chris
(Chris Jackson)
March 6, 2016, 11:05am
1
Continuing the discussion from Testing Z-Wave binding on openHAB-2 :
@shorty707 can you please post a log of the zw100 with different alarms - please try to keep it short and also clearly state what happens in each case… So, when you wave your hand, and the alarm goes off, then state this. I assume then some time later another message is sent if there is no more motion to state that the alarm is over? I want to see these different events.
This device is using the new information for the Alarm class V3 which is different than used in the OH1 binding, so I need a bit more information to make sure I get it right.
Thanks.
shorty707
(Shorty707)
March 6, 2016, 11:32am
2
_**here we go: many posts due to char limit
WAVE HAND --> MOTION ALARM:
12:18:21.504 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 09 03 20 01 FF 26
12:18:21.509 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
12:18:21.510 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 04 00 09 03 20 01 FF 26
12:18:21.512 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 04 00 09 03 20 01 FF 26
12:18:21.513 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 09 03 20 01 FF
12:18:21.514 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Application Command Request (ALIVE:DONE)
12:18:21.514 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Incoming command class BASIC
12:18:21.515 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 9: Received Basic Request
12:18:21.515 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 9: Basic Set sent to the controller will be processed as Basic Report
12:18:21.516 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 9: Basic report, value = 0xFF
12:18:21.517 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
12:18:21.517 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
12:18:21.518 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = BASIC, value = 255
12:18:21.518 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general
12:18:21.519 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general
12:18:21.519 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity
12:18:21.520 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity
12:18:21.521 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet
12:18:21.522 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature
12:18:21.523 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature
12:18:21.523 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance
12:18:21.524 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance
12:18:21.524 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_binary
12:18:21.525 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_binary
12:18:21.525 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:battery-level
12:18:21.526 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:battery-level
12:18:21.527 [DEBUG] [ssage.ApplicationCommandMessageClass] - Transaction not completed: node address inconsistent.
12:18:23.370 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 00 09 0A 71 05 00 00 00 FF 07 08 00 00 6C
12:18:23.372 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
12:18:23.374 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 10 00 04 00 09 0A 71 05 00 00 00 FF 07 08 00 00 6C
12:18:23.375 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 10 00 04 00 09 0A 71 05 00 00 00 FF 07 08 00 00 6C
12:18:23.376 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 09 0A 71 05 00 00 00 FF 07 08 00 00
12:18:23.376 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Application Command Request (ALIVE:DONE)
12:18:23.377 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Incoming command class ALARM
12:18:23.377 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 9: Received Alarm Request
12:18:23.378 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 9: Process Alarm Report, V3, length 13
12:18:23.378 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 9: Alarm report - 0 = 0, source=0, event=8, status=255
12:18:23.379 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 9: Alarm Type = General (0)
12:18:23.379 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveAlarmValueEvent
12:18:23.379 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveAlarmValueEvent
12:18:23.380 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = ALARM, value = 0
12:18:23.380 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general
12:18:23.381 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general OnOffType
12:18:23.381 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Updating zwave:aeon_zw100_00_000:15348538564:node9:alarm_general to OFF
12:18:23.383 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general
12:18:23.383 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general OnOffType
12:18:23.384 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Updating zwave:aeon_zw100_00_000:15348538564:node9:alarm_general to OFF
12:18:23.386 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity
12:18:23.386 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet
12:18:23.387 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet
12:18:23.387 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature
12:18:23.388 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature
12:18:23.388 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance
12:18:23.389 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_binary
12:18:23.389 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:battery-level
12:18:23.390 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:battery-level
12:18:23.390 [DEBUG] [ssage.ApplicationCommandMessageClass] - Transaction not completed: node address inconsistent.
shorty707
(Shorty707)
March 6, 2016, 11:33am
3
AFTER CONFIGURED TIMEOUT (Parameter 3 is set to 15 seconds) --> MOTION ALARM OVER: (SPLIT IN 2 POSTS HERE !)
