Z-Wave & event log = too much information
Is there a way to prevents logging events relating to “serial_sof” ? My event log is constantly updated with lines such as:
[vent.ItemStateChangedEvent] - zwave_serial_zstick_0abcsefgh_serial_sof changed from XXXX to YYYY
Everything works perfectly but I don’t have any use for these messages that are logged very rapidly and constantly and they are annoying when I’m trying to watch for specific messages when I make changes to sitemaps or rules.
If you delete the item, you won’t have ItemStateChangedEvents.
Thank you, that did the trick!
I was not aware that the sof and ack channels were just counters. Due to the lack of documentation for the Aeotec Z-Wave USB stick I was under the impression that they were necessary for the correct operation of the binding.
