is it possible to extend the 2.2 Yamaha Receiver binding with a channel for choosing the HDMI-Output (1, 2, 1+2, none/off)?
There are two reasons for that request:
The receiver is not capable to send the HDMI-signal on both outputs to TV-set and beamer simultaneously. The beamer is connected via a 10m long cable, it only works if set the output only to it.
When i switch off my “stoneage”-TV-set, because i want to hear music, the red HDMI-Indicator starts flashing. Thats annoing! Therefor i have to switch off both HDMI-Outputs.
I don’t have an receiver with 2 hdmi outputs, but maybe you can get a workaround with the http binding for now,
to change the inputs from your sitemap or per rule.
The RX-V781 should work with the JSON API and the outputs should be settable.
