I am trying to add a new Z-Wave device to Chris’ database.
The device is a simple Door/Window switch from Monoprice Model HKZW-DWS01.
I have the battery level and tamper alarm working, I just have something misconfigured with the binary sensor.
I uploaded the XML created by the system, so there wasn’t any manual setup done.
Can someone take a look and provide any feedback?
Thanks in advance.
When I trigger the switch this is what I am seeing in the log:
2017-08-25 13:02:39.731 [vent.ItemStateChangedEvent] - zwave_serial_zstick_f7dddbf0_serial_ack changed from 209 to 210
2017-08-25 13:02:39.745 [vent.ItemStateChangedEvent] - zwave_serial_zstick_f7dddbf0_serial_sof changed from 476 to 477
Example of the XML uploaded to the database:
<?xml version="1.0" encoding="UTF-8"?>
<thing:thing-descriptions bindingId="zwave"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:thing="http://eclipse.org/smarthome/schemas/thing-description/v1.0.0"
xsi:schemaLocation="http://eclipse.org/smarthome/schemas/thing-description/v1.0.0
http://eclipse.org/smarthome/schemas/thing-description/v1.0.0">
<thing-type id="hank_24259_00_000" listed="false">
<label>24259 MONOPRICE Door and Window Sensor P/N 24259</label>
<description>MONOPRICE Door and Window Sensor P/N 24259</description>
<!-- CHANNEL DEFINITIONS -->
<channels>
<channel id="sensor_binary" typeId="sensor_binary">
<label>Binary Sensor</label>
<properties>
<property name="binding:*:OnOffType">SENSOR_BINARY</property>
</properties>
</channel>
<channel id="alarm_access" typeId="alarm_access">
<label>Alarm (access)</label>
<properties>
<property name="binding:*:OnOffType">ALARM;type=ACCESS_CONTROL</property>
</properties>
</channel>
<channel id="alarm_burglar" typeId="alarm_burglar">
<label>Alarm (burglar)</label>
<properties>
<property name="binding:*:OnOffType">ALARM;type=BURGLAR</property>
</properties>
</channel>
<channel id="battery-level" typeId="system.battery-level">
<properties>
<property name="binding:*:PercentType">BATTERY</property>
</properties>
</channel>
</channels>
<!-- DEVICE PROPERTY DEFINITIONS -->
<properties>
<property name="vendor">Hank</property>
<property name="modelId">24259</property>
<property name="manufacturerId">0208</property>
<property name="manufacturerRef">0201:0008</property>
<property name="dbReference">663</property>
</properties>
<!-- CONFIGURATION DESCRIPTIONS -->
<config-description>
<!-- ASSOCIATION DEFINITIONS -->
<parameter-group name="association">
<context>link</context>
<label>Association Groups</label>
</parameter-group>
<parameter name="group_1" type="text" groupName="association" multiple="true">
<label>1: Group 1</label>
<description><![CDATA[
Association Group 1<br /><h1>Overview</h1> <ul><li> <p>Group 1 reports the status of the Door/Window Sensor, the battery level, and the tamper button status. </p> </li> </ul>
]]></description>
<multipleLimit>5</multipleLimit>
</parameter>
<parameter name="group_2" type="text" groupName="association" multiple="true">
<label>2: Group 2</label>
Association Group 2<br /><h1>Overview</h1> <ul><li> <p>Group 2 is assigned to the Door/Window Sensor BASIC SET command. </p> </li> </ul>
]]></description>
</parameter>
</config-description>
</thing-type>
</thing:thing-descriptions>
