Issue of the topic: Smart home system runs perfectly for some weeks. Then from one day without any changes, commands are not anymore processed by all devices (plugs, roller shutters). No error messages in the logs. Events by battery devices (e.g. window contacts, motion sensors) are still received.
Please post configurations (if applicable):
Configuration of one of the affected devices (Fibaro Wall Plug, Fibaro Roller Shutter 2)
To me it looks like messages are jammed up, especially the secure nodes (over 500+ in the queue). Why are there so many (11,12,13,15,17,18,24,25,26)? and the non-secure queue is over 150+ waiting. Lastly it seems like the last heal is in various stages of completion for many of the nodes. As noted above you could try to restart the zwave binding bundle:stop xxx bundle:start xxx in the console and disable the heal for a few days to see if anything clears up. Lastly are all the nodes in the log functional?
Thanks for the hints. I have indeed 26 z-Wave nodes in my network.
After Restarting OpenHAB it is working again.
I experienced similar behavior in the past that commands were not processed anymore after OpenHAB was running for some weeks. The question is: what could be the reasons why messages are queuing up without being processed? Any hints?
Hard to say. From the log above, the zstick never sends a Transmit and just continues to queue messages. Possibly a log file after a restart (or while things are still working) might show how it gets overwhelmed in the first place. I don’t have any devices added securely, but from the documentation secure devices contribute to traffic and might be a factor.
you are swamping the network. Check all your nodes and make sure they are not reporting at an excessively high rate. There is no point reporting temperature or humidity every 30 seconds and such. Like Bob said, watch the log before things go south. Watch for ‘chatty’ nodes.
This as well. I forget what Chris said but it is like 5 times the traffic compared to non-secure nodes. Don’t securely include anything that doesn’t need security. So locks and stuff only.
