In ubuntu the binding creates this config file in
/var/lib/openhab2/config/binding/miio.config
Just wondering, in the text-only configuration, would i have to place the text file in that directory as well?
As all other text configs are usually stored in /etc/openhab2/services
Thanks for your reply. Just to be sure: This means that I have to use PaperUI at least once to initially configure the binding and to let PaperUI create the file? There is no way to initialize the binding with text-only configuration?
no, just make the file directly will also work.
From the binding perspective I don’t control the file/info, I suggested PaperUI as I think it is just the most convenient way to create it and be sure the format is right. If find out the exact location and format, please share for others that may want to do it in the same way.
So the binding is not aware if you enter it via file or paperUI. This is handled by the OH framework.
I have a short question regarding your update with the shown maps and the connection to the Xiaomi Cloud. I have a small child walking all around and touching everything. Sometime he is playing with my roborock (1st generation), which loses the coordinates and can no longer clean the defined spots. The problem was posted some months ago in this post.
Is your updated binding ready to satisfy this problem?
my map doesnt work with xiaomi vacuum 1s. any ideas what im doing wrong?
(debian netinstall with openhabian)
2020-04-23 12:44:36.876 [INFO ] [g.miio.internal.cloud.CloudConnector] - Getting vacuum map ruby2%2F321261849%2F7 from Xiaomi cloud server:
2020-04-23 12:44:37.874 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
java.lang.Error: Probable fatal error:No fonts found.
at sun.font.SunFontManager.getDefaultPhysicalFont(SunFontManager.java:1236) ~[?:1.8.0_232]
at sun.font.SunFontManager.initialiseDeferredFont(SunFontManager.java:1106) ~[?:1.8.0_232]
at sun.font.CompositeFont.doDeferredInitialisation(CompositeFont.java:287) ~[?:1.8.0_232]
at sun.font.CompositeFont.getSlotFont(CompositeFont.java:376) ~[?:1.8.0_232]
at sun.font.CompositeStrike.getStrikeForSlot(CompositeStrike.java:82) ~[?:1.8.0_232]
at sun.font.CompositeStrike.getFontMetrics(CompositeStrike.java:97) ~[?:1.8.0_232]
at sun.font.FontDesignMetrics.initMatrixAndMetrics(FontDesignMetrics.java:359) ~[?:1.8.0_232]
at sun.font.FontDesignMetrics.<init>(FontDesignMetrics.java:350) ~[?:1.8.0_232]
at sun.font.FontDesignMetrics.getMetrics(FontDesignMetrics.java:302) ~[?:1.8.0_232]
at sun.java2d.SunGraphics2D.getFontMetrics(SunGraphics2D.java:855) ~[?:1.8.0_232]
at org.openhab.binding.miio.internal.robot.RRMapDraw.drawOpenHabRocks(RRMapDraw.java:337) ~[?:?]
at org.openhab.binding.miio.internal.robot.RRMapDraw.getImage(RRMapDraw.java:379) ~[?:?]
at org.openhab.binding.miio.internal.handler.MiIoVacuumHandler.getMap(MiIoVacuumHandler.java:478) ~[?:?]
at org.openhab.binding.miio.internal.handler.MiIoVacuumHandler.lambda$5(MiIoVacuumHandler.java:451) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:1.8.0_232]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) ~[?:1.8.0_232]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) ~[?:1.8.0_232]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) ~[?:1.8.0_232]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_232]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_232]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_232]
Seems the textfont is not availble..I’ve selected something that should be available on vast majority of systems. seems still not all. See if you can install TimesRoman font to your system
maybe something like sudo apt update && sudo apt install ttf-mscorefonts-installer will do the trick
Something is wrong… unfortunately the meaning of the return codes is not yet known.
I don’t recall seeing this before. UserId / passwd are sure correct? (that gives similar unclear response)
You can give it a try with fully restarting openhab, that clears all the cookies.
