proprietary json format (Default)
#          mqtt-homie - Publish to an MQTT broker following the Homie MQTT convention
#                       (https://github.com/marvinroger/homie)
#      mqtt-smarthome - Publish to an MQTT broker following the mqtt-smarthome proposal
#                       (https://github.com/mqtt-smarthome/mqtt-smarthome)
#  homeassistant-mqtt - Publish to an MQTT broker following the HomeAssistant discovery format
#                       (https://www.home-assistant.io/docs/mqtt/discovery/)
#                json - Print to stdout as json encoded strings
#reporting_method = mqtt-json
# The bluetooth adapter that should be used to connect to Mi Flora devices (Default: hci0)
#adapter = hci0
[Daemon]
# Enable or Disable an endless execution loop (Default: true)
#enabled = true
# The period between two measurements in seconds (Default: 300)
period = 5
[MQTT]
# The hostname or IP address of the MQTT broker to connect to (Default: localhost)
#hostname = localhost
# The TCP port the MQTT broker is listening on (Default: 1883)
#port = 1883
# Maximum period in seconds between ping messages to the broker. (Default: 60)
#keepalive = 60
# The MQTT base topic to publish all Mi Flora sensor data topics under.
# Default depends on the configured reporting_mode (mqtt-json, mqtt-smarthome: miflora, mqtt-homie: homie)
#base_topic = miflora
#base_topic = homie
# Homie specific: The device ID for this daemon instance (Default: miflora-mqtt-daemon)
#homie_device_id = miflora-mqtt-daemon
# The MQTT broker authentification credentials (Default: no authentication)
username = myUser
password = myPassword
# Enable TLS/SSL on the connection
#tls = false
# Path to CA Certificate file to verify host
#tls_ca_cert =
# Path to TLS client auth key file
#tls_keyfile =
# Path to TLS client auth certificate file
#tls_certfile =
[Sensors]
# Add your Mi Flora sensors here. Each sensor consists of a name and a Ethernet MAC address.
# Additional location information can be added to the name, delimited by an '@'.
# Scan for sensors from the command line with:
#    $ sudo hcitool lescan
# Examples:
Flower mate = C4:7C:8D:61:FC:F2
#JapaneseBonsai    = C4:7C:8D:44:55:66
#Petunia@Balcony   = C4:7C:8D:77:88:99
