Dear foundation friends,
I hope this message finds you well.
I recently purchased a Xiaomi T12 Robot Vacuum in black, which appears to be quite similar to the first-generation Xiaomi vacuum model. While setting up the device, I encountered a few issues I’d like to kindly ask for your assistance with:
- The robot is not detected during the scanning process—only a generic device appears. However, I am able to manually enter the device details, and it successfully comes online.
- Unfortunately, when I attempt to use the “Start Vacuum” command, the robot does not respond or begin cleaning.
Below, I’ve included some additional information about the device that may help in diagnosing the issue:
NAME: OG Xiaomi Robot Vacuum T12
MAC: B8:50:D8:07:XX:XX
IP: 192.168.3.55
TOKEN: 55517944XXXXXXXXXXXXXXXX454A4E64
MODEL: xiaomi.vacuum.b106bk
I would greatly appreciate your guidance on how to resolve this matter. Thank you in advance for your support!
best regards,
/Franz
2025-08-27 11:35:20.181 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Starting Mi IO MessageSenderThread 1059753432
2025-08-27 11:35:29.181 [DEBUG] [o.internal.handler.MiIoVacuumHandler] - Periodic update for 'miio:vacuum:4443c011d7' (miio:vacuum)
2025-08-27 11:35:29.182 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":307,"method":"get_dnd_timer","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 1).
2025-08-27 11:35:29.182 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Sending Ping to device '1059753432' (rk3308-robot32.fritz.box)
2025-08-27 11:35:29.183 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Opening socket on port: 36663 (1059753432 rk3308-robot32.fritz.box)
2025-08-27 11:35:29.192 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Ping to device '1059753432' (rk3308-robot32.fritz.box) success
2025-08-27 11:35:29.193 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":308,"method":"get_clean_summary","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 1).
2025-08-27 11:35:29.194 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Sending Ping to device '1059753432' (rk3308-robot32.fritz.box)
2025-08-27 11:35:35.358 [DEBUG] [o.internal.handler.MiIoVacuumHandler] - Periodic update for 'miio:vacuum:4443c011d7' (miio:vacuum)
2025-08-27 11:35:35.358 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Starting Mi IO MessageSenderThread 1059753432
2025-08-27 11:35:35.359 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":307,"method":"get_dnd_timer","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 1).
2025-08-27 11:35:35.359 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Sending Ping to device '1059753432' (rk3308-robot32.fritz.box)
2025-08-27 11:35:35.361 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Opening socket on port: 49354 (1059753432 rk3308-robot32.fritz.box)
2025-08-27 11:35:35.366 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Ping to device '1059753432' (rk3308-robot32.fritz.box) success
2025-08-27 11:35:35.366 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler tried updating the thing status although the handler was already disposed.
2025-08-27 11:35:35.367 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":308,"method":"get_clean_summary","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 2).
2025-08-27 11:35:35.367 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Sending Ping to device '1059753432' (rk3308-robot32.fritz.box)
2025-08-27 11:35:35.378 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Ping to device '1059753432' (rk3308-robot32.fritz.box) success
2025-08-27 11:35:35.379 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler tried updating the thing status although the handler was already disposed.
2025-08-27 11:35:35.379 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":309,"method":"get_status","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 3).
2025-08-27 11:35:35.379 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Sending Ping to device '1059753432' (rk3308-robot32.fritz.box)
2025-08-27 11:35:35.387 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Ping to device '1059753432' (rk3308-robot32.fritz.box) success
2025-08-27 11:35:35.388 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler tried updating the thing status although the handler was already disposed.
2025-08-27 11:35:35.388 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":310,"method":"get_consumable","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 4).
2025-08-27 11:35:35.388 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Sending Ping to device '1059753432' (rk3308-robot32.fritz.box)
2025-08-27 11:35:35.397 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Ping to device '1059753432' (rk3308-robot32.fritz.box) success
2025-08-27 11:35:35.398 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler tried updating the thing status although the handler was already disposed.
2025-08-27 11:35:35.398 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel cleaning#map is linked although the handler was already disposed.
2025-08-27 11:35:35.398 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel info#customize_clean_mode is linked although the handler was already disposed.
2025-08-27 11:35:35.398 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel status#dock_state_id is linked although the handler was already disposed.
2025-08-27 11:35:35.399 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel actions#clean_mop_start is linked although the handler was already disposed.
2025-08-27 11:35:35.399 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel actions#collect_dust is linked although the handler was already disposed.
2025-08-27 11:35:35.399 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel info#multi_maps_list is linked although the handler was already disposed.
2025-08-27 11:35:35.399 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel actions#clean_mop_stop is linked although the handler was already disposed.
2025-08-27 11:35:35.399 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel status#map_status is linked although the handler was already disposed.
