Something is not proper. I’ve tried commands:
with Thread::sleep(500) and more.
Third time trigger sends it to dock.
Some logs:
2020-07-23 11:42:02.667 [DEBUG] [o.internal.handler.MiIoVacuumHandler] - Periodic update for ‘miio:vacuum:070A579C’ (miio:vacuum)
2020-07-23 11:42:02.668 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:1764,“method”:“get_dnd_timer”,“params”:} → 192.XXX.XXX.XXX (Device: 070A579C token: 49714B79XXXXXXXXXXXXXXXX66725130 Queue: 1)
2020-07-23 11:42:02.669 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:1765,“method”:“get_clean_summary”,“params”:} → 192.XXX.XXX.XXX (Device: 070A579C token: 49714B79XXXXXXXXXXXXXXXX66725130 Queue: 2)
2020-07-23 11:42:02.670 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:1766,“method”:“get_status”,“params”:} → 192.XXX.XXX.XXX (Device: 070A579C token: 49714B79XXXXXXXXXXXXXXXX66725130 Queue: 3)
2020-07-23 11:42:02.670 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Send command ‘{“id”:1764,“method”:“get_dnd_timer”,“params”:}’ → 192.XXX.XXX.XXX (Device: 070A579C) gave error maximum number of DatagramSockets reached
2020-07-23 11:42:02.671 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:1767,“method”:“get_consumable”,“params”:} → 192.XXX.XXX.XXX (Device: 070A579C token: 49714B79XXXXXXXXXXXXXXXX66725130 Queue: 3)
2020-07-23 11:42:02.671 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 070A579C type: DND_GET, result: {}, fullresponse: {“error”:“maximum number of DatagramSockets reached”}
2020-07-23 11:42:02.672 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received: “maximum number of DatagramSockets reached”
2020-07-23 11:42:02.673 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Send command ‘{“id”:1765,“method”:“get_clean_summary”,“params”:}’ → 192.XXX.XXX.XXX (Device: 070A579C) gave error maximum number of DatagramSockets reached
2020-07-23 11:42:02.673 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 070A579C type: CLEAN_SUMMARY_GET, result: {}, fullresponse: {“error”:“maximum number of DatagramSockets reached”}
2020-07-23 11:42:02.674 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received: “maximum number of DatagramSockets reached”
2020-07-23 11:42:02.675 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Send command ‘{“id”:1766,“method”:“get_status”,“params”:}’ → 192.XXX.XXX.XXX (Device: 070A579C) gave error maximum number of DatagramSockets reached
2020-07-23 11:42:02.675 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 070A579C type: GET_STATUS, result: {}, fullresponse: {“error”:“maximum number of DatagramSockets reached”}
2020-07-23 11:42:02.676 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received: “maximum number of DatagramSockets reached”
2020-07-23 11:42:02.676 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Send command ‘{“id”:1767,“method”:“get_consumable”,“params”:}’ → 192.XXX.XXX.XXX (Device: 070A579C) gave error maximum number of DatagramSockets reached
2020-07-23 11:42:02.677 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 070A579C type: CONSUMABLES_GET, result: {}, fullresponse: {“error”:“maximum number of DatagramSockets reached”}
2020-07-23 11:42:02.677 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received: “maximum number of DatagramSockets reached”
2020-07-23 11:42:02.685 [DEBUG] [io.internal.handler.MiIoBasicHandler] - Periodic update for ‘miio:generic:03B4E9F7’ (miio:basic)
2020-07-23 11:42:02.685 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:1769,“method”:“get_prop”,“params”:[“power”,“mode”,“humidity”,“aqi”,“average_aqi”]} → 192.XXX.XXX.XXX (Device: 03B4E9F7 token: D1EACC72XXXXXXXXXXXXXXXX27844769 Queue: 1)
2020-07-23 11:42:02.685 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:1770,“method”:“get_prop”,“params”:[“led”,“buzzer”,“f1_hour”,“f1_hour_used”,“use_time”]} → 192.XXX.XXX.XXX (Device: 03B4E9F7 token: D1EACC72XXXXXXXXXXXXXXXX27844769 Queue: 2)
2020-07-23 11:42:02.686 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:1771,“method”:“get_prop”,“params”:[“motor1_speed”,“filter1_life”,“favorite_level”,“temp_dec”,“purify_volume”]} → 192.XXX.XXX.XXX (Device: 03B4E9F7 token: D1EACC72XXXXXXXXXXXXXXXX27844769 Queue: 3)
2020-07-23 11:42:02.686 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:1772,“method”:“get_prop”,“params”:[“child_lock”]} → 192.XXX.XXX.XXX (Device: 03B4E9F7 token: D1EACC72XXXXXXXXXXXXXXXX27844769 Queue: 4)
2020-07-23 11:42:02.738 [DEBUG] [io.internal.handler.MiIoBasicHandler] - Periodic update for ‘miio:generic:033DE0FB’ (miio:basic)
2020-07-23 11:42:02.738 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:1743,“method”:“get_prop”,“params”:[“power”,“mode”,“humidity”,“aqi”,“average_aqi”]} → 192.XXX.XXX.XXX (Device: 033DE0FB token: 9EB8274EXXXXXXXXXXXXXXXX4D548F74 Queue: 1)
2020-07-23 11:42:02.739 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:1744,“method”:“get_prop”,“params”:[“led”,“buzzer”,“f1_hour”,“f1_hour_used”,“use_time”]} → 192.XXX.XXX.XXX (Device: 033DE0FB token: 9EB8274EXXXXXXXXXXXXXXXX4D548F74 Queue: 2)
2020-07-23 11:42:02.739 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:1745,“method”:“get_prop”,“params”:[“motor1_speed”,“filter1_life”,“favorite_level”,“temp_dec”,“purify_volume”]} → 192.XXX.XXX.XXX (Device: 033DE0FB token: 9EB8274EXXXXXXXXXXXXXXXX4D548F74 Queue: 3)
2020-07-23 11:42:02.740 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:1746,“method”:“get_prop”,“params”:[“child_lock”]} → 192.XXX.XXX.XXX (Device: 033DE0FB token: 9EB8274EXXXXXXXXXXXXXXXX4D548F74 Queue: 4)
