I have two Xiaomi Mi smart temperature and humidity sensors. They are sitting next to each other and one is showing about 3 degrees hotter than the other. Anyone know if there is a way to offset this in the binding?
Did you ever find out if this is possible? I’ve got a bunch of Wireless Sensor Tags that consistently read the same, and lower than my Aqara/Xiaomi ones which vary by several degrees at least. The temps reported in the Aqara motion sensors also fluctuate and i’d like to be able to offset the values to match the WST ones as I believe they’re more accurate.
profile offset
Hmm, how did I not notice this before? Thanks @rossko57.
Now I just need to figure out which ones are ‘right’…
