I’m currently trying to work with the Fibaro FGS-223 Double Switch 2. OH2 is working on openhabian and I have a Z-Stick gen5 from Aeotec. I found the Z-Stick in the Paper UI and added him to the things. After that I found the switch aswell and added him. But when I change to the switch then it’s written that it’s a “Unknown Device”. Also when I try to add a item to switch the FGS-223 there is no reaction.
How can I change, that OH knows the Fibaro Switch?
Some devices need to be included repeatedly. They only send a fragment of their identification meta data with each inclusion process. Try to reapeat the “add things” process several times by putting OH inclusion modes (“Configuration / Things / + / Z-Wave Binding”) and tripple-pressing the “tamper” button at the device. After three may be four repeatations you should be all set.
The tamper button on the device. Bring your device into close proximity of the Aetoc stick befiele inclusion. I haven‘t had good experiences with bringing the stick to the device and using the button on the stick.
