i am looking for a solution to load data from an RSS feed into a text item.
Is this something that someone had implemented already?
thx
Karsten
thx
Karsten
i am a bit further down the road so far - tried to create an XSLT for reading the following UR:
http://www.deutschlandradio.de/verkehrsmeldungen.438.de.rss
XSLT:
<?xml version="1.0"?>
<xsl:stylesheet xmlns:xsl="http://www.w3.org/1999/XSL/Transform" version="2.0">
<xsl:output indent="yes" method="xml" encoding="UTF-8" omit-xml-declaration="yes" />
<xsl:template match="/">
<xsl:for-each select="rss/channel/item/titel">
<xsl:if test="A81 Stuttgart Richtung Singen">
<xsl:value-of select="description"/>
</xsl:if>
</xsl:for-each>
</xsl:template>
</xsl:stylesheet>
Item declaration:
String VerkehrA81 “Verkehr A81” { http="<[travel:50000:XSLT(verkehr.xsl)]" }
but ending up in error messages in OH:
2015-10-06 12:42:59.889 [ERROR] [.i.s.XsltTransformationService] - transformation throws exception
javax.xml.transform.TransformerConfigurationException: file:/opt/openhab/configurations/transform/verkehr.xsl: line 8: Erforderliches Attribut "test" fehlt.
at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerFactoryImpl.newTemplates(TransformerFactoryImpl.java:994) ~[na:1.8.0]
at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerFactoryImpl.newTransformer(TransformerFactoryImpl.java:766) ~[na:1.8.0]
at org.openhab.core.transform.internal.service.XsltTransformationService.transform(XsltTransformationService.java:82) ~[na:na]
at org.openhab.binding.http.internal.HttpBinding.execute(HttpBinding.java:179) [bundlefile:na]
at org.openhab.core.binding.AbstractActiveBinding$BindingActiveService.execute(AbstractActiveBinding.java:156) [org.openhab.core_1.7.0.jar:na]
at org.openhab.core.service.AbstractActiveService$RefreshThread.run(AbstractActiveService.java:173) [org.openhab.core_1.7.0.jar:na]
2015-10-06 12:42:59.901 [ERROR] [.o.b.http.internal.HttpBinding] - transformation throws exception [transformation=XSLT(verkehr.xsl), response=<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0">
<channel>
<title xmlns:func="http://exslt.org/functions">Deutschlandradio - Verkehrsmeldungen</title>
<link xmlns:func="http://exslt.org/functions">http://www.deutschlandradio.de/</link>
<description xmlns:func="http://exslt.org/functions">Aktuelle Verkehrsmeldungen</description>
<category xmlns:func="http://exslt.org/functions">Info</category>
<language>de-DE</language>
<copyright>Deutschlandradio - dradio.de</copyright>
<pubDate>Tue, 06 Oct 2015 12:42:59 +0200</pubDate>
<lastBuildDate>Tue, 06 Oct 2015 12:42:59 +0200</lastBuildDate>
<image>
<url>http://www.deutschlandradio.de/themes/dradio/img/dradio-de-logo-neutral.gif</url>
<title>Deutschlandradio Logo</title>
<link>http://www.deutschlandradio.de/</link>
<description>Feed provided by Deutschlandradio. Click to visit.</description>
</image>
<item xmlns:func="http://exslt.org/functions">
<title>A8 Karlsruhe Richtung Stuttgart</title>
<description>A8 Karlsruhe Richtung Stuttgart zwischen Dreieck Karlsruhe und Karlsbad Wanderbaustelle, die linke Spur ist gesperrt.</description>
</item>
<description>A8 Karlsruhe Richtung Stuttgart zwischen Karlsbad und Pforzheim-West Wanderbaustelle, die linke Spur ist gesperrt.</description>
</item>
<title>A81 Stuttgart Richtung Singen</title>
<description>A8 Stuttgart Richtung Karlsruhe zwischen Heimsheim und Pforzheim-Nord 10 km stockender Verkehr.</description>
</item>
<title>A8 Stuttgart Richtung Karlsruhe</title>
<description>A8 Stuttgart Richtung Karlsruhe zwischen Pforzheim-West und Karlsbad Wanderbaustelle, die linke Spur ist gesperrt.</description>
</item>
</channel>
</rss>
org.openhab.core.transform.TransformationException: transformation throws exception
at org.openhab.core.transform.internal.service.XsltTransformationService.transform(XsltTransformationService.java:86) ~[na:na]
at org.openhab.binding.http.internal.HttpBinding.execute(HttpBinding.java:179) ~[na:na]
Caused by: javax.xml.transform.TransformerConfigurationException: file:/opt/openhab/configurations/transform/verkehr.xsl: line 8: Erforderliches Attribut "test" fehlt.
