Greetings from a new Openhab user!
I started playing with OpenHab a few days ago and it’s been going very well! I got a few zwave light switches and sensors working fine but I’m having some issues with this Yale216 lock for monitoring the lock state and get the lock/unlock notifications.
It’s associated fine. I’m able to lock/unlock remotely, update the configurations options and set remote codes but it only created one channel ‘door_lock’. It’s my understanding from other users posts that I should have an ‘alarm_raw’ channel that I can monitor but it wasn’t added from the Paper UI.
I have a recent snapshot running. It seems I can’t attached an XML document as I’m a new user. The XML generated for my thing is available here: https://drive.google.com/file/d/1fGs0H1OGyrJSpF4M0sK6-H14nr3Q0nwR/view?usp=sharing
openhab> bundle:list | grep ZWave
231 | Active | 80 | 2.5.0.201910171234 | openHAB Add-ons :: Bundles :: ZWave Binding
I can see the lock sending notifications in the zwave logs:
2019-10-17 11:52:24.085 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 20: resetResendCount initComplete=true isDead=false
2019-10-17 11:52:24.086 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 20: Decapsulating COMMAND_CLASS_SECURITY
2019-10-17 11:52:24.090 [DEBUG] [mmandclass.ZWaveSecurityCommandClass] - NODE 20: SECURITY_RXD 71 05 09 02 00 FF 06 0B 00 00
2019-10-17 11:52:24.091 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 20: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2019-10-17 11:52:24.093 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 20: Received COMMAND_CLASS_ALARM V4 NOTIFICATION_REPORT
2019-10-17 11:52:24.095 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 20: NOTIFICATION report - 9 = 2, event=11, status=255, plen=0
2019-10-17 11:52:24.097 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 20: Alarm Type = ACCESS_CONTROL (9)
2019-10-17 11:52:24.098 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 20: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2019-10-17 11:52:24.100 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 20: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ALARM, value=255
2019-10-17 11:52:24.103 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 20: Commands processed 1.
2019-10-17 11:52:24.105 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 20: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@a69f4.
Thank you!