2025-08-27 11:35:35.399 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel status#led_status is linked although the handler was already disposed.
2025-08-27 11:35:35.400 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel status#segment_status is linked although the handler was already disposed.
2025-08-27 11:35:35.400 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel info#fw_features is linked although the handler was already disposed.
2025-08-27 11:35:35.400 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel status#mop_drying_time is linked although the handler was already disposed.
2025-08-27 11:35:35.400 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel info#carpet_mode is linked although the handler was already disposed.
2025-08-27 11:35:35.400 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel info#room_mapping is linked although the handler was already disposed.
2025-08-27 11:35:35.400 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel status#is_mop_drying is linked although the handler was already disposed.
2025-08-27 11:35:39.646 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: DND_GET, result: {}, fullresponse: {"id":307,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4173}
2025-08-27 11:35:39.647 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":307,"method":"get_dnd_timer","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:35:43.825 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: CLEAN_SUMMARY_GET, result: {}, fullresponse: {"id":308,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4170}
2025-08-27 11:35:43.826 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":308,"method":"get_clean_summary","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:35:44.197 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Communication error for Mi device at rk3308-robot32.fritz.box: Receive timed out
2025-08-27 11:35:44.198 [DEBUG] [nal.transport.MiIoAsyncCommunication] - No response from device 1059753432 at rk3308-robot32.fritz.box for command {"id":307,"method":"get_dnd_timer","params":[]}.
2025-08-27 11:35:44.198 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Received message is without id: {"error":"No Response"}
2025-08-27 11:35:44.198 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: DND_GET, result: {}, fullresponse: {"error":"Received message is without id"}
2025-08-27 11:35:44.198 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":307,"method":"get_dnd_timer","params":[]}': "Received message is without id".
2025-08-27 11:35:44.207 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Ping to device '1059753432' (rk3308-robot32.fritz.box) success
2025-08-27 11:35:44.207 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":309,"method":"get_status","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 1).
2025-08-27 11:35:44.208 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":310,"method":"miIO.info","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 2).
2025-08-27 11:35:44.208 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":311,"method":"get_consumable","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 3).
2025-08-27 11:35:44.208 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'miio:vacuum:4443c011d7' changed from OFFLINE to ONLINE
2025-08-27 11:35:48.006 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: GET_STATUS, result: {}, fullresponse: {"id":309,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4170}
2025-08-27 11:35:48.006 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":309,"method":"get_status","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:35:48.231 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: CLEAN_SUMMARY_GET, result: {}, fullresponse: {"id":308,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4009}
2025-08-27 11:35:48.231 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":308,"method":"get_clean_summary","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:35:52.186 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: CONSUMABLES_GET, result: {}, fullresponse: {"id":310,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4170}
2025-08-27 11:35:52.187 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":310,"method":"get_consumable","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:35:52.257 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: GET_STATUS, result: {}, fullresponse: {"id":309,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4007}
2025-08-27 11:35:52.258 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":309,"method":"get_status","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:35:52.271 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: MIIO_INFO, result: {"life":79889,"model":"xiaomi.vacuum.b106bk","token":"516a64577261646d4962744676503444","ipflag":1,"miio_ver":"0.0.9","uid":1809013495,"uptime":80074,"mac":"b8:50:d8:07:53:8e","fw_ver":"4.3.3_0010","hw_ver":"Linux","miio_client_ver":"4.3.3","VmPeak":57012,"VmSize":57012,"VmRSS":1520,"MemFree":252948,"ap":{"ssid":"OhWehLAN","bssid":"88:C3:97:C5:DC:D5","rssi":"-34","freq":2412},"netif":{"localIp":"192.168.3.55","mask":"255.255.255.0","gw":"192.168.3.1"},"config_type":"app","miio_times":[79889,8,3,79846]}, fullresponse: {"id":310,"result":{"life":79889,"model":"xiaomi.vacuum.b106bk","token":"516a64577261646d4962744676503444","ipflag":1,"miio_ver":"0.0.9","uid":1809013495,"uptime":80074,"mac":"b8:50:d8:07:53:8e","fw_ver":"4.3.3_0010","hw_ver":"Linux","miio_client_ver":"4.3.3","VmPeak":57012,"VmSize":57012,"VmRSS":1520,"MemFree":252948,"ap":{"ssid":"OhWehLAN","bssid":"88:C3:97:C5:DC:D5","rssi":"-34","freq":2412},"netif":{"localIp":"192.168.3.55","mask":"255.255.255.0","gw":"192.168.3.1"},"config_type":"app","miio_times":[79889,8,3,79846]},"exe_time":3}
2025-08-27 11:35:52.273 [INFO ] [internal.handler.MiIoAbstractHandler] - Mi Device model Unknown Mi IO Device (unknown) identified as: miio:unsupported, thingtype miio:vacuum. Does not matches thingtype miio:unsupported. Unexpected, unless manual override.