2020-07-23 11:42:02.768 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Send command ‘{“id”:1769,“method”:“get_prop”,“params”:[“power”,“mode”,“humidity”,“aqi”,“average_aqi”]}’ → 192.XXX.XXX.XXX (Device: 03B4E9F7) gave error maximum number of DatagramSockets reached
2020-07-23 11:42:02.769 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 03B4E9F7 type: GET_PROPERTY, result: {}, fullresponse: {“error”:“maximum number of DatagramSockets reached”}
2020-07-23 11:42:02.770 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received: “maximum number of DatagramSockets reached”
2020-07-23 11:42:02.771 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Send command ‘{“id”:1770,“method”:“get_prop”,“params”:[“led”,“buzzer”,“f1_hour”,“f1_hour_used”,“use_time”]}’ → 192.XXX.XXX.XXX (Device: 03B4E9F7) gave error maximum number of DatagramSockets reached
2020-07-23 11:42:02.772 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 03B4E9F7 type: GET_PROPERTY, result: {}, fullresponse: {“error”:“maximum number of DatagramSockets reached”}
2020-07-23 11:42:02.772 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received: “maximum number of DatagramSockets reached”
2020-07-23 11:42:02.773 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Send command ‘{“id”:1771,“method”:“get_prop”,“params”:[“motor1_speed”,“filter1_life”,“favorite_level”,“temp_dec”,“purify_volume”]}’ → 192.XXX.XXX.XXX (Device: 03B4E9F7) gave error maximum number of DatagramSockets reached
2020-07-23 11:42:02.774 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 03B4E9F7 type: GET_PROPERTY, result: {}, fullresponse: {“error”:“maximum number of DatagramSockets reached”}
2020-07-23 11:42:02.775 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received: “maximum number of DatagramSockets reached”
2020-07-23 11:42:02.775 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Send command ‘{“id”:1772,“method”:“get_prop”,“params”:[“child_lock”]}’ → 192.XXX.XXX.XXX (Device: 03B4E9F7) gave error maximum number of DatagramSockets reached
2020-07-23 11:42:02.776 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 03B4E9F7 type: GET_PROPERTY, result: {}, fullresponse: {“error”:“maximum number of DatagramSockets reached”}
2020-07-23 11:42:02.777 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received: “maximum number of DatagramSockets reached”
2020-07-23 11:42:02.794 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Send command ‘{“id”:1743,“method”:“get_prop”,“params”:[“power”,“mode”,“humidity”,“aqi”,“average_aqi”]}’ → 192.XXX.XXX.XXX (Device: 033DE0FB) gave error maximum number of DatagramSockets reached
2020-07-23 11:42:02.794 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 033DE0FB type: GET_PROPERTY, result: {}, fullresponse: {“error”:“maximum number of DatagramSockets reached”}
2020-07-23 11:42:02.795 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received: “maximum number of DatagramSockets reached”
2020-07-23 11:42:02.796 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Send command ‘{“id”:1744,“method”:“get_prop”,“params”:[“led”,“buzzer”,“f1_hour”,“f1_hour_used”,“use_time”]}’ → 192.XXX.XXX.XXX (Device: 033DE0FB) gave error maximum number of DatagramSockets reached
2020-07-23 11:42:02.796 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 033DE0FB type: GET_PROPERTY, result: {}, fullresponse: {“error”:“maximum number of DatagramSockets reached”}
2020-07-23 11:42:02.797 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received: “maximum number of DatagramSockets reached”
2020-07-23 11:42:02.797 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Send command ‘{“id”:1745,“method”:“get_prop”,“params”:[“motor1_speed”,“filter1_life”,“favorite_level”,“temp_dec”,“purify_volume”]}’ → 192.XXX.XXX.XXX (Device: 033DE0FB) gave error maximum number of DatagramSockets reached
2020-07-23 11:42:02.798 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 033DE0FB type: GET_PROPERTY, result: {}, fullresponse: {“error”:“maximum number of DatagramSockets reached”}
2020-07-23 11:42:02.798 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received: “maximum number of DatagramSockets reached”
2020-07-23 11:42:02.799 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Send command ‘{“id”:1746,“method”:“get_prop”,“params”:[“child_lock”]}’ → 192.XXX.XXX.XXX (Device: 033DE0FB) gave error maximum number of DatagramSockets reached
2020-07-23 11:42:02.799 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 033DE0FB type: GET_PROPERTY, result: {}, fullresponse: {“error”:“maximum number of DatagramSockets reached”}
2020-07-23 11:42:02.800 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received: “maximum number of DatagramSockets reached”
2020-07-23 11:42:04.260 [DEBUG] [ernal.handler.MiIoUnsupportedHandler] - Periodic update for ‘miio:unsupported:036CE19F’ (miio:unsupported)
2020-07-23 11:42:04.261 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:384,“method”:“miIO.info”,“params”:} → 192.XXX.XXX.XXX (Device: 036CE19F token: 6E693533XXXXXXXXXXXXXXXX6C65696A Queue: 1)
2020-07-23 11:42:04.262 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Sending Ping 036CE19F (192.XXX.XXX.XXX)
2020-07-23 11:42:04.263 [DEBUG] [ernal.handler.MiIoUnsupportedHandler] - Periodic update for ‘miio:generic:036CE19F’ (miio:unsupported)
