Does anyone know if the CENTRAL_SCENE support is in 1.9 or was it just in 2.0?
Cheers
Cheers
Itâs included in 1.9.
Cheers Chris,
Wanted a ZRC-90 for a while so been waiting for this
Gonna have to update to OpenHab 2.0 one of these days though
Hi Chris,
One final question, does the 1.9 version support the key press stuff and is the binding done in the same way?
scene.key ?
Now youâre asking the tough questions. I think the answer is yes, and no⊠I think it supports the keypress, but itâs done differently. In OH2 I put the keypress as a âdecimalâ where the implementation on OH1 (from memory) was to multiply by 10 or something, and then put the key⊠I would suggest to set up an item and a sitemap so you can see what values are being set with the different key/pressesâŠ
If you get stuck let me know and I can look through the code.
So just as an example if the scene was 4 and the key was 1 it would be 401?
Yes - something like that. It might be 41 - I forget - but thatâs the principal anywayâŠ
Cheers Chris, you are a legend
Hi
I would be really great full if you could please add an example how an item could look like.
I have bought a fibaro âThe buttonâ that also uses Central_scene and i have a hard time to understand how to use it. I would like to for example trigger rules and toggle a switch but i donât know how to do it.
/Fredrik
See the link below for a rule -:
The item configuration should simply include command=CENTRAL_SCENE
Thanks⊠looks like the example i need⊠i will look into itâŠ
Hi
I have tried it now and it almost worked, thanks but the problem is that i always get the value 1 from the item, its like the Number item does not get the decimal number only integer. The effect is that no matter what i press i get 1 as the result and triggers the â1x logâ.
I copied your rule in the example to try it out and the item looks like this:
Number SchTest âMushroomâ (Control_Items) {zwave=â14:command=CENTRAL_SCENEâ}
Do i need to do anything else have i made any mistake?
I too have the exact same problem.
It seems to be impossible to read out the number of presses, I run the latest 1.9 build of z-wave binding. The thing is that I think that both me and the others who seem to have the same problem seems to run openhab 1.8.3.
My item looks like this:
Number SchTest âMushroomâ {zwave=â22:command=CENTRAL_SCENEâ }
I try running the same rule you recommended an other user:
rule "Mushroom Pushing"
Item SchTest received update
if (SchTest.state == 1.0) {
logInfo(âTestâ, âMushroom 1x pushedâ)
if (SchTest.state == 1.1) {
logInfo(âTestâ, âMushroom leave aloneâ)
if (SchTest.state == 1.2) {
logInfo(âTestâ, âMushroom kept inâ)
if (SchTest.state == 1.3) {
logInfo(âTestâ, âMushroom 2x pushedâ)
if (SchTest.state == 1.4) {
logInfo(âTestâ, âMushroom 3x pushedâ)
if (SchTest.state == 1.5) {
logInfo(âTestâ, âMushroom 4x pushedâ)
if (SchTest.state == 1.6) {
logInfo(âTestâ, âMushroom 5x pushedâ)
Am I doing something wrong? Or will it not work with openhab 1.x?
Forgot to write that I always get 1 and come to âMushroom 1x pushedâ, but when I look in the logs when not having a correct item defined I can see that the key sent varies see part of log below:
2016-12-30 18:46:32.644 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 22: No item bound for event, endpoint = 0, command class = CENTRAL_SCENE, value = {key=131, scene=1}, ignoring.
2016-12-30 18:46:43.894 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 22: No item bound for event, endpoint = 0, command class = CENTRAL_SCENE, value = {key=132, scene=1}, ignoring.
2016-12-30 18:46:52.119 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 22: No item bound for event, endpoint = 0, command class = CENTRAL_SCENE, value = {key=132, scene=1}, ignoring.
2016-12-30 18:46:58.033 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 22: No item bound for event, endpoint = 0, command class = CENTRAL_SCENE, value = {key=133, scene=1}, ignoring.
I have the exact same problem, did you ever solve it?
I guess upgrading to openhab 2 would work, but thats not an option for meâŠ
Sincerely Johan
No I donât have any solution. I think itâs a must to upgrade to openhab 2 soon, I got into trubbel with some other fibaro device also and to me it looks like itâs only going to be solved in 2.0.
The upgrade is going to take time but after I think things will get better.
Hello there,
I had the same issue with my Fibaro Button (not able to properly capture numbers of clicks) under openHAB 1.8.
I solved it using following trick: https://github.com/openhab/openhab1-addons/pull/4431 (thanks @savageautomate).
My items file looks as this:
/* Fibaro Button */
Number fibaro_button_scene "Fibaro Button Scene" {zwave="7:command=central_scene"}
Number fibaro_button_scene_1 "Fibaro Button Scene 1x" {zwave="7:command=central_scene,scene=1,key=128"}
Number fibaro_button_scene_released "Fibaro Button Scene Released" {zwave="7:command=central_scene,scene=1,key=129"}
Number fibaro_button_scene_hold "Fibaro Button Scene Hold" {zwave="7:command=central_scene,scene=1,key=130"}
Number fibaro_button_scene_2 "Fibaro Button Scene 2x" {zwave="7:command=central_scene,scene=1,key=131"}
Number fibaro_button_battery "Fibaro Button Battery" <battery> {zwave="7:command=battery"}
Hope it helps.
Bye
