Z-Wave Bridge Offline after dist-upgrade to Debian Bullseye x86_64
I just updated my home server to the freshly released Debian 11. Everything works just fine so far, except my z-wave stack in Openhab. The bridge (and all other devices) are just listed as “BRIDGE_OFFLINE* Controller is offline” There is no obvious error logged (see below), my device /dev/ttyzwave is available and my other tty device (a Deconz sticks) works just fine. I spend over an hour googling the issue. Some had problems with /var/lock but the lock file looks just fine, besides my log file is a bit different. The issues just started after upgrading Debian, it worked fine for years before. I already uninstalled apparmor as it has caused many strange issues on different machines just to rule it out, but it did not help. Now I am out of ideas and I hope someone here can help :slight_smile:
I am running openhab 3.1.0-1, the z-wave stick is reported as Sigma Designs, Inc. Aeotec Z-Stick Gen5 (ZW090) - UZB.
uname -a
Linux [...] 5.10.0-8-amd64 #1 SMP Debian 5.10.46-4 (2021-08-03) x86_64 GNU/Linux
dmesg | grep tty
[    0.100538] printk: console [tty0] enabled
[    3.814567] systemd[1]: Created slice system-getty.slice.
[    4.697907] cdc_acm 1-2.1:1.0: ttyACM0: USB ACM device
[    4.698185] cdc_acm 1-2.3:1.0: ttyACM1: USB ACM device
grep tty /etc/default/openhab
EXTRA_JAVA_OPTS="-Xmx8000m -Dgnu.io.rxtx.SerialPorts=/dev/ttyzwave"
ls -l /dev/ttyzwave
lrwxrwxrwx 1 root root 7 Aug 16 23:13 /dev/ttyzwave -> ttyACM1
ls -l /dev/ttyACM1
crw-rw---- 1 root dialout 166, 1 Aug 16 23:13 /dev/ttyACM1
groups openhab
openhab : openhab tty dialout audio
grep zwave openhab.log # (had to remove the timestamps and truncate class names to fit it into the post limit here)
[INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'zwave.items'
[INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'zwave.rules'
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider] : BundleComponentActivator : ComponentHolder created.
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory] : BundleComponentActivator : ComponentHolder created.
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider] : Dependency Manager created ConfigDescriptionRegistryinterface=org.openhab.core.config.core.ConfigDescriptionRegistry, filter=null, policy=static, cardinality=1..1, bind=setConfigDescriptionRegistry, unbind=unsetConfigDescriptionRegistry, updated=null, field=null, field-option=null, collection-type=null, parameter=null
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider] : Dependency Manager created ThingRegistryinterface=org.openhab.core.thing.ThingRegistry, filter=null, policy=static, cardinality=1..1, bind=setThingRegistry, unbind=unsetThingRegistry, updated=null, field=null, field-option=null, collection-type=null, parameter=null
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider] : Dependency Manager created ThingTypeRegistryinterface=org.openhab.core.thing.type.ThingTypeRegistry, filter=null, policy=static, cardinality=1..1, bind=setThingTypeRegistry, unbind=unsetThingTypeRegistry, updated=null, field=null, field-option=null, collection-type=null, parameter=null
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider] : Component created: DS=DS13, implementation=org.openhab.binding.zwave.internal.ZWaveConfigProvider, immediate=true, default-enabled=true, factory=null, configuration-policy=optional, activate=activate, deactivate=deactivate, modified=null configuration-pid=[org.openhab.binding.zwave.internal.ZWaveConfigProvider]
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider] : Component Services: scope=singleton, services=[org.openhab.core.config.core.ConfigDescriptionProvider, org.openhab.core.config.core.ConfigOptionProvider]
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider] : Component Properties: {}
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider] : Querying state disabled
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider] : Component can not be activated since it is in state disabled
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : Updating target filters
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : No change in target property for dependency ConfigDescriptionRegistry: currently registered: false
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] :  No existing service listener to unregister for dependency ConfigDescriptionRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : Setting target property for dependency ConfigDescriptionRegistry to null
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : New service tracker for ConfigDescriptionRegistry, initial active: false, previous references: {}, classFilter: (objectClass=org.openhab.core.config.core.ConfigDescriptionRegistry), initialReferenceFilter (objectClass=org.openhab.core.config.core.ConfigDescriptionRegistry)
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : dm ConfigDescriptionRegistry tracker reset (closed)
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : dm ConfigDescriptionRegistry tracking 1 SingleStatic added {org.openhab.core.config.core.ConfigDescriptionRegistry}={service.id=248, service.bundleid=164, service.scope=bundle, component.name=org.openhab.core.config.core.ConfigDescriptionRegistry, component.id=110} (enter)
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : dm ConfigDescriptionRegistry tracking 1 SingleStatic active: false trackerOpened: false optional: false
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : dm ConfigDescriptionRegistry tracking 1 SingleStatic added {org.openhab.core.config.core.ConfigDescriptionRegistry}={service.id=248, service.bundleid=164, service.scope=bundle, component.name=org.openhab.core.config.core.ConfigDescriptionRegistry, component.id=110} (exit)
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : dm ConfigDescriptionRegistry tracker opened
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : registering service listener for dependency ConfigDescriptionRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : No change in target property for dependency ThingRegistry: currently registered: false