2020-07-23 11:42:04.264 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:384,“method”:“miIO.info”,“params”:} → 192.XXX.XXX.XXX (Device: 036CE19F token: ABC952BDXXXXXXXXXXXXXXXXFD35884B Queue: 1)
2020-07-23 11:42:04.264 [DEBUG] [internal.handler.MiIoAbstractHandler] - Command MIIO_INFO for miio:unsupported:036CE19F failed (type: miio:unsupported): maximum number of DatagramSockets reached
2020-07-23 11:42:04.265 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Sending Ping 036CE19F (192.XXX.XXX.XXX)
2020-07-23 11:42:04.265 [DEBUG] [internal.handler.MiIoAbstractHandler] - Command MIIO_INFO for miio:generic:036CE19F failed (type: miio:unsupported): maximum number of DatagramSockets reached
2020-07-23 11:42:04.331 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Send command ‘{“id”:384,“method”:“miIO.info”,“params”:}’ → 192.XXX.XXX.XXX (Device: 036CE19F) gave error maximum number of DatagramSockets reached
2020-07-23 11:42:04.331 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 036CE19F type: MIIO_INFO, result: {}, fullresponse: {“error”:“maximum number of DatagramSockets reached”}
2020-07-23 11:42:04.332 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received: “maximum number of DatagramSockets reached”
2020-07-23 11:42:04.332 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 036CE19F type: MIIO_INFO, result: {}, fullresponse: {“error”:“maximum number of DatagramSockets reached”}
2020-07-23 11:42:04.333 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received: “maximum number of DatagramSockets reached”
2020-07-23 11:42:10.356 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:1768,“method”:“app_stop”,“params”:} → 192.XXX.XXX.XXX (Device: 070A579C token: 49714B79XXXXXXXXXXXXXXXX66725130 Queue: 1)
2020-07-23 11:42:10.389 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Send command ‘{“id”:1768,“method”:“app_stop”,“params”:}’ → 192.XXX.XXX.XXX (Device: 070A579C) gave error maximum number of DatagramSockets reached
2020-07-23 11:42:10.389 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 070A579C type: STOP_VACUUM, result: {}, fullresponse: {“error”:“maximum number of DatagramSockets reached”}
2020-07-23 11:42:10.390 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received: “maximum number of DatagramSockets reached”
2020-07-23 11:42:11.356 [INFO ] [e.smarthome.model.script.DAILY-CHECK] - Sprawdzanie czy jakies urzadzenia sa wylaczone bądź nieaktywne
2020-07-23 11:42:11.359 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:1769,“method”:“app_charge”,“params”:} → 192.XXX.XXX.XXX (Device: 070A579C token: 49714B79XXXXXXXXXXXXXXXX66725130 Queue: 1)
2020-07-23 11:42:11.391 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Send command ‘{“id”:1769,“method”:“app_charge”,“params”:}’ → 192.XXX.XXX.XXX (Device: 070A579C) gave error maximum number of DatagramSockets reached
2020-07-23 11:42:11.393 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 070A579C type: CHARGE, result: {}, fullresponse: {“error”:“maximum number of DatagramSockets reached”}
2020-07-23 11:42:11.394 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received: “maximum number of DatagramSockets reached”
2020-07-23 11:42:13.763 [INFO ] [e.smarthome.model.script.DAILY-CHECK] - Brak urzadzen offline
2020-07-23 11:42:24.558 [DEBUG] [io.internal.handler.MiIoBasicHandler] - Periodic update for ‘miio:basic:033DE0FB’ (miio:basic)
2020-07-23 11:42:24.559 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:2072,“method”:“miIO.info”,“params”:} → 192.XXX.XXX.XXX (Device: 033DE0FB token: 164FE9FEXXXXXXXXXXXXXXXXDC5EA1A7 Queue: 1)
2020-07-23 11:42:24.560 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:2073,“method”:“get_prop”,“params”:[“power”,“mode”,“humidity”,“aqi”,“average_aqi”]} → 192.XXX.XXX.XXX (Device: 033DE0FB token: 164FE9FEXXXXXXXXXXXXXXXXDC5EA1A7 Queue: 2)
2020-07-23 11:42:24.561 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:2074,“method”:“get_prop”,“params”:[“led”,“buzzer”,“f1_hour”,“f1_hour_used”,“use_time”]} → 192.XXX.XXX.XXX (Device: 033DE0FB token: 164FE9FEXXXXXXXXXXXXXXXXDC5EA1A7 Queue: 3)
2020-07-23 11:42:24.561 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:2075,“method”:“get_prop”,“params”:[“motor1_speed”,“filter1_life”,“favorite_level”,“temp_dec”,“purify_volume”]} → 192.XXX.XXX.XXX (Device: 033DE0FB token: 164FE9FEXXXXXXXXXXXXXXXXDC5EA1A7 Queue: 4)
2020-07-23 11:42:24.562 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:2076,“method”:“get_prop”,“params”:[“child_lock”]} → 192.XXX.XXX.XXX (Device: 033DE0FB token: 164FE9FEXXXXXXXXXXXXXXXXDC5EA1A7 Queue: 5)
2020-07-23 11:42:24.562 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:2077,“method”:“miIO.info”,“params”:} → 192.XXX.XXX.XXX (Device: 033DE0FB token: 164FE9FEXXXXXXXXXXXXXXXXDC5EA1A7 Queue: 6)
2020-07-23 11:42:24.655 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Send command ‘{“id”:2072,“method”:“miIO.info”,“params”:}’ → 192.XXX.XXX.XXX (Device: 033DE0FB) gave error Given final block not properly padded. Such issues can arise if a bad key is used during decryption.
2020-07-23 11:42:24.656 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 033DE0FB type: MIIO_INFO, result: {}, fullresponse: {“error”:“Given final block not properly padded. Such issues can arise if a bad key is used during decryption.”}
2020-07-23 11:42:24.657 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received: “Given final block not properly padded. Such issues can arise if a bad key is used during decryption.”