12:20:18.931 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 09 03 20 01 00 D9
12:20:18.934 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
12:20:18.935 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 04 00 09 03 20 01 00 D9
12:20:18.936 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 04 00 09 03 20 01 00 D9
12:20:18.937 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 09 03 20 01 00
12:20:18.938 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Application Command Request (ALIVE:DONE)
12:20:18.939 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Incoming command class BASIC
12:20:18.939 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 9: Received Basic Request
12:20:18.940 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 9: Basic Set sent to the controller will be processed as Basic Report
12:20:18.940 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 9: Basic report, value = 0x00
12:20:18.941 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
12:20:18.941 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
12:20:18.942 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = BASIC, value = 0
12:20:18.942 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general
12:20:18.943 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general
12:20:18.943 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity
12:20:18.944 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity
12:20:18.944 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet
12:20:18.945 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet
12:20:18.945 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature
12:20:18.946 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance
12:20:18.947 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_binary
12:20:18.948 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:battery-level
12:20:18.949 [DEBUG] [ssage.ApplicationCommandMessageClass] - Transaction not completed: node address inconsistent.
12:20:20.881 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 00 09 0A 71 05 00 00 00 FF 07 00 00 00 64
12:20:20.884 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
12:20:20.885 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 10 00 04 00 09 0A 71 05 00 00 00 FF 07 00 00 00 64
12:20:20.886 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 10 00 04 00 09 0A 71 05 00 00 00 FF 07 00 00 00 64
12:20:20.887 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 09 0A 71 05 00 00 00 FF 07 00 00 00
12:20:20.887 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Application Command Request (ALIVE:DONE)
12:20:20.888 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Incoming command class ALARM
12:20:20.888 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 9: Received Alarm Request
12:20:20.889 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 9: Process Alarm Report, V3, length 13
12:20:20.889 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 9: Alarm report - 0 = 0, source=0, event=0, status=255
12:20:20.889 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 9: Alarm Type = General (0)
12:20:20.890 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveAlarmValueEvent
12:20:20.890 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveAlarmValueEvent
12:20:20.891 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = ALARM, value = 0
12:20:20.891 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general
12:20:20.891 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general OnOffType
12:20:20.892 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Updating zwave:aeon_zw100_00_000:15348538564:node9:alarm_general to OFF
12:20:20.894 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general
12:20:20.894 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general OnOffType
12:20:20.894 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Updating zwave:aeon_zw100_00_000:15348538564:node9:alarm_general to OFF
12:20:20.906 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity
12:20:20.907 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet
12:20:20.908 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet
12:20:20.915 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature
12:20:20.916 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature
12:20:20.916 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance
12:20:20.917 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance
12:20:20.918 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_binary
12:20:20.919 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:battery-level
12:20:20.920 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:battery-level
12:20:20.921 [DEBUG] [ssage.ApplicationCommandMessageClass] - Transaction not completed: node address inconsistent.
12:20:56.377 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0C 00 04 00 09 06 31 05 01 22 00 D1 3E
12:20:56.380 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
12:20:56.381 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0C 00 04 00 09 06 31 05 01 22 00 D1 3E
12:20:56.382 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0C 00 04 00 09 06 31 05 01 22 00 D1 3E
12:20:56.383 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 09 06 31 05 01 22 00 D1
12:20:56.384 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Application Command Request (ALIVE:DONE)
12:20:56.384 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Incoming command class SENSOR_MULTILEVEL
12:20:56.385 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Received Sensor Multi Level Request
12:20:56.385 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Multi Level REPORT received
12:20:56.386 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Type = Temperature(1), Scale = 0
12:20:56.386 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Value = 20.9
12:20:56.387 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMultiLevelSensorValueEvent
12:20:56.387 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
12:20:56.388 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 20.9
12:20:56.388 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general
12:20:56.389 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general
12:20:56.389 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity
12:20:56.389 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity DecimalType
12:20:56.390 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity
12:20:56.390 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity DecimalType
12:20:56.391 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet
12:20:56.391 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet DecimalType
12:20:56.392 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet DecimalType
12:20:56.392 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature
12:20:56.393 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature DecimalType
12:20:56.393 [DEBUG] [erter.ZWaveMultiLevelSensorConverter] - NODE 9: Sensor is reporting scale 0, requiring conversion to 0. Value is now 20.9.
12:20:56.394 [DEBUG] [converter.ZWaveCommandClassConverter] - Converted temperature from 20.9C to 20.9C
12:20:56.394 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Updating zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature to 20.9
12:20:56.396 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature
12:20:56.396 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature DecimalType
12:20:56.397 [DEBUG] [erter.ZWaveMultiLevelSensorConverter] - NODE 9: Sensor is reporting scale 0, requiring conversion to 0. Value is now 20.9.
