Xiaomi Vacuum command rule not working since 3.0.2 update
Hello!
I’ve had a rule setup on my OH3 for many months now that starts my Xiaomi Vacuum robot at 16h everyday if it didn’t already clean that day. But since I upgraded from OH3.0.1 to OH3.0.2, it doesn’t work anymore and I don’t understand why.
My rule is pretty straightforward:
rule "Vacuum"
        Time cron "0 0 16 ? * *"
        logInfo("VacuumRule", "Periodic");
        val startOfDay = LocalDate.now().atStartOfDay(ZoneOffset.systemDefault()).toEpochSecond();
        val lastCleaning = DateTimeType.valueOf(vac_lastStart.state.toString).getZonedDateTime().toEpochSecond();
        logInfo("VacuumRule", lastCleaning + " < " + startOfDay);
        if (lastCleaning < startOfDay) {
                logInfo("VacuumRule", "Go!");
                sendCommand(vac_actionControl, "vacuum")
        } else {
                logInfo("VacuumRule", "No Go!");
If I look at my logs of today (all day the same) I see:
2021-04-25 16:00:00.192 [INFO ] [openhab.core.model.script.VacuumRule] - Periodic
2021-04-25 16:00:00.205 [INFO ] [openhab.core.model.script.VacuumRule] - 1619274377 < 1619301600
2021-04-25 16:00:00.206 [INFO ] [openhab.core.model.script.VacuumRule] - Go
And in the events:
2021-04-25 16:00:00.209 [INFO ] [openhab.event.ItemCommandEvent      ] - Item 'vac_actionControl' received command vacuum
2021-04-25 16:00:00.210 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'vac_actionControl' predicted to become vacuum
2021-04-25 16:00:00.211 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'vac_actionControl' changed from dock to vacuum
2021-04-25 16:00:15.254 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'vac_actionControl' changed from vacuum to dock
For some reason, everytime the rule sends the vacuum command, it switches back to “dock” after 15s without having the robot starting at all.
When I re-run the rule manually, it seems to work first try
2021-04-25 17:04:47.316 [INFO ] [openhab.core.model.script.VacuumRule] - Periodic
2021-04-25 17:04:47.328 [INFO ] [openhab.core.model.script.VacuumRule] - 1619274377 < 1619301600
2021-04-25 17:04:47.329 [INFO ] [openhab.core.model.script.VacuumRule] - Go!
2021-04-25 17:04:47.331 [INFO ] [openhab.event.ItemCommandEvent      ] - Item 'vac_actionControl' received command vacuum
2021-04-25 17:04:47.334 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'vac_actionControl' predicted to become vacuum
2021-04-25 17:04:47.337 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'vac_actionControl' changed from dock to vacuum
# After I press pause on the robot:
2021-04-25 17:05:22.694 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'vac_actionControl' changed from vacuum to dock
Any idea what might be the issue here?
Also, can I safely downgrade from 3.0.2 to 3.0.1 to try if it really is the update that broke everything down, or will it mess up something?
Thanks!
the switching back means that indeed the robot did not really start. The next refresh of the data will than ‘refresh it back’ to the state it actually is.
You pob need to enable debugging to see why the robot is not responding to the vacuum command. (first test: try starting the vacuum from the UI actually still works)
Note, there is nothing noteworthy (if anything) changed in the binding between 3.01 and 3.02… I somewhat expect downgrading won’t help
