edit: ![]()
Solution: delete thing, rescan z-wave and re-add thing. It uses the same node number, and nothing has to be updated. The switch now works as intended.
Original message:
I think I have an interesting version of the integer/float problem with updating to OH3.
I have a lot of Inovelli z-wave switches.
Since the migration, I have noticed that many of the red series switches are not initializing successfully. These switches are able to initiate scenes based on button pushes, as well as display patterns/colors to their LED.
The information for the light/blinking pattern are coded in a byte in channel 8.
This particular switch in question is an LZW30-SN Red Series On/Off switch, and all of the LZW30-SNs are affected. Interestingly, the LZW31-SN Red Dimmer switches are not, and the plain LZW30’s are also unaffected.
For the LZW30-SN’s:
The error is:
Status:
UNINITIALIZED
HANDLER_CONFIGURATION_PENDING
{config_8_4_000000FF=The value 89.0 does not match allowed parameter options. Allowed options are: [ParameterOption [value=“0”, label=“Red”], ParameterOption [value=“21”, label=“Orange”], ParameterOption [value=“42”, label=“Yellow”], ParameterOption [value=“85”, label=“Green”], ParameterOption [value=“127”, label=“Cyan”], ParameterOption [value=“170”, label=“Blue”], ParameterOption [value=“212”, label=“Violet”], ParameterOption [value=“234”, label=“Pink”], ParameterOption [value=“255”, label=“White”]]}
From @chris Jackson’s z-wave database, this device has definitions for channel 8:
8 LED Strip Effect LED Strip Effect 8 LED Strip Effect (Color) LED Strip Effect (Color) 8 LED Strip Effect (Brightness) LED Strip Effect (Brightness) 8 LED Strip Effect (Duration) LED Strip Effect (Duration) 8 LED Strip Effect (Effect) LED Strip Effect (Effect)
I thought I used to have the XML files for this device, but cannot find them at this time, and my old login to chris’ old website don’t work for the current one, …
This is probably all looking at too great a depth for this. I assume this was because of whatever color I chose to assign the LED previously, and the way that value was persisted.
I believe the problem is that the color value appears to range from 0 to 255 as integers, and the (?historical) value of 89.0 isn’t compatible with this. I believe this is stored in a byte, however, making finding the value in influxdb to convert difficult to find.
Is there a best way to clear this?
Delete the node? Exclude/re-include?
It seems odd that it is affecting only the LZW39-SN, not the (very similar) LZW31-SN
Thanks!
Edit:logs
2022-11-05 22:29:32.105 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:a204e4d4:node76' changed from UNINITIALIZED (HANDLER_CONFIGURATION_PENDING): {config_8_4_000000FF=The value 197.0 does not match allowed parameter options. Allowed options are: [ParameterOption [value="0", label="Red"], ParameterOption [value="21", label="Orange"], ParameterOption [value="42", label="Yellow"], ParameterOption [value="85", label="Green"], ParameterOption [value="127", label="Cyan"], ParameterOption [value="170", label="Blue"], ParameterOption [value="212", label="Violet"], ParameterOption [value="234", label="Pink"], ParameterOption [value="255", label="White"]]} to UNINITIALIZED
2022-11-05 22:29:32.128 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:a204e4d4:node76' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
2022-11-05 22:29:33.478 [ERROR] [st.core.internal.thing.ThingResource] - Exception during HTTP PUT request for update config at 'things/zwave:device:a204e4d4:node76/config'
java.lang.IllegalStateException: Thing with UID zwave:device:a204e4d4:node76 has no handler attached.
at org.openhab.core.thing.internal.ThingRegistryImpl.updateConfiguration(ThingRegistryImpl.java:96) ~[?:?]
at org.openhab.core.io.rest.core.internal.thing.ThingResource.updateConfiguration(ThingResource.java:498) ~[?:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.apache.cxf.service.invoker.AbstractInvoker.performInvocation(AbstractInvoker.java:179) ~[bundleFile:3.4.5]
at org.apache.cxf.service.invoker.AbstractInvoker.invoke(AbstractInvoker.java:96) ~[bundleFile:3.4.5]
at org.apache.cxf.jaxrs.JAXRSInvoker.invoke(JAXRSInvoker.java:201) ~[bundleFile:3.4.5]
at org.apache.cxf.jaxrs.JAXRSInvoker.invoke(JAXRSInvoker.java:104) ~[bundleFile:3.4.5]
at org.apache.cxf.interceptor.ServiceInvokerInterceptor$1.run(ServiceInvokerInterceptor.java:59) ~[bundleFile:3.4.5]
at org.apache.cxf.interceptor.ServiceInvokerInterceptor.handleMessage(ServiceInvokerInterceptor.java:96) ~[bundleFile:3.4.5]
at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:308) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.ChainInitiationObserver.onMessage(ChainInitiationObserver.java:121) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.http.AbstractHTTPDestination.invoke(AbstractHTTPDestination.java:265) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.ServletController.invokeDestination(ServletController.java:234) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:208) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:160) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.CXFNonSpringServlet.invoke(CXFNonSpringServlet.java:225) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.handleRequest(AbstractHTTPServlet.java:298) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.doPut(AbstractHTTPServlet.java:234) ~[bundleFile:3.4.5]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:710) ~[bundleFile:3.1.0]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.service(AbstractHTTPServlet.java:273) ~[bundleFile:3.4.5]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:799) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:550) ~[bundleFile:9.4.46.v20220331]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:74) ~[bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:600) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1440) ~[bundleFile:9.4.46.v20220331]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:294) ~[bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:501) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1355) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) ~[bundleFile:9.4.46.v20220331]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:90) ~[bundleFile:?]
at org.eclipse.jetty.server.Server.handle(Server.java:516) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:487) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:732) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:479) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:409) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034) [bundleFile:9.4.46.v20220331]
edit: ![]()
Delete thing, rescan z-wave and re-add thing. It uses the same node number, and nothing has to be updated. The switch now works as intended.