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] :  No existing service listener to unregister for dependency ThingRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : Setting target property for dependency ThingRegistry to null
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : New service tracker for ThingRegistry, initial active: false, previous references: {}, classFilter: (objectClass=org.openhab.core.thing.ThingRegistry), initialReferenceFilter (objectClass=org.openhab.core.thing.ThingRegistry)
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : dm ThingRegistry tracker reset (closed)
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : dm ThingRegistry tracking 2 SingleStatic added {org.openhab.core.thing.ThingRegistry}={service.id=375, service.bundleid=213, service.scope=bundle, component.name=org.openhab.core.thing.internal.ThingRegistryImpl, component.id=244} (enter)
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : dm ThingRegistry tracking 2 SingleStatic active: false trackerOpened: false optional: false
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : dm ThingRegistry tracking 2 SingleStatic added {org.openhab.core.thing.ThingRegistry}={service.id=375, service.bundleid=213, service.scope=bundle, component.name=org.openhab.core.thing.internal.ThingRegistryImpl, component.id=244} (exit)
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : dm ThingRegistry tracker opened
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : registering service listener for dependency ThingRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : No change in target property for dependency ThingTypeRegistry: currently registered: false
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] :  No existing service listener to unregister for dependency ThingTypeRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : Setting target property for dependency ThingTypeRegistry to null
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : New service tracker for ThingTypeRegistry, initial active: false, previous references: {}, classFilter: (objectClass=org.openhab.core.thing.type.ThingTypeRegistry), initialReferenceFilter (objectClass=org.openhab.core.thing.type.ThingTypeRegistry)
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : dm ThingTypeRegistry tracker reset (closed)
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : dm ThingTypeRegistry tracking 3 SingleStatic added {org.openhab.core.thing.type.ThingTypeRegistry}={service.id=409, service.bundleid=213, service.scope=bundle, component.name=org.openhab.core.thing.type.ThingTypeRegistry, component.id=259} (enter)
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : dm ThingTypeRegistry tracking 3 SingleStatic active: false trackerOpened: false optional: false
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : dm ThingTypeRegistry tracking 3 SingleStatic added {org.openhab.core.thing.type.ThingTypeRegistry}={service.id=409, service.bundleid=213, service.scope=bundle, component.name=org.openhab.core.thing.type.ThingTypeRegistry, component.id=259} (exit)
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : dm ThingTypeRegistry tracker opened
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : registering service listener for dependency ThingTypeRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : Changed state from disabled to unsatisfiedReference
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : Component enabled
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : ActivateInternal
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : Querying state unsatisfiedReference
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : Activating component from state unsatisfiedReference
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : Changed state from unsatisfiedReference to satisfied
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : registration change queue [registered]
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : Checking constructor public org.openhab.binding.zwave.internal.ZWaveConfigProvider()
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : Found constructor with 0 arguments : public org.openhab.binding.zwave.internal.ZWaveConfigProvider()
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : getting bind: setConfigDescriptionRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : Locating method setConfigDescriptionRegistry in class org.openhab.binding.zwave.internal.ZWaveConfigProvider
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : doFindMethod: Looking for method org.openhab.binding.zwave.internal.ZWaveConfigProvider.setConfigDescriptionRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : Declared Method org.openhab.binding.zwave.internal.ZWaveConfigProvider.setConfigDescriptionRegistry([interface org.osgi.framework.ServiceReference]) not found
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : Declared Method org.openhab.binding.zwave.internal.ZWaveConfigProvider.setConfigDescriptionRegistry([interface org.osgi.service.component.ComponentServiceObjects]) not found
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : getReferenceClass: Looking for interface class org.openhab.core.config.core.ConfigDescriptionRegistry through loader of org.openhab.binding.zwave.internal.ZWaveConfigProvider
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : getParameterClass: Found class org.openhab.core.config.core.ConfigDescriptionRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : doFindMethod: No method taking ServiceReference found, checking method taking org.openhab.core.config.core.ConfigDescriptionRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : doFindMethod: Found Method protected void org.openhab.binding.zwave.internal.ZWaveConfigProvider.setConfigDescriptionRegistry(org.openhab.core.config.core.ConfigDescriptionRegistry)
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : Found bind method: protected void org.openhab.binding.zwave.internal.ZWaveConfigProvider.setConfigDescriptionRegistry(org.openhab.core.config.core.ConfigDescriptionRegistry)
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : getting bind: setThingRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : Locating method setThingRegistry in class org.openhab.binding.zwave.internal.ZWaveConfigProvider