2020-07-23 11:42:24.661 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Send command ‘{“id”:2073,“method”:“get_prop”,“params”:[“power”,“mode”,“humidity”,“aqi”,“average_aqi”]}’ → 192.XXX.XXX.XXX (Device: 033DE0FB) gave error Given final block not properly padded. Such issues can arise if a bad key is used during decryption.
2020-07-23 11:42:24.661 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 033DE0FB type: GET_PROPERTY, result: {}, fullresponse: {“error”:“Given final block not properly padded. Such issues can arise if a bad key is used during decryption.”}
2020-07-23 11:42:24.662 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received: “Given final block not properly padded. Such issues can arise if a bad key is used during decryption.”
2020-07-23 11:42:24.667 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Send command ‘{“id”:2074,“method”:“get_prop”,“params”:[“led”,“buzzer”,“f1_hour”,“f1_hour_used”,“use_time”]}’ → 192.XXX.XXX.XXX (Device: 033DE0FB) gave error Given final block not properly padded. Such issues can arise if a bad key is used during decryption.
2020-07-23 11:42:24.667 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 033DE0FB type: GET_PROPERTY, result: {}, fullresponse: {“error”:“Given final block not properly padded. Such issues can arise if a bad key is used during decryption.”}
2020-07-23 11:42:24.668 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received: “Given final block not properly padded. Such issues can arise if a bad key is used during decryption.”
2020-07-23 11:42:24.671 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Send command ‘{“id”:2075,“method”:“get_prop”,“params”:[“motor1_speed”,“filter1_life”,“favorite_level”,“temp_dec”,“purify_volume”]}’ → 192.XXX.XXX.XXX (Device: 033DE0FB) gave error Given final block not properly padded. Such issues can arise if a bad key is used during decryption.
2020-07-23 11:42:24.672 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 033DE0FB type: GET_PROPERTY, result: {}, fullresponse: {“error”:“Given final block not properly padded. Such issues can arise if a bad key is used during decryption.”}
2020-07-23 11:42:24.672 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received: “Given final block not properly padded. Such issues can arise if a bad key is used during decryption.”
2020-07-23 11:42:24.675 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Send command ‘{“id”:2076,“method”:“get_prop”,“params”:[“child_lock”]}’ → 192.XXX.XXX.XXX (Device: 033DE0FB) gave error Given final block not properly padded. Such issues can arise if a bad key is used during decryption.
2020-07-23 11:42:24.676 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 033DE0FB type: GET_PROPERTY, result: {}, fullresponse: {“error”:“Given final block not properly padded. Such issues can arise if a bad key is used during decryption.”}
2020-07-23 11:42:24.676 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received: “Given final block not properly padded. Such issues can arise if a bad key is used during decryption.”
2020-07-23 11:42:24.680 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Send command ‘{“id”:2077,“method”:“miIO.info”,“params”:}’ → 192.XXX.XXX.XXX (Device: 033DE0FB) gave error Given final block not properly padded. Such issues can arise if a bad key is used during decryption.
2020-07-23 11:42:24.680 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 033DE0FB type: MIIO_INFO, result: {}, fullresponse: {“error”:“Given final block not properly padded. Such issues can arise if a bad key is used during decryption.”}
2020-07-23 11:42:24.681 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received: “Given final block not properly padded. Such issues can arise if a bad key is used during decryption.”
2020-07-23 11:42:31.521 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:1770,“method”:“app_stop”,“params”:} → 192.XXX.XXX.XXX (Device: 070A579C token: 49714B79XXXXXXXXXXXXXXXX66725130 Queue: 1)
2020-07-23 11:42:31.621 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 070A579C type: STOP_VACUUM, result: [“ok”], fullresponse: {“result”:[“ok”],“id”:1770}
2020-07-23 11:42:32.522 [INFO ] [e.smarthome.model.script.DAILY-CHECK] - Sprawdzanie czy jakies urzadzenia sa wylaczone bądź nieaktywne
2020-07-23 11:42:32.525 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:1771,“method”:“app_charge”,“params”:} → 192.XXX.XXX.XXX (Device: 070A579C token: 49714B79XXXXXXXXXXXXXXXX66725130 Queue: 1)
2020-07-23 11:42:32.531 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 070A579C type: CHARGE, result: {}, fullresponse: {“error”:{“code”:-10003,“message”:“action locked”},“id”:1771}
2020-07-23 11:42:32.532 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received: {“code”:-10003,“message”:“action locked”}
2020-07-23 11:42:32.672 [DEBUG] [o.internal.handler.MiIoVacuumHandler] - Periodic update for ‘miio:vacuum:070A579C’ (miio:vacuum)
2020-07-23 11:42:32.672 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:1772,“method”:“get_dnd_timer”,“params”:} → 192.XXX.XXX.XXX (Device: 070A579C token: 49714B79XXXXXXXXXXXXXXXX66725130 Queue: 1)
