And this is when I toggle from Route Standard to Route Fast:
2025-04-22 12:01:17.274 [DEBUG] [o.internal.handler.MiIoVacuumHandler] - Periodic update for 'miio:vacuum:9e0ad94358' (miio:vacuum)
2025-04-22 12:01:17.314 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 9e0ad94358 type: DND_GET, result: [{"start_hour":22,"start_minute":0,"end_hour":8,"end_minute":0,"enabled":1,"actions":{"resume":1,"vol":1,"led":1,"dust":1,"dry":0}}], fullresponse: {"id":71,"result":[{"start_hour":22,"start_minute":0,"end_hour":8,"end_minute":0,"enabled":1,"actions":{"resume":1,"vol":1,"led":1,"dust":1,"dry":0}}],"exe_time":10}
2025-04-22 12:01:17.335 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 9e0ad94358 type: CLEAN_SUMMARY_GET, result: {"clean_time":97480,"clean_area":1163680000,"clean_count":88,"dust_collection_count":0,"records":[1745255269,1745169053,1745166772,1745166250,1745158070,1745154814,1745147893,1745142900,1745141235,1745082342,1745076514,1745074480,1745051766,1744995626,1744909625,1744822315,1744737191,1744651445,1744650046,1744650027]}, fullresponse: {"id":72,"result":{"clean_time":97480,"clean_area":1163680000,"clean_count":88,"dust_collection_count":0,"records":[1745255269,1745169053,1745166772,1745166250,1745158070,1745154814,1745147893,1745142900,1745141235,1745082342,1745076514,1745074480,1745051766,1744995626,1744909625,1744822315,1744737191,1744651445,1744650046,1744650027]},"exe_time":10}
2025-04-22 12:01:17.357 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 9e0ad94358 type: GET_STATUS, result: [{"msg_ver":2,"msg_seq":1422,"state":8,"battery":100,"clean_time":551,"clean_area":4805000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":104,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"distance_off":60,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":1,"is_exploring":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":0,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":15,"mop_mode":300,"debug_mode":0,"in_warmup":0,"collision_avoid_status":1,"switch_map_mode":1,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0,"clean_percent":0,"rss":2,"dss":0,"common_status":0}], fullresponse: {"id":73,"result":[{"msg_ver":2,"msg_seq":1422,"state":8,"battery":100,"clean_time":551,"clean_area":4805000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":104,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"distance_off":60,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":1,"is_exploring":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":0,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":15,"mop_mode":300,"debug_mode":0,"in_warmup":0,"collision_avoid_status":1,"switch_map_mode":1,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0,"clean_percent":0,"rss":2,"dss":0,"common_status":0}],"exe_time":10}
2025-04-22 12:01:17.398 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 9e0ad94358 type: CONSUMABLES_GET, result: [{"main_brush_work_time":97859,"side_brush_work_time":97859,"filter_work_time":97859,"filter_element_work_time":0,"sensor_dirty_time":97480,"dust_collection_work_times":0}], fullresponse: {"id":74,"result":[{"main_brush_work_time":97859,"side_brush_work_time":97859,"filter_work_time":97859,"filter_element_work_time":0,"sensor_dirty_time":97480,"dust_collection_work_times":0}],"exe_time":11}
2025-04-22 12:01:17.420 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 9e0ad94358 type: GET_ROOM_MAPPING, result: [[16,"95001098433",6],[17,"95001098432",8],[18,"95001098435",14],[19,"95001098440",13],[20,"95001098437",15],[21,"95001098436",8],[23,"95001098434",13]], fullresponse: {"id":75,"result":[[16,"95001098433",6],[17,"95001098432",8],[18,"95001098435",14],[19,"95001098440",13],[20,"95001098437",15],[21,"95001098436",8],[23,"95001098434",13]],"exe_time":11}
2025-04-22 12:01:47.278 [DEBUG] [o.internal.handler.MiIoVacuumHandler] - Periodic update for 'miio:vacuum:9e0ad94358' (miio:vacuum)
2025-04-22 12:01:47.379 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 9e0ad94358 type: DND_GET, result: [{"start_hour":22,"start_minute":0,"end_hour":8,"end_minute":0,"enabled":1,"actions":{"resume":1,"vol":1,"led":1,"dust":1,"dry":0}}], fullresponse: {"id":76,"result":[{"start_hour":22,"start_minute":0,"end_hour":8,"end_minute":0,"enabled":1,"actions":{"resume":1,"vol":1,"led":1,"dust":1,"dry":0}}],"exe_time":11}