2025-08-27 11:35:52.274 [DEBUG] [internal.handler.MiIoAbstractHandler] - No RSSI info in response
2025-08-27 11:35:56.617 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: CONSUMABLES_GET, result: {}, fullresponse: {"id":311,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4326}
2025-08-27 11:35:56.618 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":311,"method":"get_consumable","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:36:05.401 [DEBUG] [o.internal.handler.MiIoVacuumHandler] - Periodic update for 'miio:vacuum:4443c011d7' (miio:vacuum)
2025-08-27 11:36:05.401 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":311,"method":"get_dnd_timer","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 1).
2025-08-27 11:36:05.401 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":312,"method":"get_clean_summary","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 2).
2025-08-27 11:36:05.402 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":313,"method":"get_status","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 3).
2025-08-27 11:36:05.402 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":314,"method":"miIO.info","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 4).
2025-08-27 11:36:05.402 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":315,"method":"get_consumable","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 5).
2025-08-27 11:36:05.402 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel cleaning#map is linked although the handler was already disposed.
2025-08-27 11:36:05.403 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel info#customize_clean_mode is linked although the handler was already disposed.
2025-08-27 11:36:05.403 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel status#dock_state_id is linked although the handler was already disposed.
2025-08-27 11:36:05.403 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel actions#clean_mop_start is linked although the handler was already disposed.
2025-08-27 11:36:05.403 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel actions#collect_dust is linked although the handler was already disposed.
2025-08-27 11:36:05.403 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel info#multi_maps_list is linked although the handler was already disposed.
2025-08-27 11:36:05.403 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel actions#clean_mop_stop is linked although the handler was already disposed.
2025-08-27 11:36:05.404 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel status#map_status is linked although the handler was already disposed.
2025-08-27 11:36:05.404 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel status#led_status is linked although the handler was already disposed.
2025-08-27 11:36:05.404 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel status#segment_status is linked although the handler was already disposed.
2025-08-27 11:36:05.404 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel info#fw_features is linked although the handler was already disposed.
2025-08-27 11:36:05.404 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel status#mop_drying_time is linked although the handler was already disposed.
2025-08-27 11:36:05.404 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel info#carpet_mode is linked although the handler was already disposed.
2025-08-27 11:36:05.404 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel info#room_mapping is linked although the handler was already disposed.
2025-08-27 11:36:05.405 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel status#is_mop_drying is linked although the handler was already disposed.
2025-08-27 11:36:09.621 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: DND_GET, result: {}, fullresponse: {"id":311,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4196}
2025-08-27 11:36:09.621 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":311,"method":"get_dnd_timer","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:36:13.794 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: CLEAN_SUMMARY_GET, result: {}, fullresponse: {"id":312,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4162}
2025-08-27 11:36:13.794 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":312,"method":"get_clean_summary","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:36:14.209 [DEBUG] [o.internal.handler.MiIoVacuumHandler] - Periodic update for 'miio:vacuum:4443c011d7' (miio:vacuum)
2025-08-27 11:36:14.209 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":312,"method":"get_dnd_timer","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 1).
2025-08-27 11:36:14.210 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":313,"method":"get_clean_summary","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 2).
2025-08-27 11:36:14.210 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":314,"method":"get_status","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 3).
2025-08-27 11:36:14.210 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":315,"method":"get_consumable","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 4).
2025-08-27 11:36:17.969 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: GET_STATUS, result: {}, fullresponse: {"id":313,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4165}
2025-08-27 11:36:17.969 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":313,"method":"get_status","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:36:17.984 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: MIIO_INFO, result: {"life":79915,"model":"xiaomi.vacuum.b106bk","token":"516a64577261646d4962744676503444","ipflag":1,"miio_ver":"0.0.9","uid":1809013495,"uptime":80100,"mac":"b8:50:d8:07:53:8e","fw_ver":"4.3.3_0010","hw_ver":"Linux","miio_client_ver":"4.3.3","VmPeak":57012,"VmSize":57012,"VmRSS":1520,"MemFree":253216,"ap":{"ssid":"OhWehLAN","bssid":"88:C3:97:C5:DC:D5","rssi":"-34","freq":2412},"netif":{"localIp":"192.168.3.55","mask":"255.255.255.0","gw":"192.168.3.1"},"config_type":"app","miio_times":[79915,8,3,79872]}, fullresponse: {"id":314,"result":{"life":79915,"model":"xiaomi.vacuum.b106bk","token":"516a64577261646d4962744676503444","ipflag":1,"miio_ver":"0.0.9","uid":1809013495,"uptime":80100,"mac":"b8:50:d8:07:53:8e","fw_ver":"4.3.3_0010","hw_ver":"Linux","miio_client_ver":"4.3.3","VmPeak":57012,"VmSize":57012,"VmRSS":1520,"MemFree":253216,"ap":{"ssid":"OhWehLAN","bssid":"88:C3:97:C5:DC:D5","rssi":"-34","freq":2412},"netif":{"localIp":"192.168.3.55","mask":"255.255.255.0","gw":"192.168.3.1"},"config_type":"app","miio_times":[79915,8,3,79872]},"exe_time":2}
2025-08-27 11:36:17.985 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried updating channel network#ssid although the handler was already disposed.
