This is my first time doing so, if there is anything else I need to do please let me know. @chris is this available immediately or do I need to wait for a snapshot release to use the device? Thanks!
This link says there are configuration parameters. Under “Management” is listed the official instructions for inclusion & exclusion too. Command classes are there too, I believe.
I am just learning too, & learning how to research this stuff.
Thank you for trying.
You shouldn’t change the command classes. I assume they were generated by uploading the XML, so they will be correct. The channels may (or not) need to be edited, but as a starting point they should be ok.
The device can be added, but it fails to add via secure inclusion and does not allow me to toggle the lock or update user codes. @chris Maybe something got updated in the configuration that is causing this? It was working fine with the xml I added manually a few weeks ago.
