Hi, I’m trying to add my Z-wave devices to OH2. This worked fine in a previous OH2 setup but now I’m having some trouble. Adding the Aeotec Z-Stick S2 works fine but then all devices show up as ‘Unknown Device’ in the Inbox. All devices are in the database.
OH2 runtime is latest nightly build (March 4th), Z-wave bundle is 2.0.0.201701191638.
Z-wave logs and xml (node 10 and 11 are both Everspring AN157 Switches):
I had kind of the same issue with a door sensor and same stick all zwave.
I restarted Openhab
open the Log viewer and follow the evolution of the logs -
once your node (my sensor in my case) is being initialized and then comes the log called “node has been updated” then do the wake up process of the device (for me pushing and holding the button during 6 sec) as many times as needed (4 times were ok for me and I could see in the dashboard that the node is finally recognized
I guess that doing the wake up process of the node when it is being initialized is key
maybe I got lucky but wanted to share my experience with you guys