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : doFindMethod: Looking for method org.openhab.binding.zwave.internal.ZWaveConfigProvider.setThingRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : Declared Method org.openhab.binding.zwave.internal.ZWaveConfigProvider.setThingRegistry([interface org.osgi.framework.ServiceReference]) not found
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : Declared Method org.openhab.binding.zwave.internal.ZWaveConfigProvider.setThingRegistry([interface org.osgi.service.component.ComponentServiceObjects]) not found
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : getReferenceClass: Looking for interface class org.openhab.core.thing.ThingRegistry through loader of org.openhab.binding.zwave.internal.ZWaveConfigProvider
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : getParameterClass: Found class org.openhab.core.thing.ThingRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : doFindMethod: No method taking ServiceReference found, checking method taking org.openhab.core.thing.ThingRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : doFindMethod: Found Method protected void org.openhab.binding.zwave.internal.ZWaveConfigProvider.setThingRegistry(org.openhab.core.thing.ThingRegistry)
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : Found bind method: protected void org.openhab.binding.zwave.internal.ZWaveConfigProvider.setThingRegistry(org.openhab.core.thing.ThingRegistry)
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : getting bind: setThingTypeRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : Locating method setThingTypeRegistry in class org.openhab.binding.zwave.internal.ZWaveConfigProvider
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : doFindMethod: Looking for method org.openhab.binding.zwave.internal.ZWaveConfigProvider.setThingTypeRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : Declared Method org.openhab.binding.zwave.internal.ZWaveConfigProvider.setThingTypeRegistry([interface org.osgi.framework.ServiceReference]) not found
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : Declared Method org.openhab.binding.zwave.internal.ZWaveConfigProvider.setThingTypeRegistry([interface org.osgi.service.component.ComponentServiceObjects]) not found
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : getReferenceClass: Looking for interface class org.openhab.core.thing.type.ThingTypeRegistry through loader of org.openhab.binding.zwave.internal.ZWaveConfigProvider
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : getParameterClass: Found class org.openhab.core.thing.type.ThingTypeRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : doFindMethod: No method taking ServiceReference found, checking method taking org.openhab.core.thing.type.ThingTypeRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : doFindMethod: Found Method protected void org.openhab.binding.zwave.internal.ZWaveConfigProvider.setThingTypeRegistry(org.openhab.core.thing.type.ThingTypeRegistry)
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : Found bind method: protected void org.openhab.binding.zwave.internal.ZWaveConfigProvider.setThingTypeRegistry(org.openhab.core.thing.type.ThingTypeRegistry)
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : This thread collected dependencies
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : getService (single component manager) dependencies collected.
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : Querying state satisfied
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : For dependency ConfigDescriptionRegistry, optional: false; to bind: [[RefPair: ref: [{org.openhab.core.config.core.ConfigDescriptionRegistry}={service.id=248, service.bundleid=164, service.scope=bundle, component.name=org.openhab.core.config.core.ConfigDescriptionRegistry, component.id=110}] service: [org.openhab.core.config.core.ConfigDescriptionRegistry@51c5815]]]
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : For dependency ThingRegistry, optional: false; to bind: [[RefPair: ref: [{org.openhab.core.thing.ThingRegistry}={service.id=375, service.bundleid=213, service.scope=bundle, component.name=org.openhab.core.thing.internal.ThingRegistryImpl, component.id=244}] service: [org.openhab.core.thing.internal.ThingRegistryImpl@5e32df21]]]
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : For dependency ThingTypeRegistry, optional: false; to bind: [[RefPair: ref: [{org.openhab.core.thing.type.ThingTypeRegistry}={service.id=409, service.bundleid=213, service.scope=bundle, component.name=org.openhab.core.thing.type.ThingTypeRegistry, component.id=259}] service: [org.openhab.core.thing.type.ThingTypeRegistry@1a972667]]]
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : invoking bind: setConfigDescriptionRegistry: parameters [org.openhab.core.config.core.ConfigDescriptionRegistry]
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : invoked bind: setConfigDescriptionRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : invoking bind: setThingRegistry: parameters [org.openhab.core.thing.internal.ThingRegistryImpl]
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : invoked bind: setThingRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : invoking bind: setThingTypeRegistry: parameters [org.openhab.core.thing.type.ThingTypeRegistry]
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : invoked bind: setThingTypeRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : getting activate: activate
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : Locating method activate in class org.openhab.binding.zwave.internal.ZWaveConfigProvider
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : Declared Method org.openhab.binding.zwave.internal.ZWaveConfigProvider.activate([interface org.osgi.service.component.ComponentContext]) not found
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : Locating method activate in class java.lang.Object
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : Declared Method java.lang.Object.activate([interface org.osgi.service.component.ComponentContext]) not found