2020-07-23 11:42:32.673 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:1773,“method”:“get_clean_summary”,“params”:} → 192.XXX.XXX.XXX (Device: 070A579C token: 49714B79XXXXXXXXXXXXXXXX66725130 Queue: 2)
2020-07-23 11:42:32.673 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:1774,“method”:“get_status”,“params”:} → 192.XXX.XXX.XXX (Device: 070A579C token: 49714B79XXXXXXXXXXXXXXXX66725130 Queue: 3)
2020-07-23 11:42:32.674 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:1775,“method”:“miIO.info”,“params”:} → 192.XXX.XXX.XXX (Device: 070A579C token: 49714B79XXXXXXXXXXXXXXXX66725130 Queue: 4)
2020-07-23 11:42:32.674 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:1776,“method”:“get_consumable”,“params”:} → 192.XXX.XXX.XXX (Device: 070A579C token: 49714B79XXXXXXXXXXXXXXXX66725130 Queue: 5)
2020-07-23 11:42:32.687 [DEBUG] [io.internal.handler.MiIoBasicHandler] - Periodic update for ‘miio:generic:03B4E9F7’ (miio:basic)
2020-07-23 11:42:32.687 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:1773,“method”:“get_prop”,“params”:[“power”,“mode”,“humidity”,“aqi”,“average_aqi”]} → 192.XXX.XXX.XXX (Device: 03B4E9F7 token: D1EACC72XXXXXXXXXXXXXXXX27844769 Queue: 1)
2020-07-23 11:42:32.688 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:1774,“method”:“get_prop”,“params”:[“led”,“buzzer”,“f1_hour”,“f1_hour_used”,“use_time”]} → 192.XXX.XXX.XXX (Device: 03B4E9F7 token: D1EACC72XXXXXXXXXXXXXXXX27844769 Queue: 2)
2020-07-23 11:42:32.688 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:1775,“method”:“get_prop”,“params”:[“motor1_speed”,“filter1_life”,“favorite_level”,“temp_dec”,“purify_volume”]} → 192.XXX.XXX.XXX (Device: 03B4E9F7 token: D1EACC72XXXXXXXXXXXXXXXX27844769 Queue: 3)
2020-07-23 11:42:32.689 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:1776,“method”:“get_prop”,“params”:[“child_lock”]} → 192.XXX.XXX.XXX (Device: 03B4E9F7 token: D1EACC72XXXXXXXXXXXXXXXX27844769 Queue: 4)
2020-07-23 11:42:32.689 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:1777,“method”:“miIO.info”,“params”:} → 192.XXX.XXX.XXX (Device: 03B4E9F7 token: D1EACC72XXXXXXXXXXXXXXXX27844769 Queue: 5)
2020-07-23 11:42:32.722 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 03B4E9F7 type: GET_PROPERTY, result: [“on”,“auto”,41,9,8], fullresponse: {“result”:[“on”,“auto”,41,9,8],“id”:1773}
2020-07-23 11:42:32.739 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 070A579C type: DND_GET, result: [{“start_hour”:20,“start_minute”:0,“end_hour”:8,“end_minute”:0,“enabled”:1}], fullresponse: {“result”:[{“start_hour”:20,“start_minute”:0,“end_hour”:8,“end_minute”:0,“enabled”:1}],“id”:1772}
2020-07-23 11:42:32.741 [DEBUG] [io.internal.handler.MiIoBasicHandler] - Periodic update for ‘miio:generic:033DE0FB’ (miio:basic)
2020-07-23 11:42:32.742 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:1747,“method”:“get_prop”,“params”:[“power”,“mode”,“humidity”,“aqi”,“average_aqi”]} → 192.XXX.XXX.XXX (Device: 033DE0FB token: 9EB8274EXXXXXXXXXXXXXXXX4D548F74 Queue: 1)
2020-07-23 11:42:32.743 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:1748,“method”:“get_prop”,“params”:[“led”,“buzzer”,“f1_hour”,“f1_hour_used”,“use_time”]} → 192.XXX.XXX.XXX (Device: 033DE0FB token: 9EB8274EXXXXXXXXXXXXXXXX4D548F74 Queue: 2)
2020-07-23 11:42:32.743 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:1749,“method”:“get_prop”,“params”:[“motor1_speed”,“filter1_life”,“favorite_level”,“temp_dec”,“purify_volume”]} → 192.XXX.XXX.XXX (Device: 033DE0FB token: 9EB8274EXXXXXXXXXXXXXXXX4D548F74 Queue: 3)
2020-07-23 11:42:32.744 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:1750,“method”:“get_prop”,“params”:[“child_lock”]} → 192.XXX.XXX.XXX (Device: 033DE0FB token: 9EB8274EXXXXXXXXXXXXXXXX4D548F74 Queue: 4)
2020-07-23 11:42:32.744 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:1751,“method”:“miIO.info”,“params”:} → 192.XXX.XXX.XXX (Device: 033DE0FB token: 9EB8274EXXXXXXXXXXXXXXXX4D548F74 Queue: 5)
2020-07-23 11:42:32.746 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 070A579C type: CLEAN_SUMMARY_GET, result: [306196,5035920000,313,[1595497284,1595497167,1595496994,1595496906,1595496841,1595496753,1595483834,1595416154,1595416133,1595416098,1595416075,1595416018,1595415987,1595415917,1595415316,1595415239,1595415138,1595415011,1595410996,1595410824]], fullresponse: {“result”:[306196,5035920000,313,[1595497284,1595497167,1595496994,1595496906,1595496841,1595496753,1595483834,1595416154,1595416133,1595416098,1595416075,1595416018,1595415987,1595415917,1595415316,1595415239,1595415138,1595415011,1595410996,1595410824]],“id”:1773}
2020-07-23 11:42:32.747 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:1777,“method”:“get_clean_record”,“params”:[1595497284]} → 192.XXX.XXX.XXX (Device: 070A579C token: 49714B79XXXXXXXXXXXXXXXX66725130 Queue: 4)