12:20:56.397 [DEBUG] [converter.ZWaveCommandClassConverter] - Converted temperature from 20.9C to 20.9C
12:20:56.398 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Updating zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature to 20.9
12:20:56.399 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance
12:20:56.400 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance DecimalType
12:20:56.400 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance
12:20:56.401 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance DecimalType
12:20:56.401 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_binary
12:20:56.402 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:battery-level
12:20:56.403 [DEBUG] [ssage.ApplicationCommandMessageClass] - Transaction not completed: node address inconsistent.
12:20:56.411 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_aeon_zw100_00_000_15348538564_node9_sensor_temperature changed from 21 to 20.9
12:20:56.417 [INFO ] [marthome.event.ItemStateChangedEvent] - MS1_Temp changed from 21 to 20.9
12:20:58.235 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0B 00 04 00 09 05 31 05 05 01 29 E5
12:20:58.238 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
12:20:58.239 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0B 00 04 00 09 05 31 05 05 01 29 E5
12:20:58.240 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0B 00 04 00 09 05 31 05 05 01 29 E5
12:20:58.240 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 09 05 31 05 05 01 29
12:20:58.241 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Application Command Request (ALIVE:DONE)
12:20:58.241 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Incoming command class SENSOR_MULTILEVEL
12:20:58.242 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Received Sensor Multi Level Request
12:20:58.242 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Multi Level REPORT received
12:20:58.243 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Type = RelativeHumidity(5), Scale = 0
12:20:58.243 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Value = 41
12:20:58.244 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMultiLevelSensorValueEvent
12:20:58.244 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
12:20:58.245 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 41
12:20:58.245 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general
12:20:58.246 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general
12:20:58.246 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity
12:20:58.246 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity DecimalType
12:20:58.247 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Updating zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity to 41
12:20:58.249 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity
12:20:58.249 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity DecimalType
12:20:58.250 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Updating zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity to 41
12:20:58.251 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet
12:20:58.251 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet DecimalType
12:20:58.252 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet
12:20:58.252 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet DecimalType
12:20:58.253 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature
12:20:58.253 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature DecimalType
12:20:58.254 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature DecimalType
12:20:58.254 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance
12:20:58.254 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance DecimalType
12:20:58.255 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance DecimalType
12:20:58.255 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_binary
12:20:58.256 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:battery-level
12:20:58.257 [DEBUG] [ssage.ApplicationCommandMessageClass] - Transaction not completed: node address inconsistent.
12:20:59.167 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 09 03 80 03 64 1F
12:20:59.170 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
12:20:59.171 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 04 00 09 03 80 03 64 1F
12:20:59.172 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 04 00 09 03 80 03 64 1F
12:20:59.173 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 09 03 80 03 64
12:20:59.174 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Application Command Request (ALIVE:DONE)
12:20:59.175 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Incoming command class BATTERY
12:20:59.175 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 9: Received Battery Request
12:20:59.176 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 9: Battery report value = 100
12:20:59.176 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
12:20:59.177 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
12:20:59.178 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = BATTERY, value = 100
12:20:59.178 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general
12:20:59.179 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general
12:20:59.179 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity
12:20:59.180 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity
12:20:59.180 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet
12:20:59.181 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet
12:20:59.181 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature
12:20:59.182 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature
12:20:59.182 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance
12:20:59.183 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance
12:20:59.184 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_binary
12:20:59.185 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_binary
12:20:59.186 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:battery-level
12:20:59.186 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:battery-level PercentType
12:20:59.187 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Updating zwave:aeon_zw100_00_000:15348538564:node9:battery-level to 100
12:20:59.190 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:battery-level
12:20:59.193 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:battery-level PercentType
12:20:59.193 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Updating zwave:aeon_zw100_00_000:15348538564:node9:battery-level to 100
12:20:59.196 [DEBUG] [ssage.ApplicationCommandMessageClass] - Transaction not completed: node address inconsistent.
