The latest Yamaha binding does not support Spotify input.
Certain newer models (RX-S601D) allow to stream directly from Spotify. You use the Spotify app to send a playlist to the device. Once the playlist is selected, by using the Yamaha remote or Spotify app one can:
- play/pause/stop
- next, previous
- see the song title displayed on receiver
- see the song cover image displayed on the Spotify mobile app.
With the current version of Yamaha binding, there is no support to achieve the above.
I have looked at the code and some minor changes would be required to support this:
- Enable Spotify as a known input for playback.
- Few changes:
- make the next track command send
Skip Fwd - make the prev track command send
Skip Rev - adjust the element name for song name to
Trackelement - make the
playback_stationchannel be empty, as Spotify does not support this - expose new
playback_song_image_urlchannel of type String that will be the URL to an image provided by the AVR
Here is some protocol level examples for Spotify:
I will make an contribution, unless someone is working on that already?
What do you think?
CC: @David_Graeff
