Looking at my log I see a lot of timeouts. All from my aeotec multisensor 6. I have it on usb power and it is configured to send an update every 30 seconds. It is doing that bit fine, but at the same time it is logging a lot of these errors:
2017-05-19 15:37:36.187 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 11: Timeout while sending message. Requeueing - 2 attempts left!
2017-05-19 15:37:36.187 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 11: Node is DEAD. Dropping message.
I enabled debugging but it’s not helping me understand this problem. Neither did googling the problem. Most suggestions are about it being battery powered or downgrading certain linux libraries. I’m running Windows and it’s usb powered.
2017-05-19 15:46:16.306 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 11: Timeout while sending message. Requeueing - 2 attempts left!
2017-05-19 15:46:16.306 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 11: Got an error while sending data. Resending message.
2017-05-19 15:46:16.306 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 324. Queue={}
2017-05-19 15:46:16.306 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 323
2017-05-19 15:46:16.306 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0C 00 13 0B 05 71 04 00 07 00 25 85 3C
2017-05-19 15:46:16.306 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 11: Sending REQUEST Message = 01 0C 00 13 0B 05 71 04 00 07 00 25 85 3C
2017-05-19 15:46:16.314 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2017-05-19 15:46:16.315 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-05-19 15:46:16.315 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
2017-05-19 15:46:16.316 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
2017-05-19 15:46:16.316 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
2017-05-19 15:46:16.316 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: Sent Data successfully placed on stack.
2017-05-19 15:46:16.366 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 16 EA
2017-05-19 15:46:16.367 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 11: Sending ABORT Message = 01 03 00 16 EA
2017-05-19 15:46:16.367 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 16 EA
2017-05-19 15:46:16.367 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Port closed sending REQUEST Message = 01 03 00 16 EA
2017-05-19 15:46:16.367 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 11: Timeout while sending message. Requeueing - 2 attempts left!
2017-05-19 15:46:16.367 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 11: Node is DEAD. Dropping message.
2017-05-19 15:46:16.367 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 112004
2017-05-19 15:46:16.367 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 05 00 47 06 01 BA
2017-05-19 15:46:16.367 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Port closed sending REQUEST Message = 01 05 00 47 06 01 BA
2017-05-19 15:46:16.459 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 85 00 00 0F 61
2017-05-19 15:46:16.459 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-05-19 15:46:16.459 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 85 00 00 0F 00 00 6F
2017-05-19 15:46:16.459 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 85 00 00 0F 00 00 6F
2017-05-19 15:46:16.459 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=85 00 00 0F
2017-05-19 15:46:16.459 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: SendData Request. CallBack ID = 133, Status = Transmission complete and ACK received(0)
2017-05-19 15:46:16.460 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 11: Starting initialisation from DONE
2017-05-19 15:46:16.460 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@756dd8ac already registered
2017-05-19 15:46:16.460 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=11, callback=133, payload=0B 05 71 04 00 07 00
2017-05-19 15:46:16.460 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=85 00 00 0F
2017-05-19 15:46:16.460 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=133, expected=ApplicationCommandHandler, cancelled=false MISMATCH
2017-05-19 15:46:19.313 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Polling...
2017-05-19 15:46:19.313 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Polling zwave:device:326f5f4b:node11:sensor_binary
2017-05-19 15:46:19.313 [DEBUG] [converter.ZWaveBinarySensorConverter] - NODE 11: Generating poll message for SENSOR_BINARY, endpoint 0
2017-05-19 15:46:19.313 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 11: Creating new message for application command SENSOR_BINARY_GET
2017-05-19 15:46:19.313 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Polling zwave:device:326f5f4b:node11:sensor_relhumidity
2017-05-19 15:46:19.313 [DEBUG] [erter.ZWaveMultiLevelSensorConverter] - NODE 11: Generating poll message for SENSOR_MULTILEVEL, endpoint 0
2017-05-19 15:46:19.313 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 11: Creating new message for command SENSOR_MULTI_LEVEL_GET
2017-05-19 15:46:19.313 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Polling zwave:device:326f5f4b:node11:sensor_temperature
2017-05-19 15:46:19.313 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Polling zwave:device:326f5f4b:node11:sensor_luminance
2017-05-19 15:46:19.313 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Polling zwave:device:326f5f4b:node11:sensor_ultraviolet
2017-05-19 15:46:19.314 [DEBUG] [erter.ZWaveMultiLevelSensorConverter] - NODE 11: Generating poll message for SENSOR_MULTILEVEL, endpoint 0
2017-05-19 15:46:19.314 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 11: Creating new message for command SENSOR_MULTI_LEVEL_GET
2017-05-19 15:46:19.314 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Polling zwave:device:326f5f4b:node11:alarm_burglar
2017-05-19 15:46:19.314 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 11: Generating poll message for ALARM, endpoint 0, alarm BURGLAR, event null
2017-05-19 15:46:19.314 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 11: Creating new message for application command NOTIFICATION_GET V3
2017-05-19 15:46:19.314 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Polling zwave:device:326f5f4b:node11:battery-level
2017-05-19 15:46:19.314 [DEBUG] [rnal.converter.ZWaveBatteryConverter] - NODE 11: Generating poll message for BATTERY endpoint 0
2017-05-19 15:46:19.314 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 11: Creating new message for application command BATTERY_GET
2017-05-19 15:46:19.314 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 324. Queue={}
2017-05-19 15:46:19.314 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 325. Queue={}
2017-05-19 15:46:19.314 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 326. Queue={}
2017-05-19 15:46:19.314 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 327. Queue={}
2017-05-19 15:46:19.314 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 328. Queue={}
2017-05-19 15:46:19.314 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 329. Queue={}
2017-05-19 15:46:19.314 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 330. Queue={}
2017-05-19 15:46:21.307 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 11: Timeout while sending message. Requeueing - 1 attempts left!
