Xiaomi Zigbee power plug is ready only
Hi team,
Need your help!
I’ve recently added Xiaomi Zigbee Plug to my collection of Xiaomi devices.
It works great, can read the power load and consumption, updates the status of the switch but I cannot control the device from OpenHAB.
Is there anything that I’ve done wrong in the config?
Items:
Switch 		Mi_Plug_1_Switch 		"Media Centre Switch [%s]"				<switch> 			{ channel="mihome:sensor_plug:158d0001ded347:power" }
Switch 		Mi_Plug_1_Active 		"Media Centre Active [%s]"			   	<switch> 			{ channel="mihome:sensor_plug:158d0001ded347:inUse" }
Number 		Mi_Plug_1_Power 		"Power Load [%.1f W]"					<energy> 			{ channel="mihome:sensor_plug:158d0001ded347:loadPower" }
Number 		Mi_Plug_1_Consumption	"Power Cunsumed [%.1f kWh]"				<line-incline> 		{ channel="mihome:sensor_plug:158d0001ded347:powerConsumed" }
Sitemap:
		Switch item=Mi_Plug_1_Switch
		Switch item=Mi_Plug_1_Active
		Text item=Mi_Plug_1_Power
		Text item=Mi_Plug_1_Consumption
Logs:
2017-10-27 15:58:00.559 [ItemStateChangedEvent     ] - Mi_Plug_1_Power changed from 46.65 to 46.21
2017-10-27 16:11:24.570 [ItemStateChangedEvent     ] - Mi_Plug_1_Consumption changed from 18.536 to 18.563
2017-10-27 16:11:24.571 [ItemStateChangedEvent     ] - Mi_Plug_1_Power changed from 46.21 to 46.65
2017-10-27 16:45:23.496 [ItemStateChangedEvent     ] - Mi_Plug_1_Power changed from 46.65 to 46.21
2017-10-27 16:45:23.497 [ItemStateChangedEvent     ] - Mi_Plug_1_Consumption changed from 18.563 to 18.591
2017-10-27 16:50:44.487 [ItemStateChangedEvent     ] - Mi_Plug_1_Power changed from 46.21 to 46.65
2017-10-27 16:58:27.481 [ItemStateChangedEvent     ] - Mi_Plug_1_Power changed from 46.65 to 46.21
2017-10-27 17:05:46.469 [ItemStateChangedEvent     ] - Mi_Plug_1_Power changed from 46.21 to 46.65
2017-10-27 17:16:21.455 [ItemStateChangedEvent     ] - Mi_Plug_1_Consumption changed from 18.591 to 18.617
2017-10-27 17:17:44.448 [ItemCommandEvent          ] - Item 'Mi_Plug_1_Switch' received command OFF
2017-10-27 17:17:44.458 [ItemStateChangedEvent     ] - Mi_Plug_1_Switch changed from ON to OFF
2017-10-27 17:17:46.100 [ItemCommandEvent          ] - Item 'Mi_Plug_1_Active' received command OFF
2017-10-27 17:17:46.102 [ItemStateChangedEvent     ] - Mi_Plug_1_Active changed from ON to OFF
2017-10-27 17:17:47.575 [ItemCommandEvent          ] - Item 'Mi_Plug_1_Switch' received command ON
Screenshot from Paper UI (I’ve added things via it):
Going through a similar issue here, with a very similar setup.
