I am following the instructions here
“Enter the previously noted developer key in openHAB Paper UI -> Configuration -> Things -> Xiaomi Gateway -> Edit -> Developer Key. Save (This is required if you want to be able to send controls to the devices like the light of the gateway)”
The gateway got detected. I can select and edit it. But I don’t see an option for “Developer Key”. I have one for “Token” but it has to be in hex and the developer key is not hex. Are these the same thing.
Also status of the hub says “UNINITIALIZED - HANDLER_CONFIGURATION_PENDING”
Saleem
