My POPP Smoke Detector worked fine in openHAB2 until last week (zwave OH2 binding from around 20161106).
This weekend I updated the binding twice, since then the device is shown as “unknown”, currently on 2.0.0.201611122320
Error message:
2016-11-13 18:54:48.233 [WARN ] [ig.xml.osgi.XmlDocumentBundleTracker] - The XML document '/ESH-INF/thing/popp_004407_1_0.xml' in module 'org.openhab.binding.zwave' could not be parsed: : ParseError at [row,col]:[61,37]
Message: Auf "&" in der Entityreferenz muss umgehend der Entityname folgen. : : ParseError at [row,col]:[61,37]
---- Debugging information ----
message : : ParseError at [row,col]:[61,37]
cause-exception : com.thoughtworks.xstream.io.StreamException
cause-message : : ParseError at [row,col]:[61,37]
class : org.eclipse.smarthome.config.xml.util.NodeValue
required-type : org.eclipse.smarthome.config.xml.util.NodeValue
converter-type : org.eclipse.smarthome.config.xml.util.NodeValueConverter
path : /thing-descriptions/thing-type/properties/property
line number : 61
class[1] : java.util.ArrayList
converter-type[1] : com.thoughtworks.xstream.converters.collections.CollectionConverter
class[2] : org.eclipse.smarthome.config.xml.util.NodeList
converter-type[2] : org.eclipse.smarthome.config.xml.util.NodeListConverter
class[3] : org.eclipse.smarthome.core.thing.xml.internal.ThingTypeXmlResult
converter-type[3] : org.eclipse.smarthome.core.thing.xml.internal.ThingTypeConverter
class[4] : org.eclipse.smarthome.core.thing.xml.internal.ThingDescriptionList
converter-type[4] : org.eclipse.smarthome.core.thing.xml.internal.ThingDescriptionConverter
version : 1.4.7
I deleted the xml, reinitialized (xml was newly created) and even excluded and included the device and as a last step inserted a new battery, still it does not work.
Any ideas?