2020-07-23 11:42:32.751 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 070A579C type: GET_STATUS, result: [{“msg_ver”:3,“msg_seq”:1048,“state”:3,“battery”:96,“clean_time”:68,“clean_area”:1292500,“error_code”:0,“map_present”:1,“in_cleaning”:0,“in_returning”:0,“in_fresh_state”:1,“lab_status”:1,“water_box_status”:0,“fan_power”:103,“dnd_enabled”:0,“map_status”:3,“lock_status”:0}], fullresponse: {“result”:[{“msg_ver”:3,“msg_seq”:1048,“state”:3,“battery”:96,“clean_time”:68,“clean_area”:1292500,“error_code”:0,“map_present”:1,“in_cleaning”:0,“in_returning”:0,“in_fresh_state”:1,“lab_status”:1,“water_box_status”:0,“fan_power”:103,“dnd_enabled”:0,“map_status”:3,“lock_status”:0}],“id”:1774}
2020-07-23 11:42:32.761 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 03B4E9F7 type: GET_PROPERTY, result: [“off”,“off”,3500,1647,18374625], fullresponse: {“result”:[“off”,“off”,3500,1647,18374625],“id”:1774}
2020-07-23 11:42:32.762 [DEBUG] [io.internal.handler.MiIoBasicHandler] - Transformed with ‘SecondsToHours’: Filter Hours used 1647 → 0
2020-07-23 11:42:32.762 [DEBUG] [io.internal.handler.MiIoBasicHandler] - Transformed with ‘SecondsToHours’: Run Time 18374625 → 5104
2020-07-23 11:42:32.763 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 070A579C type: MIIO_INFO, result: {“hw_ver”:“Linux”,“fw_ver”:“3.5.7_002008”,“ap”:{“ssid”:“orzechszek2G”,“bssid”:“74:83:C2:91:3A:33”,“rssi”:-41},“netif”:{“localIp”:“192.XXX.XXX.XXX”,“mask”:“255.255.255.0”,“gw”:“192.XXX.XXX.XXX,“model”:“roborock.vacuum.s5”,“mac”:“40:31:3C:AD:00:21”,“token”:“49714b79474c75693362323066725130”,“life”:28902}, fullresponse: {“partner_id”:”",“id”:1775,“code”:0,“message”:“ok”,“result”:{“hw_ver”:“Linux”,“fw_ver”:“3.5.7_002008”,“ap”:{“ssid”:“orzechszek2G”,“bssid”:“74:83:C2:91:3A:33”,“rssi”:-41},“netif”:{“localIp”:“192.XXX.XXX.XXX”,“mask”:“255.255.255.0”,“gw”:"192.XXX.XXX.XXX,“model”:“roborock.vacuum.s5”,“mac”:“40:31:3C:AD:00:21”,“token”:“49714b79474c75693362323066725130”,“life”:28902}}
2020-07-23 11:42:32.773 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 03B4E9F7 type: GET_PROPERTY, result: [352,52,8,255,204030], fullresponse: {“result”:[352,52,8,255,204030],“id”:1775}
2020-07-23 11:42:32.774 [DEBUG] [io.internal.handler.MiIoBasicHandler] - Transformed with ‘/10’: Temperature 255 → 25.5
2020-07-23 11:42:32.801 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 070A579C type: CONSUMABLES_GET, result: [{“main_brush_work_time”:306513,“side_brush_work_time”:306513,“filter_work_time”:306513,“filter_element_work_time”:0,“sensor_dirty_time”:2113}], fullresponse: {“result”:[{“main_brush_work_time”:306513,“side_brush_work_time”:306513,“filter_work_time”:306513,“filter_element_work_time”:0,“sensor_dirty_time”:2113}],“id”:1776}
2020-07-23 11:42:32.809 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 070A579C type: CLEAN_RECORD_GET, result: [[1595497284,1595497352,68,1292500,0,0,2,1]], fullresponse: {“result”:[[1595497284,1595497352,68,1292500,0,0,2,1]],“id”:1777}
2020-07-23 11:42:32.845 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 033DE0FB type: GET_PROPERTY, result: [“off”,“idle”,44,10,8], fullresponse: {“result”:[“off”,“idle”,44,10,8],“id”:1747}
2020-07-23 11:42:32.849 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 033DE0FB type: GET_PROPERTY, result: [“off”,“off”,3500,3375,12103853], fullresponse: {“result”:[“off”,“off”,3500,3375,12103853],“id”:1748}
2020-07-23 11:42:32.850 [DEBUG] [io.internal.handler.MiIoBasicHandler] - Transformed with ‘SecondsToHours’: Filter Hours used 3375 → 0
2020-07-23 11:42:32.850 [DEBUG] [io.internal.handler.MiIoBasicHandler] - Transformed with ‘SecondsToHours’: Run Time 12103853 → 3362
2020-07-23 11:42:32.854 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 033DE0FB type: GET_PROPERTY, result: [0,3,10,254,130032], fullresponse: {“result”:[0,3,10,254,130032],“id”:1749}
2020-07-23 11:42:32.855 [DEBUG] [io.internal.handler.MiIoBasicHandler] - Transformed with ‘/10’: Temperature 254 → 25.4
2020-07-23 11:42:32.861 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 033DE0FB type: GET_PROPERTY, result: [“off”], fullresponse: {“result”:[“off”],“id”:1750}
2020-07-23 11:42:32.866 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 033DE0FB type: MIIO_INFO, result: {“life”:135456,“cfg_time”:0,“token”:“9eb8274e5747e911c877c4de4d548f74”,“mac”:“28:6C:07:B9:62:70”,“fw_ver”:“1.4.3_100”,“hw_ver”:“MC200”,“model”:“zhimi.airpurifier.m1”,“wifi_fw_ver”:“SD878x-14.76.36.p79-702.1.0-WM”,“ap”:{“rssi”:-43,“ssid”:“orzechszek2G”,“bssid”:“74:83:C2:91:3A:33”},“netif”:{“localIp”:“192.XXX.XXX.XXX”,“mask”:“255.255.255.0”,“gw”:“192.XXX.XXX.XXX"gw_mac”:“00:01:2E:83:CA:9C”},“mmfree”:55768,“ot”:“otu”,“otu_stat”:[261,261,7607,14,6850,683],“ott_stat”:[19,0,2974,190]}, fullresponse: {“result”:{“life”:135456,“cfg_time”:0,“token”:“9eb8274e5747e911c877c4de4d548f74”,“mac”:“28:6C:07:B9:62:70”,“fw_ver”:“1.4.3_100”,“hw_ver”:“MC200”,“model”:“zhimi.airpurifier.m1”,“wifi_fw_ver”:“SD878x-14.76.36.p79-702.1.0-WM”,“ap”:{“rssi”:-43,“ssid”:“orzechszek2G”,“bssid”:“74:83:C2:91:3A:33”},“netif”:{“localIp”:“192.XXX.XXX.XXX”,“mask”:“255.255.255.0”,“gw”:“192.XXX.XXX.XXX"gw_mac”:“00:01:2E:83:CA:9C”},“mmfree”:55768,“ot”:“otu”,“otu_stat”:[261,261,7607,14,6850,683],“ott_stat”:[19,0,2974,190]},“id”:1751}
