- Platform information:
- Hardware: Raspberrypi PI2 B, with Aoetech Gen5 z-wave stick.
- OS: Raspbian
- Java Runtime Environment: zulu8
- openHAB version: 2.5
- Issue of the topic:
I could successfully configuring and geting values from 3 of 4 senors of Abus Multisensor SHBW10000. Only the motion PIR sensor doesn’t show any reaction on motion. The association group is “Controller”, the Door-Item is set with channel type “alarm_buglar” (also i tried Motion-Item). Sensitivity was leaved at default 10. Setting 14 and 15 is default, too.
I also create a testrule with an item trigger:
rule “test1”
Item ZWaveNode002SHBW10000PIRMultisensor_AlarmBurglar received update
if ( ZWaveNode002SHBW10000PIRMultisensor_AlarmBurglar.state == ON ) {
ZWaveNode003TZ68WallPlug_Switch.sendCommand(“ON”)
} else {
ZWaveNode003TZ68WallPlug_Switch.sendCommand(“OFF”)
No reaction at all. - If logs where generated please post these here using code fences:
I’ve enabled TRACE log level for zwave-bindung class. It seems that the channel was correct initialized.
Here is the log:
05:31:37.521 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - lastTransaction null 05:31:37.527 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 2: Application Command Request (ALIVE:DYNAMIC_VALUES) 05:31:37.532 [DEBUG] [ing.zwave.internal.protocol.ZWaveNode] - NODE 2: Incoming command class COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint 0 05:31:37.538 [DEBUG] [ing.zwave.internal.protocol.ZWaveNode] - NODE 2: SECURITY NOT required on COMMAND_CLASS_SENSOR_MULTILEVEL 05:31:37.542 [DEBUG] [otocol.commandclass.ZWaveCommandClass] - NODE 2: Received COMMAND_CLASS_SENSOR_MULTILEVEL V5 SENSOR_MULTILEVEL_REPORT 05:31:37.549 [DEBUG] [ass.ZWaveMultiLevelSensorCommandClass] - NODE 2: Sensor Type = RelativeHumidity(5), Scale = 0 05:31:37.553 [DEBUG] [ass.ZWaveMultiLevelSensorCommandClass] - NODE 2: Sensor Value = 5E+1 05:31:37.558 [TRACE] [ave.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMultiLevelSensorValueEvent 05:31:37.563 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent 05:31:37.568 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 2: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SENSOR_MULTILEVEL, value=5E+1 05:31:37.575 [TRACE] [nding.zwave.handler.ZWaveThingHandler] - NODE 2: Checking channel=zwave:device:c8a57e4f:node2:sensor_binary, cmdClass=COMMAND_CLASS_SENSOR_BINARY, endpoint=0 05:31:37.583 [TRACE] [nding.zwave.handler.ZWaveThingHandler] - NODE 2: Checking channel=zwave:device:c8a57e4f:node2:sensor_luminance, cmdClass=COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint=0 05:31:37.588 [TRACE] [nding.zwave.handler.ZWaveThingHandler] - NODE 2: Checking channel=zwave:device:c8a57e4f:node2:sensor_relhumidity, cmdClass=COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint=0 05:31:37.595 [DEBUG] [verter.ZWaveMultiLevelSensorConverter] - NODE 2: Sensor conversion not performed for RELATIVE_HUMIDITY. 05:31:37.602 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 2: Updating channel state zwave:device:c8a57e4f:node2:sensor_relhumidity to 50 [DecimalType] 05:31:37.608 [TRACE] [nding.zwave.handler.ZWaveThingHandler] - NODE 2: Checking channel=zwave:device:c8a57e4f:node2:sensor_temperature, cmdClass=COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint=0 05:31:37.616 [TRACE] [nding.zwave.handler.ZWaveThingHandler] - NODE 2: Checking channel=zwave:device:c8a57e4f:node2:alarm_burglar, cmdClass=COMMAND_CLASS_ALARM, endpoint=0 05:31:37.620 [TRACE] [nding.zwave.handler.ZWaveThingHandler] - NODE 2: Checking channel=zwave:device:c8a57e4f:node2:battery-level, cmdClass=COMMAND_CLASS_BATTERY, endpoint=0 05:31:37.624 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 2: Commands processed 1. 05:31:37.629 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 2: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@4af653. 05:31:37.633 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0 05:31:37.637 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0 05:31:37.642 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty 05:31:37.645 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false. 05:31:37.649 [TRACE] [ing.zwave.internal.protocol.ZWaveNode] - NODE 2: listening == false, frequentlyListening == false, awake == false 05:31:37.653 [TRACE] [rnal.protocol.ZWaveTransactionManager] - NODE 2: Node not awake! 05:31:37.657 [TRACE] [rnal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage nothing
Any ideas are very welcome. The sensor was already changed. Thank you!
Peter