2025-04-22 12:01:47.421 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 9e0ad94358 type: CLEAN_SUMMARY_GET, result: {"clean_time":97480,"clean_area":1163680000,"clean_count":88,"dust_collection_count":0,"records":[1745255269,1745169053,1745166772,1745166250,1745158070,1745154814,1745147893,1745142900,1745141235,1745082342,1745076514,1745074480,1745051766,1744995626,1744909625,1744822315,1744737191,1744651445,1744650046,1744650027]}, fullresponse: {"id":77,"result":{"clean_time":97480,"clean_area":1163680000,"clean_count":88,"dust_collection_count":0,"records":[1745255269,1745169053,1745166772,1745166250,1745158070,1745154814,1745147893,1745142900,1745141235,1745082342,1745076514,1745074480,1745051766,1744995626,1744909625,1744822315,1744737191,1744651445,1744650046,1744650027]},"exe_time":11}
2025-04-22 12:01:47.443 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 9e0ad94358 type: GET_STATUS, result: [{"msg_ver":2,"msg_seq":1438,"state":8,"battery":100,"clean_time":551,"clean_area":4805000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":104,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"distance_off":60,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":1,"is_exploring":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":0,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":15,"mop_mode":304,"debug_mode":0,"in_warmup":0,"collision_avoid_status":1,"switch_map_mode":1,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0,"clean_percent":0,"rss":2,"dss":0,"common_status":0}], fullresponse: {"id":78,"result":[{"msg_ver":2,"msg_seq":1438,"state":8,"battery":100,"clean_time":551,"clean_area":4805000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":104,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"distance_off":60,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":1,"is_exploring":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":0,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":15,"mop_mode":304,"debug_mode":0,"in_warmup":0,"collision_avoid_status":1,"switch_map_mode":1,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0,"clean_percent":0,"rss":2,"dss":0,"common_status":0}],"exe_time":11}
2025-04-22 12:01:47.456 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 9e0ad94358 type: MIIO_INFO, result: {"life":27830,"model":"roborock.vacuum.a73","token":"555179444c57483468616c34454a4e64","ipflag":1,"miio_ver":"0.1.0","uid":1809013495,"uptime":29623,"mac":"B0:4A:39:A4:66:77","fw_ver":"4.3.9_0760","hw_ver":"Linux","miio_client_ver":"4.3.9","VmPeak":11284,"VmSize":9560,"VmRSS":2092,"MemFree":13928,"ap":{"ssid":"OhWehLAN","bssid":"88:c3:97:c5:dc:d5","rssi":"-57","freq":0},"netif":{"localIp":"192.168.3.50","mask":"255.255.255.0","gw":"192.168.3.1"},"miio_times":[27830,44,36,27749]}, fullresponse: {"id":79,"result":{"life":27830,"model":"roborock.vacuum.a73","token":"555179444c57483468616c34454a4e64","ipflag":1,"miio_ver":"0.1.0","uid":1809013495,"uptime":29623,"mac":"B0:4A:39:A4:66:77","fw_ver":"4.3.9_0760","hw_ver":"Linux","miio_client_ver":"4.3.9","VmPeak":11284,"VmSize":9560,"VmRSS":2092,"MemFree":13928,"ap":{"ssid":"OhWehLAN","bssid":"88:c3:97:c5:dc:d5","rssi":"-57","freq":0},"netif":{"localIp":"192.168.3.50","mask":"255.255.255.0","gw":"192.168.3.1"},"miio_times":[27830,44,36,27749]},"exe_time":2}
2025-04-22 12:01:47.476 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 9e0ad94358 type: CONSUMABLES_GET, result: [{"main_brush_work_time":97859,"side_brush_work_time":97859,"filter_work_time":97859,"filter_element_work_time":0,"sensor_dirty_time":97480,"dust_collection_work_times":0}], fullresponse: {"id":80,"result":[{"main_brush_work_time":97859,"side_brush_work_time":97859,"filter_work_time":97859,"filter_element_work_time":0,"sensor_dirty_time":97480,"dust_collection_work_times":0}],"exe_time":11}
2025-04-22 12:01:47.503 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 9e0ad94358 type: GET_ROOM_MAPPING, result: [[16,"95001098433",6],[17,"95001098432",8],[18,"95001098435",14],[19,"95001098440",13],[20,"95001098437",15],[21,"95001098436",8],[23,"95001098434",13]], fullresponse: {"id":81,"result":[[16,"95001098433",6],[17,"95001098432",8],[18,"95001098435",14],[19,"95001098440",13],[20,"95001098437",15],[21,"95001098436",8],[23,"95001098434",13]],"exe_time":11}