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : activate method [activate] not found, ignoring
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : Set implementation object for component
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveConfigProvider(294)] : Changed state from satisfied to active
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory] : Dependency Manager created SerialPortManagerinterface=org.openhab.core.io.transport.serial.SerialPortManager, filter=null, policy=static, cardinality=1..1, bind=setSerialPortManager, unbind=unsetSerialPortManager, updated=null, field=null, field-option=null, collection-type=null, parameter=null
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory] : Component created: DS=DS13, implementation=org.openhab.binding.zwave.internal.ZWaveHandlerFactory, immediate=false, default-enabled=true, factory=null, configuration-policy=optional, activate=activate, deactivate=deactivate, modified=null configuration-pid=[org.openhab.binding.zwave.internal.ZWaveHandlerFactory]
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory] : Component Services: scope=singleton, services=[org.openhab.core.thing.binding.ThingHandlerFactory]
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory] : Component Properties: {}
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory] : Querying state disabled
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory] : Component can not be activated since it is in state disabled
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : Updating target filters
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : No change in target property for dependency SerialPortManager: currently registered: false
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] :  No existing service listener to unregister for dependency SerialPortManager
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : Setting target property for dependency SerialPortManager to null
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : New service tracker for SerialPortManager, initial active: false, previous references: {}, classFilter: (objectClass=org.openhab.core.io.transport.serial.SerialPortManager), initialReferenceFilter (objectClass=org.openhab.core.io.transport.serial.SerialPortManager)
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : dm SerialPortManager tracker reset (closed)
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : dm SerialPortManager tracker opened
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : registering service listener for dependency SerialPortManager
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : Changed state from disabled to unsatisfiedReference
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : Component enabled
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : ActivateInternal
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : Querying state unsatisfiedReference
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : Activating component from state unsatisfiedReference
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : Dependency not satisfied: SerialPortManager
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : Not all dependencies satisfied, cannot activate
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : dm SerialPortManager tracking 1 SingleStatic added {org.openhab.core.io.transport.serial.SerialPortManager}={service.id=511, service.bundleid=277, service.scope=bundle, component.name=org.openhab.core.io.transport.serial.internal.SerialPortManagerImpl, component.id=303} (enter)
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : Changed state from unsatisfiedReference to satisfied
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : registration change queue [registered]
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : Checking constructor public org.openhab.binding.zwave.internal.ZWaveHandlerFactory()
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : Found constructor with 0 arguments : public org.openhab.binding.zwave.internal.ZWaveHandlerFactory()
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : getting bind: setSerialPortManager
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : Locating method setSerialPortManager in class org.openhab.binding.zwave.internal.ZWaveHandlerFactory
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : doFindMethod: Looking for method org.openhab.binding.zwave.internal.ZWaveHandlerFactory.setSerialPortManager
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : Declared Method org.openhab.binding.zwave.internal.ZWaveHandlerFactory.setSerialPortManager([interface org.osgi.framework.ServiceReference]) not found
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : Declared Method org.openhab.binding.zwave.internal.ZWaveHandlerFactory.setSerialPortManager([interface org.osgi.service.component.ComponentServiceObjects]) not found
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : getReferenceClass: Looking for interface class org.openhab.core.io.transport.serial.SerialPortManager through loader of org.openhab.binding.zwave.internal.ZWaveHandlerFactory
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : getParameterClass: Found class org.openhab.core.io.transport.serial.SerialPortManager
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : doFindMethod: No method taking ServiceReference found, checking method taking org.openhab.core.io.transport.serial.SerialPortManager
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : doFindMethod: Found Method protected void org.openhab.binding.zwave.internal.ZWaveHandlerFactory.setSerialPortManager(org.openhab.core.io.transport.serial.SerialPortManager)
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : Found bind method: protected void org.openhab.binding.zwave.internal.ZWaveHandlerFactory.setSerialPortManager(org.openhab.core.io.transport.serial.SerialPortManager)
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : This thread collected dependencies
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : getService (single component manager) dependencies collected.
