I have an openHab setup for already 18 months and I have 3 Xiaomi Gateways. They were all working fine until a couple of weeks ago when one of them started to be reported “offline” by openHab.
I believe this is more or less the point in time when I upgraded the firware on the gateways. They are now all on 1.4.1.167.0158.
Im’ not sure what they were on before as I upgrade from time to time and since i had no problems until now I stopped tracking the firmware changes…
I have read the documentation on por 9898, I checked if it was still open on the gateway, and confirmed it was. I enabled the traces for the binding and can see a bunch of:
2019-05-08 15:39:24.434 [DEBUG] [.mihome.internal.socket.XiaomiSocket] - Received Datagram from 192.168.101.129:4321 on Port 9898
I have them for the 3 gateways, including the one @192.168.101.129 which is the one that now appears offline…
For the other gateways, what is see is more like this (when I filter the log on the IP address):
Received Datagram from 192.168.101.20:4321 on Port 9898
2019-05-08 15:42:25.194 [DEBUG] [.mihome.internal.socket.XiaomiSocket] - Received Datagram from 192.168.101.20:4321 on Port 9898
2019-05-08 15:42:25.192 [DEBUG] [.mihome.internal.socket.XiaomiSocket] - Received Datagram from 192.168.101.20:4321 on Port 9898
2019-05-08 15:42:25.201 [TRACE] [internal.handler.XiaomiBridgeHandler] - Received message {“cmd”:“heartbeat”,“model”:“gateway”,“sid”:“34ce0091e702”,“short_id”:“0”,“token”:“KHEynPLS2j9TXXZe”,“data”:“{"ip":"192.168.101.20"}”}
2019-05-08 15:42:25.214 [DEBUG] [rnal.handler.XiaomiDeviceBaseHandler] - Item got update: {“cmd”:“heartbeat”,“model”:“gateway”,“sid”:“34ce0091e702”,“short_id”:“0”,“token”:“KHEynPLS2j9TXXZe”,“data”:“{"ip":"192.168.101.20"}”}
It looks to me that it is not a problem of ports open or closed in my case but I can’t tell for sure.
Does this look like the problem that is recovered only connecting a UART device to the gateway?
Any suggestion on other data should I look for in the trace to identify better the problem?
Thanks,