2025-08-27 11:36:17.985 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried updating channel network#bssid although the handler was already disposed.
2025-08-27 11:36:17.985 [DEBUG] [internal.handler.MiIoAbstractHandler] - No RSSI info in response
2025-08-27 11:36:17.985 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried updating channel network#life although the handler was already disposed.
2025-08-27 11:36:18.409 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: DND_GET, result: {}, fullresponse: {"id":312,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4150}
2025-08-27 11:36:18.409 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":312,"method":"get_dnd_timer","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:36:22.166 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: CONSUMABLES_GET, result: {}, fullresponse: {"id":315,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4164}
2025-08-27 11:36:22.166 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":315,"method":"get_consumable","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:36:22.421 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: CLEAN_SUMMARY_GET, result: {}, fullresponse: {"id":313,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4001}
2025-08-27 11:36:22.421 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":313,"method":"get_clean_summary","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:36:26.594 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: GET_STATUS, result: {}, fullresponse: {"id":314,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4164}
2025-08-27 11:36:26.594 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":314,"method":"get_status","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:36:30.897 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: CONSUMABLES_GET, result: {}, fullresponse: {"id":315,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4283}
2025-08-27 11:36:30.897 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":315,"method":"get_consumable","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:36:35.405 [DEBUG] [o.internal.handler.MiIoVacuumHandler] - Periodic update for 'miio:vacuum:4443c011d7' (miio:vacuum)
2025-08-27 11:36:35.405 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":316,"method":"get_dnd_timer","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 1).
2025-08-27 11:36:35.406 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":317,"method":"get_clean_summary","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 2).
2025-08-27 11:36:35.406 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":318,"method":"get_status","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 3).
2025-08-27 11:36:35.406 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":319,"method":"get_consumable","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 4).
2025-08-27 11:36:35.406 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel cleaning#map is linked although the handler was already disposed.
2025-08-27 11:36:35.406 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel info#customize_clean_mode is linked although the handler was already disposed.
2025-08-27 11:36:35.407 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel status#dock_state_id is linked although the handler was already disposed.
2025-08-27 11:36:35.407 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel actions#clean_mop_start is linked although the handler was already disposed.
2025-08-27 11:36:35.407 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel actions#collect_dust is linked although the handler was already disposed.
2025-08-27 11:36:35.407 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel info#multi_maps_list is linked although the handler was already disposed.
2025-08-27 11:36:35.407 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel actions#clean_mop_stop is linked although the handler was already disposed.
2025-08-27 11:36:35.407 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel status#map_status is linked although the handler was already disposed.
2025-08-27 11:36:35.407 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel status#led_status is linked although the handler was already disposed.
2025-08-27 11:36:35.407 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel status#segment_status is linked although the handler was already disposed.
2025-08-27 11:36:35.408 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel info#fw_features is linked although the handler was already disposed.
2025-08-27 11:36:35.408 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel status#mop_drying_time is linked although the handler was already disposed.
2025-08-27 11:36:35.408 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel info#carpet_mode is linked although the handler was already disposed.
2025-08-27 11:36:35.408 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel info#room_mapping is linked although the handler was already disposed.
2025-08-27 11:36:35.409 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel status#is_mop_drying is linked although the handler was already disposed.
2025-08-27 11:36:39.815 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: DND_GET, result: {}, fullresponse: {"id":316,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4320}
2025-08-27 11:36:39.816 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":316,"method":"get_dnd_timer","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:36:43.989 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: CLEAN_SUMMARY_GET, result: {}, fullresponse: {"id":317,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4163}
2025-08-27 11:36:43.990 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":317,"method":"get_clean_summary","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:36:44.211 [DEBUG] [o.internal.handler.MiIoVacuumHandler] - Periodic update for 'miio:vacuum:4443c011d7' (miio:vacuum)
2025-08-27 11:36:44.211 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":316,"method":"get_dnd_timer","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 1).
2025-08-27 11:36:44.211 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":317,"method":"get_clean_summary","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 2).
2025-08-27 11:36:44.212 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":318,"method":"get_status","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 3).
