I updated yesterday to the latest OH2 snapshot via apt, and I am running the latest Z-wave binding from the top of this thread. The binding was in use successfully prior to the OH2 upgrade.
Now, with this latest release, I can’t control any Z-Wave items. When I try, I get log errors like this:
2017-04-19 12:00:14.325 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Command received zwave:device:159387b2735:node4:switch_dimmer --> ON
2017-04-19 12:00:14.325 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: No converter set for command zwave:device:159387b2735:node4:switch_dimmer type OnOffType
2017-04-19 12:00:16.618 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Command received zwave:device:159387b2735:node4:switch_dimmer --> INCREASE
2017-04-19 12:00:16.618 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Command for unknown channel zwave:device:159387b2735:node4:switch_dimmer with IncreaseDecreaseType
2017-04-19 12:00:17.091 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Command received zwave:device:159387b2735:node4:switch_dimmer --> ON
2017-04-19 12:00:17.091 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: No converter set for command zwave:device:159387b2735:node4:switch_dimmer type OnOffType
2017-04-19 12:00:17.274 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Command received zwave:device:159387b2735:node4:switch_dimmer --> ON
2017-04-19 12:00:17.274 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: No converter set for command zwave:device:159387b2735:node4:switch_dimmer type OnOffType
2017-04-19 12:00:17.396 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Command received zwave:device:159387b2735:node4:switch_dimmer --> INCREASE
2017-04-19 12:00:17.396 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Command for unknown channel zwave:device:159387b2735:node4:switch_dimmer with IncreaseDecreaseType
2017-04-19 12:00:17.565 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Command received zwave:device:159387b2735:node4:switch_dimmer --> INCREASE
2017-04-19 12:00:17.566 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Command for unknown channel zwave:device:159387b2735:node4:switch_dimmer with IncreaseDecreaseType
2017-04-19 12:00:17.865 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Command received zwave:device:159387b2735:node4:switch_dimmer --> INCREASE
2017-04-19 12:00:17.866 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Command for unknown channel zwave:device:159387b2735:node4:switch_dimmer with IncreaseDecreaseType
Unlinking and re-linking the Items to the channel doesn’t resolve this issue, and neither does reinitializing the node. Any thoughts?
