I received the following response from iBlinds. I’m not sure if this will help someone update the database correctly so I’m posting for informational purposes.
" Hi,
iblinds is a Z-Wave Plus Certified Device - https://products.z-wavealliance.org/products/2486
Z-Wave Product Catalog - Window Blind Controller
An intelligent Z-Wave blind motor that installs out of sight in existing Horizontal (2" and 2 1/2" slatted-style) blind headrails. Use iBlinds to tilt the slats open, closed or use the value slider for precise positioning of the slat tilt angle.
and OpenHab supports Z-Wave devices so I am certain iblinds will work. I believe the issue is since iblinds is a brand new product no one has created an entry for it in the OpenHab database. Sorry, we don’t have OpenHab so we have been unable to create an entry for everyone.
Please try checking the OpenHab community or OpenHab support for assistance.
Here’s some information you may need for the OpenHab database.
Supported Command Classes - cc:5E,85,59,86,72,5A,73,26,25,80,70
Command Class Association Group Info V2
Command Class Association V2
Command Class Basic V2
Command Class Battery
Command Class Device Reset Locally
Command Class Manufacturer Specific V2
Command Class Powerlevel
Command Class Switch Binary
Command Class Switch Multilevel V4
Command Class Version V2
Command Class Z-Wave+ Info V2
Product Details
Z-Wave Specific Device Type: Window Covering - Endpoint and Position Aware, CLASS_B_MOTOR_CONTROL
Z-Wave Generic Device Type: Multilevel Switch
Z-Wave Role Type: Listening Sleeping Slave
Manufacturer ID: 0287
Product Type ID: 0x0003
Product ID: 0x000D
If you or OpenHab supports needs any additional information, please let us know.
Thanks,
Eric"
