Dear all,
When my water leak sensor triggers an alarm the Xiaomi Gateway itself makes noise and flashes red. How can one cancel this - besides powering off?
Selter
Dear all,
Selter
I guess you did configure that in your Xiaomi app???
Or you have a rule causing this?
In deed - it seems that there is an default option within the Xiaomi App. One can confirm the alert by pressing the button on the gateway.
But is there a way to confirm the alert with a switch (rule) in openhab?
When I press the gateway’s button there is no log in the OH logfile
Looks like there is no channel available for that:
I would set the OFF command to a shorter delay to avoid that problem at all:
https://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/493