2020-07-23 11:42:34.265 [DEBUG] [ernal.handler.MiIoUnsupportedHandler] - Periodic update for ‘miio:unsupported:036CE19F’ (miio:unsupported)
2020-07-23 11:42:34.266 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:385,“method”:“miIO.info”,“params”:} → 192.XXX.XXX.XXX (Device: 036CE19F token: 6E693533XXXXXXXXXXXXXXXX6C65696A Queue: 1)
2020-07-23 11:42:34.267 [DEBUG] [ernal.handler.MiIoUnsupportedHandler] - Periodic update for ‘miio:generic:036CE19F’ (miio:unsupported)
2020-07-23 11:42:34.267 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Sending Ping 036CE19F (192.XXX.XXX.XXX)
2020-07-23 11:42:34.268 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:385,“method”:“miIO.info”,“params”:} → 192.XXX.XXX.XXX (Device: 036CE19F token: ABC952BDXXXXXXXXXXXXXXXXFD35884B Queue: 1)
2020-07-23 11:42:34.268 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Sending Ping 036CE19F (192.XXX.XXX.XXX)
2020-07-23 11:42:34.271 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Ping 036CE19F (192.XXX.XXX.XXX) success
2020-07-23 11:42:34.293 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Send command ‘{“id”:385,“method”:“miIO.info”,“params”:}’ → 192.XXX.XXX.XXX (Device: 036CE19F) gave error Given final block not properly padded. Such issues can arise if a bad key is used during decryption.
2020-07-23 11:42:34.294 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Send command ‘{“id”:385,“method”:“miIO.info”,“params”:}’ → 192.XXX.XXX.XXX (Device: 036CE19F) gave error Given final block not properly padded. Such issues can arise if a bad key is used during decryption.
2020-07-23 11:42:34.294 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 036CE19F type: MIIO_INFO, result: {}, fullresponse: {“error”:“Given final block not properly padded. Such issues can arise if a bad key is used during decryption.”}
2020-07-23 11:42:34.295 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received: “Given final block not properly padded. Such issues can arise if a bad key is used during decryption.”
2020-07-23 11:42:34.981 [INFO ] [e.smarthome.model.script.DAILY-CHECK] - Brak urzadzen offline
2020-07-23 11:42:40.802 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:1778,“method”:“app_stop”,“params”:} → 192.XXX.XXX.XXX (Device: 070A579C token: 49714B79XXXXXXXXXXXXXXXX66725130 Queue: 1)
2020-07-23 11:42:40.822 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 070A579C type: STOP_VACUUM, result: [“ok”], fullresponse: {“result”:[“ok”],“id”:1778}
2020-07-23 11:42:41.801 [INFO ] [e.smarthome.model.script.DAILY-CHECK] - Sprawdzanie czy jakies urzadzenia sa wylaczone bądź nieaktywne
2020-07-23 11:42:41.804 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:1779,“method”:“app_charge”,“params”:} → 192.XXX.XXX.XXX (Device: 070A579C token: 49714B79XXXXXXXXXXXXXXXX66725130 Queue: 1)
2020-07-23 11:42:42.453 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 070A579C type: CHARGE, result: [“ok”], fullresponse: {“result”:[“ok”],“id”:1779}
2020-07-23 11:42:42.785 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Communication error for Mi device at 192.XXX.XXX.XXX: Receive timed out
2020-07-23 11:42:42.785 [DEBUG] [nal.transport.MiIoAsyncCommunication] - No response from device 03B4E9F7 at 192.XXX.XXX.XXX for command {“id”:1776,“method”:“get_prop”,“params”:[“child_lock”]}.
2020-07-23 11:42:42.786 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 03B4E9F7 type: GET_PROPERTY, result: {}, fullresponse: {“error”:“No Response”}
2020-07-23 11:42:42.787 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received: “No Response”
2020-07-23 11:42:43.193 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 03B4E9F7 type: MIIO_INFO, result: {“life”:135822,“cfg_time”:0,“token”:“d1eacc72f17e934327cbea4027844769”,“mac”:“34:CE:00:B8:90:3F”,“fw_ver”:“1.4.3_105”,“hw_ver”:“MW300”,“model”:“zhimi.airpurifier.m2”,“wifi_fw_ver”:“SD878x-14.76.36.p84-702.1.0-WM”,“ap”:{“rssi”:-63,“ssid”:“orzechszek2G”,“bssid”:“74:83:C2:91:3A:33”},“netif”:{“localIp”:“192.XXX.XXX.XXX”,“mask”:“255.255.255.0”,“gw”:“192.XXX.XXX.XXX"gw_mac”:“00:01:2E:83:CA:9C”},“mmfree”:238964,“ot”:“otu”,“otu_stat”:[309,275,2003,7,1867,153],“ott_stat”:[3,0,175,198]}, fullresponse: {“result”:{“life”:135822,“cfg_time”:0,“token”:“d1eacc72f17e934327cbea4027844769”,“mac”:“34:CE:00:B8:90:3F”,“fw_ver”:“1.4.3_105”,“hw_ver”:“MW300”,“model”:“zhimi.airpurifier.m2”,“wifi_fw_ver”:“SD878x-14.76.36.p84-702.1.0-WM”,“ap”:{“rssi”:-63,“ssid”:“orzechszek2G”,“bssid”:“74:83:C2:91:3A:33”},“netif”:{“localIp”:“192.XXX.XXX.XXX”,“mask”:“255.255.255.0”,“gw”:“192.XXX.XXX.XXX"gw_mac”:“00:01:2E:83:CA:9C”},“mmfree”:238964,“ot”:“otu”,“otu_stat”:[309,275,2003,7,1867,153],“ott_stat”:[3,0,175,198]},“id”:1777}
2020-07-23 11:42:44.217 [INFO ] [e.smarthome.model.script.DAILY-CHECK] - Brak urzadzen offline
2020-07-23 11:42:54.563 [DEBUG] [io.internal.handler.MiIoBasicHandler] - Periodic update for ‘miio:basic:033DE0FB’ (miio:basic)
2020-07-23 11:42:54.564 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:2078,“method”:“miIO.info”,“params”:} → 192.XXX.XXX.XXX (Device: 033DE0FB token: 164FE9FEXXXXXXXXXXXXXXXXDC5EA1A7 Queue: 1)
