Xiaomi MI IO Lumi Gateway device doesn't work - Yeelight binding UPDATE needed
I’ve been trying to add Xiaomi MI IO devices, but I have a problem to configure the Yeelight Bedside lamp:
at the Inbox it appeared three things to be added:
Xiaomi Mi Device 04AD1C34 (78453812)
Xiaomi Mi Device
Xiaomi Mi Device 04AD1C34 (78453812) lumi-gateway-v3_miio78453812
Unsupported Xiaomi Mi Device
Xiaomi Mi Device 0544F03C (88404028)
Xiaomi Mi Device
I figured out that this device uses 2 IP addresses, using 2 different MAC addresses. Probably one IP is the Gateway and the other is the light by itself.
I tried to add one by one, inserting the token. The device accepted the token. It appears as an online device at Things.
After that I added the item as it was suggested:
miio:generic:04AD1C34:actions#power
But the lamp doesn’t respond.
Also I tried to change the item command deleting the “actions#”
miio:generic:04AD1C34:power , having no response at all
I’ve been studying this issue, I think that this will only work after an update at the YEELING BINDING because so far there is no support for this product at the binding. There is a PDF at this link:
but I don’t know how to update the binding…
Is there any advices on how to proceed??
thank you,
Paulo