2025-08-27 11:36:44.212 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":319,"method":"miIO.info","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 4).
2025-08-27 11:36:44.212 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":320,"method":"get_consumable","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 5).
2025-08-27 11:36:48.166 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: GET_STATUS, result: {}, fullresponse: {"id":318,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4168}
2025-08-27 11:36:48.167 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":318,"method":"get_status","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:36:48.339 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: DND_GET, result: {}, fullresponse: {"id":316,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4007}
2025-08-27 11:36:48.339 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":316,"method":"get_dnd_timer","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:36:52.512 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: CLEAN_SUMMARY_GET, result: {}, fullresponse: {"id":317,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4152}
2025-08-27 11:36:52.512 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: CONSUMABLES_GET, result: {}, fullresponse: {"id":319,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4335}
2025-08-27 11:36:52.512 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":319,"method":"get_consumable","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:36:52.513 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":317,"method":"get_clean_summary","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:36:56.695 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: GET_STATUS, result: {}, fullresponse: {"id":318,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4163}
2025-08-27 11:36:56.695 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":318,"method":"get_status","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:36:56.717 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: MIIO_INFO, result: {"life":79954,"model":"xiaomi.vacuum.b106bk","token":"516a64577261646d4962744676503444","ipflag":1,"miio_ver":"0.0.9","uid":1809013495,"uptime":80139,"mac":"b8:50:d8:07:53:8e","fw_ver":"4.3.3_0010","hw_ver":"Linux","miio_client_ver":"4.3.3","VmPeak":57012,"VmSize":57012,"VmRSS":1520,"MemFree":252816,"ap":{"ssid":"OhWehLAN","bssid":"88:C3:97:C5:DC:D5","rssi":"-33","freq":2412},"netif":{"localIp":"192.168.3.55","mask":"255.255.255.0","gw":"192.168.3.1"},"config_type":"app","miio_times":[79953,8,3,79910]}, fullresponse: {"id":319,"result":{"life":79954,"model":"xiaomi.vacuum.b106bk","token":"516a64577261646d4962744676503444","ipflag":1,"miio_ver":"0.0.9","uid":1809013495,"uptime":80139,"mac":"b8:50:d8:07:53:8e","fw_ver":"4.3.3_0010","hw_ver":"Linux","miio_client_ver":"4.3.3","VmPeak":57012,"VmSize":57012,"VmRSS":1520,"MemFree":252816,"ap":{"ssid":"OhWehLAN","bssid":"88:C3:97:C5:DC:D5","rssi":"-33","freq":2412},"netif":{"localIp":"192.168.3.55","mask":"255.255.255.0","gw":"192.168.3.1"},"config_type":"app","miio_times":[79953,8,3,79910]},"exe_time":2}
2025-08-27 11:36:56.718 [DEBUG] [internal.handler.MiIoAbstractHandler] - No RSSI info in response
2025-08-27 11:37:00.778 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: CONSUMABLES_GET, result: {}, fullresponse: {"id":320,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4050}
2025-08-27 11:37:00.779 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":320,"method":"get_consumable","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:37:05.409 [DEBUG] [o.internal.handler.MiIoVacuumHandler] - Periodic update for 'miio:vacuum:4443c011d7' (miio:vacuum)
2025-08-27 11:37:05.409 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":320,"method":"get_dnd_timer","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 1).
2025-08-27 11:37:05.410 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":321,"method":"get_clean_summary","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 2).
2025-08-27 11:37:05.410 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":322,"method":"get_status","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 3).
2025-08-27 11:37:05.411 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":323,"method":"miIO.info","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 4).
2025-08-27 11:37:05.411 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":324,"method":"get_consumable","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 5).
2025-08-27 11:37:05.412 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel cleaning#map is linked although the handler was already disposed.
2025-08-27 11:37:05.412 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel info#customize_clean_mode is linked although the handler was already disposed.
2025-08-27 11:37:05.413 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel status#dock_state_id is linked although the handler was already disposed.
2025-08-27 11:37:05.413 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel actions#clean_mop_start is linked although the handler was already disposed.
2025-08-27 11:37:05.414 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel actions#collect_dust is linked although the handler was already disposed.
2025-08-27 11:37:05.414 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel info#multi_maps_list is linked although the handler was already disposed.
2025-08-27 11:37:05.415 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel actions#clean_mop_stop is linked although the handler was already disposed.
2025-08-27 11:37:05.415 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel status#map_status is linked although the handler was already disposed.
2025-08-27 11:37:05.416 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel status#led_status is linked although the handler was already disposed.
2025-08-27 11:37:05.416 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel status#segment_status is linked although the handler was already disposed.
2025-08-27 11:37:05.417 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel info#fw_features is linked although the handler was already disposed.