2020-07-23 11:42:54.565 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:2079,“method”:“get_prop”,“params”:[“power”,“mode”,“humidity”,“aqi”,“average_aqi”]} → 192.XXX.XXX.XXX (Device: 033DE0FB token: 164FE9FEXXXXXXXXXXXXXXXXDC5EA1A7 Queue: 2)
2020-07-23 11:42:54.566 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:2080,“method”:“get_prop”,“params”:[“led”,“buzzer”,“f1_hour”,“f1_hour_used”,“use_time”]} → 192.XXX.XXX.XXX (Device: 033DE0FB token: 164FE9FEXXXXXXXXXXXXXXXXDC5EA1A7 Queue: 3)
2020-07-23 11:42:54.566 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:2081,“method”:“get_prop”,“params”:[“motor1_speed”,“filter1_life”,“favorite_level”,“temp_dec”,“purify_volume”]} → 192.XXX.XXX.XXX (Device: 033DE0FB token: 164FE9FEXXXXXXXXXXXXXXXXDC5EA1A7 Queue: 4)
2020-07-23 11:42:54.567 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:2082,“method”:“get_prop”,“params”:[“child_lock”]} → 192.XXX.XXX.XXX (Device: 033DE0FB token: 164FE9FEXXXXXXXXXXXXXXXXDC5EA1A7 Queue: 5)
2020-07-23 11:42:54.567 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {“id”:2083,“method”:“miIO.info”,“params”:} → 192.XXX.XXX.XXX (Device: 033DE0FB token: 164FE9FEXXXXXXXXXXXXXXXXDC5EA1A7 Queue: 6)
2020-07-23 11:42:54.619 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Send command ‘{“id”:2078,“method”:“miIO.info”,“params”:}’ → 192.XXX.XXX.XXX (Device: 033DE0FB) gave error Given final block not properly padded. Such issues can arise if a bad key is used during decryption.
2020-07-23 11:42:54.620 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 033DE0FB type: MIIO_INFO, result: {}, fullresponse: {“error”:“Given final block not properly padded. Such issues can arise if a bad key is used during decryption.”}
2020-07-23 11:42:54.621 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received: “Given final block not properly padded. Such issues can arise if a bad key is used during decryption.”
2020-07-23 11:42:54.624 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Send command ‘{“id”:2079,“method”:“get_prop”,“params”:[“power”,“mode”,“humidity”,“aqi”,“average_aqi”]}’ → 192.XXX.XXX.XXXXX (Device: 033DE0FB) gave error Given final block not properly padded. Such issues can arise if a bad key is used during decryption.
2020-07-23 11:42:54.625 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 033DE0FB type: GET_PROPERTY, result: {}, fullresponse: {“error”:“Given final block not properly padded. Such issues can arise if a bad key is used during decryption.”}
2020-07-23 11:42:54.625 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received: “Given final block not properly padded. Such issues can arise if a bad key is used during decryption.”
2020-07-23 11:42:54.629 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Send command ‘{“id”:2080,“method”:“get_prop”,“params”:[“led”,“buzzer”,“f1_hour”,“f1_hour_used”,“use_time”]}’ → 192.XXX.XXX.XXX (Device: 033DE0FB) gave error Given final block not properly padded. Such issues can arise if a bad key is used during decryption.
2020-07-23 11:42:54.629 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 033DE0FB type: GET_PROPERTY, result: {}, fullresponse: {“error”:“Given final block not properly padded. Such issues can arise if a bad key is used during decryption.”}
2020-07-23 11:42:54.630 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received: “Given final block not properly padded. Such issues can arise if a bad key is used during decryption.”
2020-07-23 11:42:54.630 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Send command ‘{“id”:2081,“method”:“get_prop”,“params”:[“motor1_speed”,“filter1_life”,“favorite_level”,“temp_dec”,“purify_volume”]}’ → 192.XXX.XXX.XXX (Device: 033DE0FB) gave error maximum number of DatagramSockets reached
2020-07-23 11:42:54.631 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 033DE0FB type: GET_PROPERTY, result: {}, fullresponse: {“error”:“maximum number of DatagramSockets reached”}
2020-07-23 11:42:54.631 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received: “maximum number of DatagramSockets reached”
2020-07-23 11:42:54.631 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Send command ‘{“id”:2082,“method”:“get_prop”,“params”:[“child_lock”]}’ → 192.XXX.XXX.XXX (Device: 033DE0FB) gave error maximum number of DatagramSockets reached
2020-07-23 11:42:54.632 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received: “maximum number of DatagramSockets reached”
2020-07-23 11:42:54.632 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Send command ‘{“id”:2083,“method”:“miIO.info”,“params”:}’ → 192.XXX.XXX.XXX (Device: 033DE0FB) gave error maximum number of DatagramSockets reached
2020-07-23 11:42:54.633 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 033DE0FB type: MIIO_INFO, result: {}, fullresponse: {“error”:“maximum number of DatagramSockets reached”}
2020-07-23 11:42:54.633 [DEBUG] [internal.handler.MiIoAbstractHandler] - Error received: “maximum number of DatagramSockets reached”
