Xiaomi MIIO - Mi Gateway V3
Hi, I’m using Xiaomi MIIO Binding for my Xiaomi Gateway V3.
The thing is discovered without any issue, however I can only see the following channels, there are much more functionalities such as light/motion sensor, night light etc., are they not supported by the binding? Thank you!
What is the exact model of your gateway (that you see in the thing config).
Also, there have been significant updates in the hub, so depending on your OH version you may see differences.
You may try to ‘override’ your model with lumi.gateway.mieu01 if you have a different one.
If that is the case, let me know the results.
This is what I see as channels