2025-08-27 11:37:05.418 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel status#mop_drying_time is linked although the handler was already disposed.
2025-08-27 11:37:05.418 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel info#carpet_mode is linked although the handler was already disposed.
2025-08-27 11:37:05.419 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel info#room_mapping is linked although the handler was already disposed.
2025-08-27 11:37:05.419 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel status#is_mop_drying is linked although the handler was already disposed.
2025-08-27 11:37:09.617 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: DND_GET, result: {}, fullresponse: {"id":320,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4168}
2025-08-27 11:37:09.617 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":320,"method":"get_dnd_timer","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:37:12.569 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":321,"method":"app_start","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 1).
2025-08-27 11:37:13.809 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: CLEAN_SUMMARY_GET, result: {}, fullresponse: {"id":321,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4172}
2025-08-27 11:37:13.809 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":321,"method":"get_clean_summary","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:37:14.213 [DEBUG] [o.internal.handler.MiIoVacuumHandler] - Periodic update for 'miio:vacuum:4443c011d7' (miio:vacuum)
2025-08-27 11:37:14.213 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":322,"method":"get_dnd_timer","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 1).
2025-08-27 11:37:14.214 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":323,"method":"get_clean_summary","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 2).
2025-08-27 11:37:14.214 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":324,"method":"get_status","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 3).
2025-08-27 11:37:14.214 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":325,"method":"get_consumable","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 4).
2025-08-27 11:37:18.144 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: GET_STATUS, result: {}, fullresponse: {"id":322,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4162}
2025-08-27 11:37:18.145 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":322,"method":"get_status","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:37:18.157 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: MIIO_INFO, result: {"life":79975,"model":"xiaomi.vacuum.b106bk","token":"516a64577261646d4962744676503444","ipflag":1,"miio_ver":"0.0.9","uid":1809013495,"uptime":80160,"mac":"b8:50:d8:07:53:8e","fw_ver":"4.3.3_0010","hw_ver":"Linux","miio_client_ver":"4.3.3","VmPeak":57012,"VmSize":57012,"VmRSS":1520,"MemFree":252692,"ap":{"ssid":"OhWehLAN","bssid":"88:C3:97:C5:DC:D5","rssi":"-33","freq":2412},"netif":{"localIp":"192.168.3.55","mask":"255.255.255.0","gw":"192.168.3.1"},"config_type":"app","miio_times":[79975,8,3,79932]}, fullresponse: {"id":323,"result":{"life":79975,"model":"xiaomi.vacuum.b106bk","token":"516a64577261646d4962744676503444","ipflag":1,"miio_ver":"0.0.9","uid":1809013495,"uptime":80160,"mac":"b8:50:d8:07:53:8e","fw_ver":"4.3.3_0010","hw_ver":"Linux","miio_client_ver":"4.3.3","VmPeak":57012,"VmSize":57012,"VmRSS":1520,"MemFree":252692,"ap":{"ssid":"OhWehLAN","bssid":"88:C3:97:C5:DC:D5","rssi":"-33","freq":2412},"netif":{"localIp":"192.168.3.55","mask":"255.255.255.0","gw":"192.168.3.1"},"config_type":"app","miio_times":[79975,8,3,79932]},"exe_time":2}
2025-08-27 11:37:18.157 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried updating channel network#ssid although the handler was already disposed.
2025-08-27 11:37:18.158 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried updating channel network#bssid although the handler was already disposed.
2025-08-27 11:37:18.158 [DEBUG] [internal.handler.MiIoAbstractHandler] - No RSSI info in response
2025-08-27 11:37:18.158 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried updating channel network#life although the handler was already disposed.
2025-08-27 11:37:22.337 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: CONSUMABLES_GET, result: {}, fullresponse: {"id":324,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4169}
2025-08-27 11:37:22.337 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":324,"method":"get_consumable","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:37:27.604 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Communication error for Mi device at rk3308-robot32.fritz.box: Receive timed out
2025-08-27 11:37:27.604 [DEBUG] [nal.transport.MiIoAsyncCommunication] - No response from device 1059753432 at rk3308-robot32.fritz.box for command {"id":321,"method":"app_start","params":[]}.
2025-08-27 11:37:27.604 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Received message is without id: {"error":"No Response"}
2025-08-27 11:37:27.605 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: START_VACUUM, result: {}, fullresponse: {"error":"Received message is without id"}
2025-08-27 11:37:27.605 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":321,"method":"app_start","params":[]}': "Received message is without id".
