The Aeotec wallswipe can connect to Aeotec nano devices, allowing it to control the device. This also presents additional configuration to the nano devices. I currently have a wallswipe connected to a nano dimmer and have manually updated the nano dimmer xml to present the additional configuration options. I’d be happy to add these changes, but I’m not sure the best way to include them. I’m assuming the nano devices need to be a minimum version first, so this possibly needs a new device listing with minimum versions? I’m also not sure if the configuration would always be available with that minimum version or only when the wall swipe is connected, would there be a way to have conditional configuration options?