12:20:59.355 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0C 00 04 00 09 06 31 05 03 0A 00 1E DB
12:20:59.357 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
12:20:59.359 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0C 00 04 00 09 06 31 05 03 0A 00 1E DB
12:20:59.361 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0C 00 04 00 09 06 31 05 03 0A 00 1E DB
12:20:59.362 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 09 06 31 05 03 0A 00 1E
12:20:59.363 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Application Command Request (ALIVE:DONE)
12:20:59.364 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Incoming command class SENSOR_MULTILEVEL
12:20:59.364 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Received Sensor Multi Level Request
12:20:59.365 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Multi Level REPORT received
12:20:59.365 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Type = Luminance(3), Scale = 1
12:20:59.367 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Value = 3E+1
12:20:59.367 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMultiLevelSensorValueEvent
12:20:59.381 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
12:20:59.382 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 3E+1
12:20:59.382 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general
12:20:59.383 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general
12:20:59.383 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity
12:20:59.383 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity DecimalType
12:20:59.384 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity
12:20:59.384 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity DecimalType
12:20:59.384 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet
12:20:59.385 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet DecimalType
12:20:59.385 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet
12:20:59.386 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet DecimalType
12:20:59.386 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature
12:20:59.386 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature DecimalType
12:20:59.387 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature
12:20:59.387 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature DecimalType
12:20:59.387 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance
12:20:59.388 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance DecimalType
12:20:59.388 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Updating zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance to 30
12:20:59.390 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance
12:20:59.390 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance DecimalType
12:20:59.391 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Updating zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance to 30
12:20:59.392 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_aeon_zw100_00_000_15348538564_node9_sensor_luminance changed from 28 to 30
12:20:59.396 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_binary
12:20:59.397 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_binary
12:20:59.398 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:battery-level
12:20:59.399 [DEBUG] [ssage.ApplicationCommandMessageClass] - Transaction not completed: node address inconsistent.
12:20:59.401 [INFO ] [marthome.event.ItemStateChangedEvent] - MS1_Lux changed from 28 to 30
shorty707
(Shorty707)
4
12:20:59.493 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0B 00 04 00 09 05 31 05 1B 01 00 D2
12:20:59.496 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
12:20:59.497 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0B 00 04 00 09 05 31 05 1B 01 00 D2
12:20:59.498 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0B 00 04 00 09 05 31 05 1B 01 00 D2
12:20:59.499 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 09 05 31 05 1B 01 00
12:20:59.499 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Application Command Request (ALIVE:DONE)
12:20:59.500 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Incoming command class SENSOR_MULTILEVEL
12:20:59.500 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Received Sensor Multi Level Request
12:20:59.501 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Multi Level REPORT received
12:20:59.501 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Type = Ultraviolet(27), Scale = 0
12:20:59.502 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Value = 0E+1
12:20:59.504 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMultiLevelSensorValueEvent
12:20:59.510 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
12:20:59.511 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 0E+1
12:20:59.511 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general
12:20:59.512 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity
12:20:59.512 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity DecimalType
12:20:59.513 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity DecimalType
12:20:59.513 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet
12:20:59.514 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet DecimalType
12:20:59.522 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Updating zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet to 0
12:20:59.527 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet
12:20:59.528 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet DecimalType
12:20:59.533 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Updating zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet to 0
12:20:59.537 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature
12:20:59.537 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature DecimalType
12:20:59.538 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature
12:20:59.539 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature DecimalType
12:20:59.540 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance
12:20:59.540 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance DecimalType
12:20:59.541 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance
12:20:59.541 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance DecimalType
12:20:59.542 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_binary
12:20:59.543 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_binary
12:20:59.543 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:battery-level
12:20:59.544 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:battery-level
12:20:59.544 [DEBUG] [ssage.ApplicationCommandMessageClass] - Transaction not completed: node address inconsistent.
shorty707
(Shorty707)
March 6, 2016, 11:34am
5
TAMPER ALARM (Took the sensor in my hand; from behind without waving something through PIR; not sure if moving the sensor itself also sets PIR in alarm):
12:23:11.992 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 09 03 20 01 FF 26
12:23:11.995 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
12:23:11.996 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 04 00 09 03 20 01 FF 26
12:23:11.997 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 04 00 09 03 20 01 FF 26
12:23:11.998 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 09 03 20 01 FF
12:23:11.999 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Application Command Request (ALIVE:DONE)
12:23:11.999 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Incoming command class BASIC
12:23:12.000 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 9: Received Basic Request
12:23:12.000 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 9: Basic Set sent to the controller will be processed as Basic Report
12:23:12.001 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 9: Basic report, value = 0xFF
12:23:12.001 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
12:23:12.002 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
12:23:12.002 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = BASIC, value = 255
12:23:12.003 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general
12:23:12.005 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general
12:23:12.007 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity
12:23:12.009 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity
12:23:12.010 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet
12:23:12.012 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet
12:23:12.014 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature
12:23:12.015 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature
12:23:12.017 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance
12:23:12.018 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance
12:23:12.020 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_binary
12:23:12.021 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_binary
12:23:12.022 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:battery-level
12:23:12.023 [DEBUG] [ssage.ApplicationCommandMessageClass] - Transaction not completed: node address inconsistent.
