I use the XMPP- Actions- but now I have a configurations problem.
Ive installed (2.5.0) the XMPP Client Binding- I need it to do command with xmpp- ervery time I get the java error, tls handshake. I think its ok, because in the XMPP Client Binding I cant set up secure connection or anything else for tls.
I read a lot, but I find no solution for it.
So I think, Ive to transform the binding, like the actions, for secure connection-- but how?
Thanks at all
Use the console and see if you have all of these installed:
210 β Active β 80 β 4.3.3 β smack-core
211 β Active β 80 β 4.3.3 β smack-extensions
212 β Active β 80 β 4.3.3 β smack-im
213 β Active β 80 β 4.3.3 β smack-tcp
214 β Active β 80 β 0.6.3 β jxmpp-core
215 β Active β 80 β 0.6.3 β jxmpp-jid
216 β Active β 80 β 0.6.3 β jxmpp-util-cache
217 β Active β 80 β 0.3.3 β minidns-core
218 β Active β 80 β 2.5.0.201904131627 β openHAB Add-ons :: Bundles :: XMPPClient Binding
219 β Active β 80 β 1.1.4 β XPP3 Library
220 β Active β 80 β 4.3.3 β smack-java7
221 β Active β 80 β 4.3.3 β smack-resolver-javax
Bundles you may be missing:
smack-java7
Per github here: https://github.com/openhab/openhab-addons/issues/5473
Perfekt, I will check this soon, thanks!
The same error, smack.tcp- but I have got all bundles
[hingStatusInfoChangedEvent] - βxmppclient:xmppBridge:e9b8451cβ changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): No response received within reply timeout. Timeout was 5000ms (~5s). While waiting for establishing TLS
$JAVA_HOME/bin/java SSLPoke XXXXX.de XXXX
Successfully connected
Now i worked with java- Firewall still open- no handshake.
