my Z-stick AEOTEC Gen5 stays offline.
I’ve tried everything: factory reset; rights granted; searched for /dev/ttyAMA0 and found it.
But none of the solutions I’ve searched for turn out to work.
The Z-stick works normally (it links the divices) and has worked well in the past.
See below the info from the log viewer.
There are no errors. Only the message that the Z-stick is off-line.
Be desperate for the moment. Thanks in advance for your help.
2020-12-06 17:15:14.447 [hingStatusInfoChangedEvent] - ‘zwave:serial_zstick:3d778252’ changed from UNINITIALIZED to INITIALIZING
2020-12-06 17:15:14.613 [me.event.ThingUpdatedEvent] - Thing ‘zwave:serial_zstick:3d778252’ has been updated.
2020-12-06 17:15:14.621 [hingStatusInfoChangedEvent] - ‘zwave:serial_zstick:3d778252’ changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
The stick never makes it ONLINE. You need to provide more information though.
What server hardware?
What openHAB version?
Are you sure that is the proper device?
What is the output of sudo dmesg | grep tty ? That shows what serial devices the OS knows about.
Thank you very much for your help
I tried the other USB port, the port result is the same see below:
2020-12-06 18:34:18.476 [hingStatusInfoChangedEvent] - ‘zwave:serial_zstick:aba04922’ changed from UNINITIALIZED to INITIALIZING
2020-12-06 18:34:18.511 [me.event.ThingUpdatedEvent] - Thing ‘zwave:serial_zstick:aba04922’ has been updated.
2020-12-06 18:34:18.513 [hingStatusInfoChangedEvent] - ‘zwave:serial_zstick:aba04922’ changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
the hub has no power supply, there is also a keyboard connected to it and that works well. i’ve tried without a hub before, but then the Z-Stick dropped out regularly. After using the usb-2 hub I had no problems anymore.
I used a powerd hub again (which I just wanted to get rid of because of the power wires) and now the usb in grep tty is recognized as ttyACM0 and also in paper UI I can select it. Everything works normally again.
Thanks for your input, double check is always a good thing, sometimes there must be a trigger
A former manager of mine quite often used the advice “Double Check Your Work”.
Consciously following that has saved me from some potential disasters. I also realized I forgot that recently in my rush and need to figure out how to fix an issue that could have been avoided.
@Bruce_Osborne, you are right “dialout” was an assumption, but in most distributions it is the right one. To be precise I should have phrased it:
Is the user that runs OH a member of the group that the device file representing the Z-Wave stick (/dev/tty???) belongs to?
Just added that for the benefit of readers that may stumble upon this thread in the future and need more precise information than I’ve given previously