I’m on Windows 10, OH 2.1, jre1.8.0_152
However, I get the following error when triggering (only) the Xiaomi Zigbee Plug ON or OFF :
2017-11-14 01:35:13.344 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occurred while calling handler: java.lang.NullPointerException
java.util.concurrent.ExecutionException: java.lang.NullPointerException
	at org.eclipse.smarthome.core.common.SafeMethodCaller.executeDirectly(SafeMethodCaller.java:220)[98:org.eclipse.smarthome.core:0.9.0.b5]
	at org.eclipse.smarthome.core.common.SafeMethodCaller.callAsynchronous(SafeMethodCaller.java:189)[98:org.eclipse.smarthome.core:0.9.0.b5]
	at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:83)[98:org.eclipse.smarthome.core:0.9.0.b5]
	at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:67)[98:org.eclipse.smarthome.core:0.9.0.b5]
	at org.eclipse.smarthome.core.thing.internal.ThingManager.receiveCommand(ThingManager.java:374)[105:org.eclipse.smarthome.core.thing:0.9.0.b5]
	at org.eclipse.smarthome.core.items.events.AbstractItemEventSubscriber.receive(AbstractItemEventSubscriber.java:47)[98:org.eclipse.smarthome.core:0.9.0.b5]
	at org.eclipse.smarthome.core.internal.events.OSGiEventManager$1.call(OSGiEventManager.java:192)[98:org.eclipse.smarthome.core:0.9.0.b5]
	at org.eclipse.smarthome.core.internal.events.OSGiEventManager$1.call(OSGiEventManager.java:1)[98:org.eclipse.smarthome.core:0.9.0.b5]
	at org.eclipse.smarthome.core.common.SafeMethodCaller$CallableWrapper.call(SafeMethodCaller.java:181)[98:org.eclipse.smarthome.core:0.9.0.b5]
	at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_152]
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)[:1.8.0_152]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)[:1.8.0_152]
	at java.lang.Thread.run(Thread.java:748)[:1.8.0_152]
Caused by: java.lang.NullPointerException
	at org.openhab.binding.mihome.handler.XiaomiBridgeHandler.toJsonValue(XiaomiBridgeHandler.java:319)[187:org.openhab.binding.mihome:2.1.0]
	at org.openhab.binding.mihome.handler.XiaomiBridgeHandler.sendCommandToBridge(XiaomiBridgeHandler.java:257)[187:org.openhab.binding.mihome:2.1.0]
	at org.openhab.binding.mihome.handler.XiaomiBridgeHandler.sendCommandToBridge(XiaomiBridgeHandler.java:239)[187:org.openhab.binding.mihome:2.1.0]
	at org.openhab.binding.mihome.handler.XiaomiBridgeHandler.writeToDevice(XiaomiBridgeHandler.java:266)[187:org.openhab.binding.mihome:2.1.0]
	at org.openhab.binding.mihome.handler.XiaomiActorPlugHandler.execute(XiaomiActorPlugHandler.java:42)[187:org.openhab.binding.mihome:2.1.0]
	at org.openhab.binding.mihome.handler.XiaomiDeviceBaseHandler.handleCommand(XiaomiDeviceBaseHandler.java:97)[187:org.openhab.binding.mihome:2.1.0]
	at org.eclipse.smarthome.core.thing.internal.ThingManager$4.call(ThingManager.java:377)[105:org.eclipse.smarthome.core.thing:0.9.0.b5]
	at org.eclipse.smarthome.core.thing.internal.ThingManager$4.call(ThingManager.java:1)[105:org.eclipse.smarthome.core.thing:0.9.0.b5]
	at org.eclipse.smarthome.core.common.SafeMethodCaller.executeDirectly(SafeMethodCaller.java:218)[98:org.eclipse.smarthome.core:0.9.0.b5]
	... 12 more
2017-11-14 01:35:23.849 [INFO ] [.smarthome.model.script.Yeelink Bulb] - LR Light is:100
2017-11-14 01:35:27.009 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occurred while calling handler: java.lang.NullPointerException
	... 12 more
My Gateway, Door sensor, Yeelight and Wireless Controller all work fine, otherwise.
I’m on Ubuntu but found the same problem in 2.1.0.
The 2.2 snapshot versions however works.
I use a small lxd container running 2.2 for testing and to run things that don’t work properly in 2.1.
I have configured it to use mqtt to trigger my plugs through that.
Not ideal but the work-around works.
As you say the rest appears to work, including reading the status and power info from the plugs.
I recently switched to the Xiaomi Smart Home binding’s 2.2.0 SNAPSHOT (found on this post) and it’s working fine now; for anyone else that comes across this.
Hi Aaron
what else did u change i just updated and changed to that 2.2.0 SNAPSHOT, and im still having the same problem cant send command to the plug. But its able to read all the information abt it
I can confirm that switching to the latest binding fixed that issue for me.
hi @sasha_jpr,
please, may you confirm that the above reported positive result is made with the xiaomi mi smart zigbee plug connected to the zigbee binding and not to zigbee2mqtt?
I am planning to buy the above mentioned plug and use it with the zigbee binding
thanks
Is there any update on this? I have same issue using MQTT binding.
More details here: https://community.openhab.org/t/openhab-and-zigbee2mqtt/101939/14?u=leshqo