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : Querying state satisfied
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : For dependency SerialPortManager, optional: false; to bind: [[RefPair: ref: [{org.openhab.core.io.transport.serial.SerialPortManager}={service.id=511, service.bundleid=277, service.scope=bundle, component.name=org.openhab.core.io.transport.serial.internal.SerialPortManagerImpl, component.id=303}] service: [org.openhab.core.io.transport.serial.internal.SerialPortManagerImpl@1332dc3c]]]
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : invoking bind: setSerialPortManager: parameters [org.openhab.core.io.transport.serial.internal.SerialPortManagerImpl]
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : invoked bind: setSerialPortManager
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : getting activate: activate
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : Locating method activate in class org.openhab.binding.zwave.internal.ZWaveHandlerFactory
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : Declared Method org.openhab.binding.zwave.internal.ZWaveHandlerFactory.activate([interface org.osgi.service.component.ComponentContext]) not found
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : Locating method activate in class org.openhab.core.thing.binding.BaseThingHandlerFactory
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : Found activate method: protected void org.openhab.core.thing.binding.BaseThingHandlerFactory.activate(org.osgi.service.component.ComponentContext)
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : invoking activate: activate: parameters [org.apache.felix.scr.impl.manager.ComponentContextImpl]
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : invoked activate: activate
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : Set implementation object for component
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : Changed state from satisfied to active
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.1.0 (271)[org....ZWaveHandlerFactory(295)] : dm SerialPortManager tracking 1 SingleStatic added {org.openhab.core.io.transport.serial.SerialPortManager}={service.id=511, service.bundleid=277, service.scope=bundle, component.name=org.openhab.core.io.transport.serial.internal.SerialPortManagerImpl, component.id=303} (exit)
[DEBUG] [wave.discovery.ZWaveDiscoveryService] - Creating ZWave discovery service for zwave:serial_zstick:635489e3 with scan time of 60
[DEBUG] [wave.discovery.ZWaveDiscoveryService] - ZWave discovery: Active zwave:serial_zstick:635489e3
[INFO ] [zwave.handler.ZWaveControllerHandler] - Attempting to add listener when controller is null
[DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Initializing ZWave serial controller.
[DEBUG] [zwave.handler.ZWaveControllerHandler] - Initializing ZWave Controller zwave:serial_zstick:635489e3.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:635489e3:node11.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:635489e3:node15.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:635489e3:node17.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:635489e3:node13.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:635489e3:node3.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:635489e3:node10.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:635489e3:node4.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:635489e3:node31.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:635489e3:node7.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:635489e3:node2.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:635489e3:node9.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:635489e3:node6.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:635489e3:node33.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:635489e3:node24.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:635489e3:node25.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:635489e3:node32.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:635489e3:node23.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:635489e3:node22.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:635489e3:node28.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:635489e3:node30.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:635489e3:node29.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:635489e3:node27.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:635489e3:node26.
[DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port '/dev/ttyzwave'
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - No bridgeUID found in getConfigDescription thing:zwave:serial_zstick:635489e3
I just tried changing to controller configuration from the symlinked device /dev/ttyzwave to /dev/ttyACM1 to no avail:
2021-08-17 19:52:05.239 [DEBUG] [g.zwave.internal.ZWaveConfigProvider] - No bridgeUID found in getConfigDescription thing:zwave:serial_zstick:635489e3
2021-08-17 19:52:10.070 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port '/dev/ttyACM1'
2021-08-17 19:52:15.286 [DEBUG] [g.zwave.internal.ZWaveConfigProvider] - No bridgeUID found in getConfigDescription thing:zwave:serial_zstick:635489e3
The bridge and all devices are still offline.
Accessing /dev/ttyzwave with openzwave / MinOZW and the openhab user works fine (sudo -u openhab MinOZW /dev/ttyzwave), I can see the nodes talking to the controller. So the issue must be somewhere within OpenHAB.
Oh damn, I think I have the same issue as the guys and gals in this thread: [SOLVED] OH3: zwave binding Z-Wave Serial Controller Aeotec Z-Stick Gen5 remains offline - #10 by HaKuNa
Employing the ser2net workaround worked for me. Maybe the cause really is this nrjavaserial issue here: Serial ports getting blocked after some re-connecting · Issue #1842 · openhab/openhab-core · GitHub which should be fixed in nrjavaserial v5.3.0. So there is hope that it works when this version makes it into OpenHAB.
I’ve updated today Debian to bullseye without a flaw for my openhab (stable) serial and zwave bridge.