12:23:12.335 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 00 09 0A 71 05 00 00 00 FF 07 08 00 00 6C
12:23:12.338 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
12:23:12.340 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 10 00 04 00 09 0A 71 05 00 00 00 FF 07 08 00 00 6C
12:23:12.343 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 10 00 04 00 09 0A 71 05 00 00 00 FF 07 08 00 00 6C
12:23:12.345 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 09 0A 71 05 00 00 00 FF 07 08 00 00
12:23:12.346 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Application Command Request (ALIVE:DONE)
12:23:12.347 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Incoming command class ALARM
12:23:12.348 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 9: Received Alarm Request
12:23:12.348 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 9: Process Alarm Report, V3, length 13
12:23:12.349 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 9: Alarm report - 0 = 0, source=0, event=8, status=255
12:23:12.349 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 9: Alarm Type = General (0)
12:23:12.350 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveAlarmValueEvent
12:23:12.350 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveAlarmValueEvent
12:23:12.351 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = ALARM, value = 0
12:23:12.351 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general
12:23:12.352 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general OnOffType
12:23:12.353 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Updating zwave:aeon_zw100_00_000:15348538564:node9:alarm_general to OFF
12:23:12.355 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general
12:23:12.355 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general OnOffType
12:23:12.356 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Updating zwave:aeon_zw100_00_000:15348538564:node9:alarm_general to OFF
12:23:12.357 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity
12:23:12.358 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity
12:23:12.367 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet
12:23:12.368 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet
12:23:12.368 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature
12:23:12.369 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance
12:23:12.370 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_binary
12:23:12.370 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:battery-level
12:23:12.371 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:battery-level
12:23:12.371 [DEBUG] [ssage.ApplicationCommandMessageClass] - Transaction not completed: node address inconsistent.
shorty707
(Shorty707)
March 6, 2016, 11:35am
6
TAMPER OVER / Sensor was returned still on the table again and log shows that update: again split in 2 posts
12:23:36.292 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 09 03 20 01 00 D9
12:23:36.294 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
12:23:36.295 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 04 00 09 03 20 01 00 D9
12:23:36.296 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 04 00 09 03 20 01 00 D9
12:23:36.296 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 09 03 20 01 00
12:23:36.297 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Application Command Request (ALIVE:DONE)
12:23:36.297 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Incoming command class BASIC
12:23:36.298 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 9: Received Basic Request
12:23:36.298 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 9: Basic Set sent to the controller will be processed as Basic Report
12:23:36.299 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 9: Basic report, value = 0x00
12:23:36.299 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
12:23:36.300 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
12:23:36.301 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = BASIC, value = 0
12:23:36.301 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general
12:23:36.302 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general
12:23:36.304 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity
12:23:36.304 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet
12:23:36.305 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet
12:23:36.305 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature
12:23:36.306 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance
12:23:36.306 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_binary
12:23:36.308 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_binary
12:23:36.308 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:battery-level
12:23:36.309 [DEBUG] [ssage.ApplicationCommandMessageClass] - Transaction not completed: node address inconsistent.
