http://my-local-server-ip:8080/habpanel gives me:
Connection lost! Trying to reconnect…
This is a fresh Ubuntu 20.04 LTS desktop install on VMware workstation pro 16 without any modifications other than installing open-vm-tools and a change in hostname
Here are all the commands i used to install OH3 and Mosquitto
sudo apt-get install mosquitto mosquitto-clients
sudo service mosquitto restart
sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys 0xB1998361219BD9C9
wget https://cdn.azul.com/zulu/bin/zulu-repo_1.0.0-2_all.deb
sudo apt-get install ./zulu-repo_1.0.0-2_all.deb
sudo apt update
sudo apt-get install zulu11-jdk
wget -qO - 'https://bintray.com/user/downloadSubjectPublicKey?username=openhab' | sudo apt-key add -
sudo apt-get install apt-transport-https
echo 'deb https://dl.bintray.com/openhab/apt-repo2 stable main' | sudo tee /etc/apt/sources.list.d/openhab.list
sudo apt update
sudo apt-get install openhab
sudo systemctl daemon-reload
sudo systemctl enable openhab.service
sudo systemctl start openhab.service
sudo systemctl status openhab.service
openhab-cli info
Then i visited the openhab http://my-local-server-ip:8080/ just setup my location and did NOT install any bindings.
Here are all the contents of /var/log/openhab.log
homeserver:/var/log/openhab$ cat openhab.log 2020-12-31 22:43:16.687 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Intentionally Deleted'. 2020-12-31 22:43:16.697 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to 'Intentionally Deleted'. 2020-12-31 22:43:16.698 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'en_US'. 2020-12-31 22:43:20.873 [INFO ] [.core.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007 2020-12-31 22:43:21.149 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://192.168.1.200:8080/rest/addons's Observer 2020-12-31 22:43:21.807 [INFO ] [org.openhab.ui.internal.UIService ] - Started UI on port 8080 2020-12-31 22:43:22.093 [INFO ] [ab.ui.habpanel.internal.HABPanelTile] - Started HABPanel at /habpanel 2020-12-31 22:43:26.845 [INFO ] [e.automation.internal.RuleEngineImpl] - Rule engine started.
Note: I Tried the installation using openhabian at first and it gave me the same issue.
I can’t even find anything in the log to guide me where to look. The only WARN in the logs above is due to the browser trying to contact openhab during restart when it was not yet ready.
Can you please assist? All the other threads spoke about binding issues, and / or map transformation issues, etc… but I have 0 bindings and 0 map transformations listed in those sections
