I’m running OH2 on a Windows PC and if I reboot the box with the Z-Wave Controller plugged into the USB Port I get an error in Karaf “Error 0x5 at src/windows/termios.c(889): Access is denied.” and the logs report that the “Controller is offline”.
If I reboot the PC with the Controller unplugged then plug it in, I’ve no issue.
Device Manager sees the Aeotec Z-Wave Controller as on-line just fine regardless of how I boot
If I boot with the Z-Wave controller in and then unplug, replug, then run OH2 I still get the error. The only way not to get the error is to boot without it plugged in.
It’s almost like something else is locking/grabbing the Z-Wave controller on boot (COM6)
Thanks @Wolfgang_S It does not look like any other service is grabbing the Port. Process Explorer shows that java.exe is using “usbser” (the Process Handle I’ve got for the Aeotec Z-Wave stick) when all is working.
If I boot with the Z-Wave stick in, Process Explorer is reporting there is NO matching items using “usbser”