12:23:36.635 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 00 09 0A 71 05 00 00 00 FF 07 00 00 00 64
12:23:36.638 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
12:23:36.639 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 10 00 04 00 09 0A 71 05 00 00 00 FF 07 00 00 00 64
12:23:36.640 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 10 00 04 00 09 0A 71 05 00 00 00 FF 07 00 00 00 64
12:23:36.641 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 09 0A 71 05 00 00 00 FF 07 00 00 00
12:23:36.642 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Application Command Request (ALIVE:DONE)
12:23:36.642 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Incoming command class ALARM
12:23:36.643 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 9: Received Alarm Request
12:23:36.643 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 9: Process Alarm Report, V3, length 13
12:23:36.644 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 9: Alarm report - 0 = 0, source=0, event=0, status=255
12:23:36.644 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 9: Alarm Type = General (0)
12:23:36.645 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveAlarmValueEvent
12:23:36.645 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveAlarmValueEvent
12:23:36.646 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = ALARM, value = 0
12:23:36.646 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general
12:23:36.646 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general OnOffType
12:23:36.647 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Updating zwave:aeon_zw100_00_000:15348538564:node9:alarm_general to OFF
12:23:36.649 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general
12:23:36.649 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general OnOffType
12:23:36.649 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Updating zwave:aeon_zw100_00_000:15348538564:node9:alarm_general to OFF
12:23:36.651 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity
12:23:36.652 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet
12:23:36.653 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature
12:23:36.654 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance
12:23:36.655 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_binary
12:23:36.655 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:battery-level
12:23:36.656 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:battery-level
12:23:36.657 [DEBUG] [ssage.ApplicationCommandMessageClass] - Transaction not completed: node address inconsistent.
12:23:57.913 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0C 00 04 00 09 06 31 05 01 22 00 D1 3E
12:23:57.915 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
12:23:57.916 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0C 00 04 00 09 06 31 05 01 22 00 D1 3E
12:23:57.917 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0C 00 04 00 09 06 31 05 01 22 00 D1 3E
12:23:57.918 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 09 06 31 05 01 22 00 D1
12:23:57.919 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Application Command Request (ALIVE:DONE)
12:23:57.919 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Incoming command class SENSOR_MULTILEVEL
12:23:57.920 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Received Sensor Multi Level Request
12:23:57.920 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Multi Level REPORT received
12:23:57.920 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Type = Temperature(1), Scale = 0
12:23:57.921 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Value = 20.9
12:23:57.921 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMultiLevelSensorValueEvent
12:23:57.922 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
12:23:57.922 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 20.9
12:23:57.923 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general
12:23:57.924 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity
12:23:57.924 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity DecimalType
12:23:57.925 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity DecimalType
12:23:57.925 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet
12:23:57.926 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet DecimalType
12:23:57.926 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet
12:23:57.927 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature
12:23:57.927 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature DecimalType
12:23:57.927 [DEBUG] [erter.ZWaveMultiLevelSensorConverter] - NODE 9: Sensor is reporting scale 0, requiring conversion to 0. Value is now 20.9.
12:23:57.928 [DEBUG] [converter.ZWaveCommandClassConverter] - Converted temperature from 20.9C to 20.9C
12:23:57.928 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Updating zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature to 20.9
12:23:57.930 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature
12:23:57.930 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature DecimalType
12:23:57.931 [DEBUG] [erter.ZWaveMultiLevelSensorConverter] - NODE 9: Sensor is reporting scale 0, requiring conversion to 0. Value is now 20.9.
12:23:57.931 [DEBUG] [converter.ZWaveCommandClassConverter] - Converted temperature from 20.9C to 20.9C
12:23:57.931 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Updating zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature to 20.9
12:23:57.933 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance
12:23:57.934 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance DecimalType
12:23:57.934 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance
12:23:57.935 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance DecimalType
12:23:57.935 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_binary
12:23:57.943 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_binary
12:23:57.944 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:battery-level
12:23:57.945 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:battery-level
12:23:57.945 [DEBUG] [ssage.ApplicationCommandMessageClass] - Transaction not completed: node address inconsistent.
12:23:58.424 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0B 00 04 00 09 05 31 05 05 01 29 E5
12:23:58.427 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
12:23:58.429 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0B 00 04 00 09 05 31 05 05 01 29 E5
12:23:58.431 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0B 00 04 00 09 05 31 05 05 01 29 E5
12:23:58.432 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 09 05 31 05 05 01 29
12:23:58.436 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Application Command Request (ALIVE:DONE)
12:23:58.439 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Incoming command class SENSOR_MULTILEVEL
12:23:58.443 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Received Sensor Multi Level Request
12:23:58.445 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Multi Level REPORT received
12:23:58.448 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Type = RelativeHumidity(5), Scale = 0
12:23:58.449 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Value = 41
12:23:58.451 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMultiLevelSensorValueEvent
12:23:58.453 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
12:23:58.454 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 41
12:23:58.455 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general
12:23:58.457 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general
12:23:58.458 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity
12:23:58.460 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity DecimalType
12:23:58.461 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Updating zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity to 41
12:23:58.481 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity
12:23:58.485 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity DecimalType
12:23:58.488 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Updating zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity to 41
12:23:58.493 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet
12:23:58.494 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet DecimalType
12:23:58.495 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet
12:23:58.495 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet DecimalType
12:23:58.496 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature
12:23:58.496 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature DecimalType
12:23:58.497 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature
12:23:58.497 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature DecimalType
12:23:58.504 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance
12:23:58.505 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance DecimalType
shorty707
(Shorty707)
7
12:23:58.505 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance
12:23:58.506 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance DecimalType
12:23:58.506 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_binary
12:23:58.507 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_binary
12:23:58.507 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:battery-level
12:23:58.508 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:battery-level
12:23:58.508 [DEBUG] [ssage.ApplicationCommandMessageClass] - Transaction not completed: node address inconsistent.