2025-08-27 11:37:31.781 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: DND_GET, result: {}, fullresponse: {"id":322,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4163}
2025-08-27 11:37:31.782 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":322,"method":"get_dnd_timer","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:37:35.420 [DEBUG] [o.internal.handler.MiIoVacuumHandler] - Periodic update for 'miio:vacuum:4443c011d7' (miio:vacuum)
2025-08-27 11:37:35.420 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":325,"method":"get_dnd_timer","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 1).
2025-08-27 11:37:35.421 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":326,"method":"get_clean_summary","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 2).
2025-08-27 11:37:35.421 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":327,"method":"get_status","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 3).
2025-08-27 11:37:35.421 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":328,"method":"get_consumable","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 4).
2025-08-27 11:37:35.422 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel cleaning#map is linked although the handler was already disposed.
2025-08-27 11:37:35.422 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel info#customize_clean_mode is linked although the handler was already disposed.
2025-08-27 11:37:35.422 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel status#dock_state_id is linked although the handler was already disposed.
2025-08-27 11:37:35.422 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel actions#clean_mop_start is linked although the handler was already disposed.
2025-08-27 11:37:35.422 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel actions#collect_dust is linked although the handler was already disposed.
2025-08-27 11:37:35.423 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel info#multi_maps_list is linked although the handler was already disposed.
2025-08-27 11:37:35.423 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel actions#clean_mop_stop is linked although the handler was already disposed.
2025-08-27 11:37:35.423 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel status#map_status is linked although the handler was already disposed.
2025-08-27 11:37:35.423 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel status#led_status is linked although the handler was already disposed.
2025-08-27 11:37:35.423 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel status#segment_status is linked although the handler was already disposed.
2025-08-27 11:37:35.423 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel info#fw_features is linked although the handler was already disposed.
2025-08-27 11:37:35.424 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel status#mop_drying_time is linked although the handler was already disposed.
2025-08-27 11:37:35.424 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel info#carpet_mode is linked although the handler was already disposed.
2025-08-27 11:37:35.424 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel info#room_mapping is linked although the handler was already disposed.
2025-08-27 11:37:35.424 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel status#is_mop_drying is linked although the handler was already disposed.
2025-08-27 11:37:35.798 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: CLEAN_SUMMARY_GET, result: {}, fullresponse: {"id":323,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4007}
2025-08-27 11:37:35.798 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":323,"method":"get_clean_summary","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:37:39.639 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: DND_GET, result: {}, fullresponse: {"id":325,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4165}
2025-08-27 11:37:39.639 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":325,"method":"get_dnd_timer","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:37:39.823 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: GET_STATUS, result: {}, fullresponse: {"id":324,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4005}
2025-08-27 11:37:39.823 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":324,"method":"get_status","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:37:43.831 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: CLEAN_SUMMARY_GET, result: {}, fullresponse: {"id":326,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4169}
2025-08-27 11:37:43.831 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":326,"method":"get_clean_summary","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:37:43.848 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: CONSUMABLES_GET, result: {}, fullresponse: {"id":325,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4005}
2025-08-27 11:37:43.849 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":325,"method":"get_consumable","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:37:44.215 [DEBUG] [o.internal.handler.MiIoVacuumHandler] - Periodic update for 'miio:vacuum:4443c011d7' (miio:vacuum)
2025-08-27 11:37:44.216 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":326,"method":"get_dnd_timer","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 1).
2025-08-27 11:37:44.216 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":327,"method":"get_clean_summary","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 2).
2025-08-27 11:37:44.217 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":328,"method":"get_status","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 3).
2025-08-27 11:37:44.217 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":329,"method":"miIO.info","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 4).
2025-08-27 11:37:44.218 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":330,"method":"get_consumable","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 5).
