So my Xiaomi Gateway always show’s offline.
This what I’ve done:
enabled Developer Mode MiHome App
enabled LAN mode
extract the Token or “Password”
added the Token to the PaperUI Thing
added the Bridge to the other PaperUI Xiaomi Gateway
since I made an Update to the 2.3.0-1 (Realease Build) of OpenHAB the Gateway and all my other Sensors show offline and I cant interact with them. (Except for the Yeelights but they work with another Binding and it’s token)
Is there a way to implement these with the new OH version?
They look like this, but they didn’t before the OH 2.3.1 Update.
So I assume the channels I’m using (which are shown in PaperUI) aren’t valid.
Any Solution here?
Yes, could be a problem if the AP blocks the multicast packets running on 224.0.0.50:9898.
You can sniff your internet using a tcp dumb. Fritzbox: http://your-fritz-IP/html/capture.html
You can see all network packets beeing send and received on all network interfaces
Open them e.g. with wireshark
But at first we need to see your created .items and .things file for all xiaomi smarthome devices