12:23:59.324 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 09 03 80 03 64 1F
12:23:59.327 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
12:23:59.328 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 04 00 09 03 80 03 64 1F
12:23:59.329 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 04 00 09 03 80 03 64 1F
12:23:59.331 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 09 03 80 03 64
12:23:59.332 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Application Command Request (ALIVE:DONE)
12:23:59.333 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Incoming command class BATTERY
12:23:59.333 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 9: Received Battery Request
12:23:59.333 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 9: Battery report value = 100
12:23:59.334 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
12:23:59.334 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
12:23:59.335 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = BATTERY, value = 100
12:23:59.335 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general
12:23:59.344 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity
12:23:59.345 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity
12:23:59.345 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet
12:23:59.346 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet
12:23:59.346 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature
12:23:59.347 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance
12:23:59.348 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_binary
12:23:59.348 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:battery-level
12:23:59.349 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:battery-level PercentType
12:23:59.349 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Updating zwave:aeon_zw100_00_000:15348538564:node9:battery-level to 100
12:23:59.351 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:battery-level
12:23:59.352 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:battery-level PercentType
12:23:59.352 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Updating zwave:aeon_zw100_00_000:15348538564:node9:battery-level to 100
12:23:59.354 [DEBUG] [ssage.ApplicationCommandMessageClass] - Transaction not completed: node address inconsistent.
12:23:59.614 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0C 00 04 00 09 06 31 05 03 0A 00 18 DD
12:23:59.617 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
12:23:59.618 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0C 00 04 00 09 06 31 05 03 0A 00 18 DD
12:23:59.619 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0C 00 04 00 09 06 31 05 03 0A 00 18 DD
12:23:59.620 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 09 06 31 05 03 0A 00 18
12:23:59.621 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Application Command Request (ALIVE:DONE)
12:23:59.622 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Incoming command class SENSOR_MULTILEVEL
12:23:59.622 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Received Sensor Multi Level Request
12:23:59.622 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Multi Level REPORT received
12:23:59.623 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Type = Luminance(3), Scale = 1
12:23:59.623 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Value = 24
12:23:59.624 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMultiLevelSensorValueEvent
12:23:59.624 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
12:23:59.625 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 24
12:23:59.626 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general
12:23:59.626 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity
12:23:59.627 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity DecimalType
12:23:59.627 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity
12:23:59.628 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity DecimalType
12:23:59.629 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet
12:23:59.629 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet DecimalType
12:23:59.630 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet
12:23:59.631 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet DecimalType
12:23:59.631 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature
12:23:59.632 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature DecimalType
12:23:59.634 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature
12:23:59.635 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature DecimalType
12:23:59.636 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance
12:23:59.637 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance DecimalType
12:23:59.638 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Updating zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance to 24
12:23:59.643 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance
12:23:59.643 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance DecimalType
12:23:59.644 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Updating zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance to 24
12:23:59.644 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_aeon_zw100_00_000_15348538564_node9_sensor_luminance changed from 30 to 24
12:23:59.646 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_binary
12:23:59.647 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:battery-level
12:23:59.648 [DEBUG] [ssage.ApplicationCommandMessageClass] - Transaction not completed: node address inconsistent.