... 3 common frames omitted
any idea/ assistance?
thx
There may be other issues but in the feed URI:
titel
-> title
There is an openHAB 2 binding that already support RSS. If you are still interested, take a look at this https://github.com/openhab/openhab2-addons/issues/724.
try
<xsl:stylesheet xmlns:xsl="http://www.w3.org/1999/XSL/Transform" version="1.0">
<xsl:output indent="no" method="text" encoding="UTF-8" standalone="yes" omit-xml-declaration="yes"/>
<xsl:if test="/rss/channel/item[contains(title,'A81 Stuttgart Richtung Singen')]">
<xsl:value-of select="(//rss/channel/item/description)"/>
</xsl:if>
</xsl:template>
</xsl:stylesheet>
One more issue on a HTTP binding on RSS feed.
The Value(Ill moyenne - Lauch : Vert) does not appear on sitemap log info is OK !
What’s wrong ?
2016-10-21 10:06:26.342 [INFO ] [runtime.busevents ] - Vigicrue state updated to Ill moyenne - Lauch : Vert
Here my item and sitemap
String Vigicrue "Vigicrue" { http="<[http://www.vigicrues.gouv.fr/rss/?CdEntVigiCru=SA5:5000:XSLT(vigicrue.xsl)]" }
Text item=Vigicrue
and here the vigicrue.xsl file
<xsl:stylesheet
<xsl:value-of select="(//rss/channel/item/title)"/>
</xsl:template>
</xsl:stylesheet>
and finaly the RSS file
<rss version="2.0" xmlns:atom="http://www.w3.org/2005/Atom">
<channel>
<title>Vigicrues : Tronçon(s) de cours d'eau en vigilance crues</title>
<link>http://www.vigicrues.gouv.fr</link>
<atom:link href="http://www.vigicrues.gouv.fr/rss/index.php" rel="self" type="application/rss+xml" />
<description>MEEM/DGPR/SRNH/SCHAPI-SPC : Carte de vigilance crues</description>
<docs>http://www.vigicrues.gouv.fr/faq.php?rub=19#q_51</docs>
<category>vigilance crues</category>
<language>fr-fr</language>
<image>
<url>http://www.vigicrues.gouv.fr/ftp/cruemax.png</url>
</image>
<pubDate>Thu, 20 Oct 2016 15:50:00 +0200</pubDate>
<lastBuildDate>Thu, 20 Oct 2016 15:50:00 +0200</lastBuildDate>
<ttl>15</ttl>
<item>
<title>Ill moyenne - Lauch : Vert</title>
<link>http://www.vigicrues.gouv.fr/niveau2.php?CdEntVigiCru=3#bul_spc</link>
<description>
<p>Actualisation du site Vigicrues le <i><b>jeudi 20 octobre 2016 à 15h50</b>.</i></p>
<p>Nom du tronçon : <b>Ill moyenne - Lauch</b> (SA5)
<br />Couleur de vigilance crues du tronçon : <b>Vert</b>
<br/>Nom du SPC : Rhin-Sarre</p>
<p>Tenez vous régulièrement informé de la situation.
<br />Abonnez vous à ce flux ou consultez le site <a href="http://www.vigicrues.gouv.fr" target="_blank">Vigicrues</a>.
<br />Pour plus d'informations sur le fil RSS, cliquez <a href="http://www.vigicrues.gouv.fr/rss.php" target="_blank">ici</a>.<br /></p>
</description>
<comments>http://www.vigicrues.gouv.fr/niveau2.php?CdEntVigiCru=3#SA5</comments>
<guid>http://www.vigicrues.gouv.fr/niveau2.php?CdEntVigiCru=3#SA5</guid>
</item>
</channel>
</rss>
what line are you trying to get back?
Im trying to catch the content in rss/channel/item/title in the RSS file ->
I suspect wrong output parameters in the vigicrue.xsl file ??
I’ve taken another look in the code. The http binding work well on Vigicrue item
(see --> 2016-10-21 10:06:26.342 [INFO ] [runtime.busevents ] - Vigicrue state updated to Ill moyenne - Lauch : Vert).
Sorry for this question but is there a good reason why the sitemap (Text item=Vigicrue) doesn’t display the String ?
you might just need to add the [%s] to the item description
String Vigicrue "Vigicrue [%s]" { http="<[http://www.vigicrues.gouv.fr/rss/?CdEntVigiCru=SA5:5000:XSLT(vigicrue.xsl)]" }
OK 'works fine !
Sorry for this question…