2017-05-19 15:46:21.307 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 11: Got an error while sending data. Resending message.
2017-05-19 15:46:21.307 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 331. Queue={}
2017-05-19 15:46:21.307 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 330
2017-05-19 15:46:21.307 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0C 00 13 0B 05 71 04 00 07 00 25 8D 34
2017-05-19 15:46:21.308 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 11: Sending REQUEST Message = 01 0C 00 13 0B 05 71 04 00 07 00 25 8D 34
2017-05-19 15:46:21.316 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2017-05-19 15:46:21.317 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-05-19 15:46:21.317 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
2017-05-19 15:46:21.317 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
2017-05-19 15:46:21.317 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
2017-05-19 15:46:21.317 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: Sent Data successfully placed on stack.
2017-05-19 15:46:21.369 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 2 attempts left!
2017-05-19 15:46:21.369 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 112005. Queue={}
2017-05-19 15:46:21.369 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 112004
2017-05-19 15:46:21.369 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 05 00 47 06 01 BA
2017-05-19 15:46:21.369 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Port closed sending REQUEST Message = 01 05 00 47 06 01 BA
2017-05-19 15:46:21.461 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 8D 00 00 0F 69
2017-05-19 15:46:21.461 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-05-19 15:46:21.462 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 8D 00 00 0F 00 00 67
2017-05-19 15:46:21.462 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 8D 00 00 0F 00 00 67
2017-05-19 15:46:21.462 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=8D 00 00 0F
2017-05-19 15:46:21.462 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: SendData Request. CallBack ID = 141, Status = Transmission complete and ACK received(0)
2017-05-19 15:46:21.462 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 11: Starting initialisation from DONE
2017-05-19 15:46:21.462 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@756dd8ac already registered
2017-05-19 15:46:21.462 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=11, callback=141, payload=0B 05 71 04 00 07 00
2017-05-19 15:46:21.462 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=8D 00 00 0F
2017-05-19 15:46:21.462 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=141, expected=ApplicationCommandHandler, cancelled=false MISMATCH
2017-05-19 15:46:26.311 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 11: Timeout while sending message. Requeueing - 0 attempts left!
2017-05-19 15:46:26.311 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 11: Got an error while sending data. Resending message.
2017-05-19 15:46:26.311 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 331. Queue={}
2017-05-19 15:46:26.311 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 330
2017-05-19 15:46:26.311 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0C 00 13 0B 05 71 04 00 07 00 25 8E 37
2017-05-19 15:46:26.311 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 11: Sending REQUEST Message = 01 0C 00 13 0B 05 71 04 00 07 00 25 8E 37
2017-05-19 15:46:26.319 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2017-05-19 15:46:26.320 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-05-19 15:46:26.320 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
2017-05-19 15:46:26.320 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
2017-05-19 15:46:26.320 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
2017-05-19 15:46:26.321 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: Sent Data successfully placed on stack.
2017-05-19 15:46:26.371 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 1 attempts left!
2017-05-19 15:46:26.371 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 112005. Queue={}
2017-05-19 15:46:26.371 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 112004
2017-05-19 15:46:26.371 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 05 00 47 06 01 BA
2017-05-19 15:46:26.371 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Port closed sending REQUEST Message = 01 05 00 47 06 01 BA
2017-05-19 15:46:26.464 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 8E 00 00 0F 6A
2017-05-19 15:46:26.465 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-05-19 15:46:26.465 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 8E 00 00 0F 00 00 64
2017-05-19 15:46:26.465 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 8E 00 00 0F 00 00 64
2017-05-19 15:46:26.465 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=8E 00 00 0F
Edit:
I removed the device for now and that has resolved my problem, I don’t have any delay any more between sending a command and it actually happening.