12:23:59.654 [INFO ] [marthome.event.ItemStateChangedEvent] - MS1_Lux changed from 30 to 24
12:23:59.748 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0B 00 04 00 09 05 31 05 1B 01 00 D2
12:23:59.751 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
12:23:59.752 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0B 00 04 00 09 05 31 05 1B 01 00 D2
12:23:59.753 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0B 00 04 00 09 05 31 05 1B 01 00 D2
12:23:59.754 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 09 05 31 05 1B 01 00
12:23:59.755 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Application Command Request (ALIVE:DONE)
12:23:59.756 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Incoming command class SENSOR_MULTILEVEL
12:23:59.756 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Received Sensor Multi Level Request
12:23:59.757 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Multi Level REPORT received
12:23:59.757 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Type = Ultraviolet(27), Scale = 0
12:23:59.758 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Value = 0E+1
12:23:59.758 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMultiLevelSensorValueEvent
12:23:59.759 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
12:23:59.760 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 0E+1
12:23:59.762 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general
12:23:59.773 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:alarm_general
12:23:59.773 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity
12:23:59.774 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity DecimalType
12:23:59.774 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_relhumidity
12:23:59.775 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet
12:23:59.775 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet DecimalType
12:23:59.775 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Updating zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet to 0
12:23:59.777 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet
12:23:59.778 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet DecimalType
12:23:59.778 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Updating zwave:aeon_zw100_00_000:15348538564:node9:sensor_ultraviolet to 0
12:23:59.780 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature
12:23:59.780 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature DecimalType
12:23:59.781 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature
12:23:59.781 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_temperature DecimalType
12:23:59.782 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance
12:23:59.792 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance DecimalType
12:23:59.793 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance
12:23:59.793 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Processing event as channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_luminance DecimalType
12:23:59.794 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:sensor_binary
12:23:59.795 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Checking channel zwave:aeon_zw100_00_000:15348538564:node9:battery-level
12:23:59.796 [DEBUG] [ssage.ApplicationCommandMessageClass] - Transaction not completed: node address inconsistent.
chris
(Chris Jackson)
March 6, 2016, 12:12pm
8
Thanks. I’ve summarised this below…
Motion Alarm
Motion Alarm Timeout
Tamper Alarm
Tamper Alarm End
So, from this it seems there’s no way to tell the difference between the tamper and motion alarms… Anyway, that aside I’ll look to update the class based on this…
I know I’m a couple of days late here but I get a SENSOR_BINARY command for the motion and an ALARM command for the tamper alarm on my zw100.
How are people getting ALARM reports for the motion sensor?
shorty707
(Shorty707)
March 8, 2016, 5:40pm
10
mhhh i definately get an alarm report on motion.
i posted that under your log in the zwave text thread.
any chance to find out firmware verison of the device?
also the motion gets no update on the item/channel I use on the sitemap
shorty707
(Shorty707)
March 8, 2016, 5:52pm
12
uh
remove from network
here i also noted to have a different alarm type
ok one question ahead:
bhuism above posted his log: he gets an update for: Incoming command class SENSOR_BINARY
I do get an update on the same sensor and motion: Incoming command class ALARM
also both parameters (binary, alarm) do not get an update either on basicui nor within habmin (ever):
[image]
shorty707
(Shorty707)
March 8, 2016, 6:00pm
13
^whats yout setting for parameter5? (or maybe a screenshot of all settings?)
chris
(Chris Jackson)
March 8, 2016, 6:06pm
14
I’ve not updated the implementation of the command class yet as I’m not convinced by what I saw in the logs. It would be good to get a log from another device or two that support the V3 Alarm class. The only other device I’ve seen (WADWAZ I think) was slightly different, so I need to understand how the different fields are used…
shorty707
(Shorty707)
March 8, 2016, 6:08pm
15
ok I changed parameter 5
now I do get SENSOR BINARY on motion
also channel/item now works with parameter 5 changed to catch the motion…
however like many other items this status is only updated on UI and gets lost when you refresh (f5)
shorty707
(Shorty707)
March 8, 2016, 6:12pm
17
funny
with parameter 5 basic set mine did send ALARM and not Sensor binary
odd
@chris are the values displayed defaults or actually pulled from the Thing config?
chris
(Chris Jackson)
March 8, 2016, 6:22pm
19
They should be from the device, but I can’t be 100% sure… The device configuration is read during startup, so the configuration you see should be synchronised.
shorty707
(Shorty707)
March 8, 2016, 6:26pm
20
to what I have observed… both can happen and you cant tell exactly if that device is synched or not
eg. for that sensor I have a temp offset… sometimes habmin shows the offset
sometimes not
btw… description says to make that offset in x.x values for C … thats also not true
e.g. if you want - 2.1 C offset you must enter -21