2025-08-27 11:37:48.092 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: GET_STATUS, result: {}, fullresponse: {"id":327,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4240}
2025-08-27 11:37:48.092 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":327,"method":"get_status","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:37:48.273 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: DND_GET, result: {}, fullresponse: {"id":326,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4010}
2025-08-27 11:37:48.274 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":326,"method":"get_dnd_timer","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:37:52.271 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: CONSUMABLES_GET, result: {}, fullresponse: {"id":328,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4162}
2025-08-27 11:37:52.272 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":328,"method":"get_consumable","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:37:52.291 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: CLEAN_SUMMARY_GET, result: {}, fullresponse: {"id":327,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4008}
2025-08-27 11:37:52.292 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":327,"method":"get_clean_summary","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:37:56.465 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: GET_STATUS, result: {}, fullresponse: {"id":328,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4152}
2025-08-27 11:37:56.465 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":328,"method":"get_status","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:37:56.477 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: MIIO_INFO, result: {"life":80014,"model":"xiaomi.vacuum.b106bk","token":"516a64577261646d4962744676503444","ipflag":1,"miio_ver":"0.0.9","uid":1809013495,"uptime":80199,"mac":"b8:50:d8:07:53:8e","fw_ver":"4.3.3_0010","hw_ver":"Linux","miio_client_ver":"4.3.3","VmPeak":57012,"VmSize":57012,"VmRSS":1520,"MemFree":253064,"ap":{"ssid":"OhWehLAN","bssid":"88:C3:97:C5:DC:D5","rssi":"-33","freq":2412},"netif":{"localIp":"192.168.3.55","mask":"255.255.255.0","gw":"192.168.3.1"},"config_type":"app","miio_times":[80013,8,3,79970]}, fullresponse: {"id":329,"result":{"life":80014,"model":"xiaomi.vacuum.b106bk","token":"516a64577261646d4962744676503444","ipflag":1,"miio_ver":"0.0.9","uid":1809013495,"uptime":80199,"mac":"b8:50:d8:07:53:8e","fw_ver":"4.3.3_0010","hw_ver":"Linux","miio_client_ver":"4.3.3","VmPeak":57012,"VmSize":57012,"VmRSS":1520,"MemFree":253064,"ap":{"ssid":"OhWehLAN","bssid":"88:C3:97:C5:DC:D5","rssi":"-33","freq":2412},"netif":{"localIp":"192.168.3.55","mask":"255.255.255.0","gw":"192.168.3.1"},"config_type":"app","miio_times":[80013,8,3,79970]},"exe_time":2}
2025-08-27 11:37:56.477 [DEBUG] [internal.handler.MiIoAbstractHandler] - No RSSI info in response
2025-08-27 11:37:57.999 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":331,"method":"app_stop","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 1).
2025-08-27 11:38:00.000 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":332,"method":"app_charge","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 2).
2025-08-27 11:38:00.081 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":333,"method":"app_start","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 3).
2025-08-27 11:38:00.741 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: CONSUMABLES_GET, result: {}, fullresponse: {"id":330,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4255}
2025-08-27 11:38:00.742 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":330,"method":"get_consumable","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:38:03.001 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":334,"method":"get_status","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 3).
2025-08-27 11:38:04.924 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 4443c011d7 type: STOP_VACUUM, result: {}, fullresponse: {"id":331,"error":{"code":-9999,"message":"user ack timeout"},"exe_time":4171}
2025-08-27 11:38:04.924 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received for command '{"id":331,"method":"app_stop","params":[]}': {"code":-9999,"message":"user ack timeout"}.
2025-08-27 11:38:05.424 [DEBUG] [o.internal.handler.MiIoVacuumHandler] - Periodic update for 'miio:vacuum:4443c011d7' (miio:vacuum)
2025-08-27 11:38:05.425 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":329,"method":"get_dnd_timer","params":[]} -> rk3308-robot32.fritz.box (Device: 10597534XX token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 1).
2025-08-27 11:38:05.425 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":330,"method":"get_clean_summary","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 2).
2025-08-27 11:38:05.425 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":331,"method":"get_status","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 3).
2025-08-27 11:38:05.426 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":332,"method":"miIO.info","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 4).
2025-08-27 11:38:05.426 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":333,"method":"get_consumable","params":[]} -> rk3308-robot32.fritz.box (Device: 1059753432 token: 516A6457XXXXXXXXXXXXXXXX76503444 Queue: 5).
2025-08-27 11:38:05.427 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel cleaning#map is linked although the handler was already disposed.
2025-08-27 11:38:05.427 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel info#customize_clean_mode is linked although the handler was already disposed.
2025-08-27 11:38:05.427 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel status#dock_state_id is linked although the handler was already disposed.
2025-08-27 11:38:05.428 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel actions#clean_mop_start is linked although the handler was already disposed.
2025-08-27 11:38:05.428 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel actions#collect_dust is linked although the handler was already disposed.
2025-08-27 11:38:05.428 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel info#multi_maps_list is linked although the handler was already disposed.
2025-08-27 11:38:05.429 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel actions#clean_mop_stop is linked although the handler was already disposed.
2025-08-27 11:38:05.429 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel status#map_status is linked although the handler was already disposed.
2025-08-27 11:38:05.429 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel status#led_status is linked although the handler was already disposed.
2025-08-27 11:38:05.430 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel status#segment_status is linked although the handler was already disposed.
2025-08-27 11:38:05.430 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel info#fw_features is linked although the handler was already disposed.
2025-08-27 11:38:05.430 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel status#mop_drying_time is linked although the handler was already disposed.
2025-08-27 11:38:05.430 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel info#carpet_mode is linked although the handler was already disposed.
2025-08-27 11:38:05.431 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel info#room_mapping is linked although the handler was already disposed.
2025-08-27 11:38:05.431 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:4443c011d7 tried checking if channel status#is_mop_drying is linked although the handler was already disposed.
