I am experiencing issues with OH 2.4 stable and the z-wave binding.
The issues I am having is fundamentally about the z-wave network itself. It seems that associations, like like lifeline association between the device and controller, is lost between reboots. Once in a while.
And, lifeline associations is sometimes set to node_1_1. While I do enjoy home automation I do not enjoy resettings the basic associations on my network.
The other issue I am seeing is that devices are being lost from the network and marked as offline. It is like a disease and it spreads across the network.
I think I have somewhere north of 60 devices, and my home automation time is now basically spent resetting associations and re-including offline devices. Is anyone else experiencing similar issues?
Hi Fredrick, what binding version are you running of the zwave? There were changes done by @chris to fix the association, that you, and many others including myself experienced. Since those changes, zwave has been very solid for me.
I would recommend updating to the 2.5 snapshot binding release which works just fine on 2.4 stable (same as what im running)
Meanwhile I managed to update bindings using the console. which works fine. But every now and then the “old” bindings reappear and everything gets mixed up. I used the console/karaf to uninstall the “old” 2.4.0 (stable) bindings. Any trick on how to get rid of these bindings eternally when using an updated version?