If that helps, let me know, than I can apply that as a solution for the issue.
i updated via openhabian-config and during the process i saw that it stops openhab.service tries to update java and then restart service again and i think during all that it also clears cache .Thats normal.Then i usually do a reboot when the system settles before i start using openhab.Then i first saw this error…I did a restart again but it did fix anything.My userid/passwd are still there,i did not change anything.
2020-04-23 17:41:39.427 [INFO ] [g.miio.internal.cloud.CloudConnector] - Getting vacuum map ruby2%2F321261849%2F2 from Xiaomi cloud server:
2020-04-23 17:41:41.201 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
[INFO ] [miio.internal.cloud.MiCloudConnector] - Error logging on to Xiaomi cloud (0): Error getting logon location URL. Return code: 70016
It occurs every 10 minutes after migrating from openhab 2.5.3 to 2.5.4 and binding-miio - 2.5.4. The miio binding before updating was the downloadedorg.openhab.binding.miio-2.5.4-SNAPSHOT.jar which i added in the addon folder. This worked fine, all maps could be downloaded. Then I updated openhab to 2.5.4, deleted the mii binding snapshot jar and installed the binding 2.5.4 by paperui. The user and password settings in gui was kept over migration and are fine.
I tried bundle restart, stop from opemnhab and clean cache. Nothing helps.
I even tried to change the server country in binding in papergui.
When changing something country in binding also the message appears first:
[ERROR] [core.thing.internal.ThingManagerImpl] - Exception occurred while calling thing handler factory ‘org.openhab.binding.miio.internal.MiIoHandlerFactory@2e8913’: null
at
org.openhab.binding.miio.internal.handler.MiIoAbstractHandler.tokenCheckPass(MiIoAbstractHandler.java:134) ~[?:?]
at org.openhab.binding.miio.internal.handler.MiIoAbstractHandler.getConnection(MiIoAbstractHandler.java:288) ~[?:?]
at org.openhab.binding.miio.internal.handler.MiIoVacuumHandler.initializeData(MiIoVacuumHandler.java:407) ~[?:?]
at org.openhab.binding.miio.internal.handler.MiIoVacuumHandler.(MiIoVacuumHandler.java:95) ~[?:?]
at org.openhab.binding.miio.internal.MiIoHandlerFactory.createHandler(MiIoHandlerFactory.java:91) ~[?:?]
INFO ] [miio.internal.cloud.MiCloudConnector] - Error logging on to Xiaomi cloud (0): Cannot logon to Xiaomi cloud: Total timeout 10000 ms elapsed
After this it connect fines with the vaccum and get the status but no connection to cloud, still the first error message “Error getting logon location URL” every 10 minutes
download the 2.5.5 snapshot from the normal repositories if you want the latest.
All relevant changes are in the regular builds (or upgrade to 2.5.4 release), no need for my alpha builds.
I still need to do the upgrade myself, but it seems something changed in the framework that created this issue. I did a fresh install 2.5.4 for testing and than I could not reproduce, so maybe it is something in relation to upgrading.
I did now delete the mii thing and uninstalled the binding. Afterwards I added the binding again. Still no connection. And because the missing connection there is no initialized thing found.
so to recap my moves so if i can help with feedback:
i was on 2.5.3 using the 2.5.4 snapshot.jar in my addons folder and all was working fine.I updated to 2.5.4 stable and after restart i get the
i then delete my vacuum,removed jar from addons folder,deleted miio folder from userdata.Stoped openhab,clear cache,restart openhab,reboot.Install binding from PaperUi ,put my userid/pass in settings,discover RoborockS5 with token,add as a thing.Vacuum goes online for awhile and then “OFFLINE - CONFIGURATION_ERROR” .Also it does not discover all the thing channels,only a few.
So the last issue is most likely due to the missing token. Because the logon issue (still to be found the cause) it won’t automatically get the token from the cloud.
If you add your token from before (you can still find it in older log file maybe or else from the json files in the userdata/miio folder the channels will also come back.
most likely similar as @Constantinos_Contis .. add (manually) the token and normal (like 2.5.3) functionality should be back… just not the new goodies from the cloud.
