My config:
OH 2.4 stable with z-wave binding 2.4
my item config:
Number COSensor_COvalue { channel="zwave:device:15a7a49f3a6:node82:sensor_co" }
Number COSensor_Temperature { channel="zwave:device:15a7a49f3a6:node82:sensor_temperature" }
Switch COSensor_Alarm { channel="zwave:device:15a7a49f3a6:node82:alarm_co" }
Switch COSensor_binary { channel="zwave:device:15a7a49f3a6:node82:sensor_binary" }
Switch COSensor_alarm { channel="zwave:device:15a7a49f3a6:node82:alarm_general" }
Switch COSensor_TamperAlarm { channel="zwave:device:15a7a49f3a6:node82:alarm_burglar" }
Number COSensor_Battery { channel="zwave:device:15a7a49f3a6:node82:battery-level" }
I get values only for this two items:
COSensor_Battery
all others stayed empty.
Here is a z-wave debug log. I made a manuel alarm check at the device. Due to the manual it should send the current alarm state to the controller. The node is 82. any idea what to do?
2019-02-22 19:20:45.757 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 08 00 04 00 52 02 84 07 20
2019-02-22 19:20:45.762 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=82, callback=0, payload=00 52 02 84 07
2019-02-22 19:20:45.764 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=82, callback=0, payload=00 52 02 84 07
2019-02-22 19:20:45.765 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2019-02-22 19:20:45.767 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Application Command Request (ALIVE:DONE)
2019-02-22 19:20:45.768 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: resetResendCount initComplete=true isDead=false
2019-02-22 19:20:45.770 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: Is awake with 0 messages in the queue
2019-02-22 19:20:45.771 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: Start sleep timer at 1000ms
2019-02-22 19:20:45.772 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 82: Got an event from Z-Wave network: ZWaveNodeStatusEvent
2019-02-22 19:20:45.789 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 82: Node Status event - Node is AWAKE
2019-02-22 19:20:45.790 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Commands processed 1.
2019-02-22 19:20:45.790 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@6afcbf.
2019-02-22 19:20:45.791 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2019-02-22 19:20:45.792 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2019-02-22 19:20:45.792 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-02-22 19:20:45.797 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-02-22 19:20:46.272 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: WakeupTimerTask 0 Messages waiting, state DONE
2019-02-22 19:20:46.772 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: WakeupTimerTask 0 Messages waiting, state DONE
2019-02-22 19:20:46.774 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: No more messages, go back to sleep
2019-02-22 19:20:46.776 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 82: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
2019-02-22 19:20:46.778 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: SECURITY NOT required on COMMAND_CLASS_WAKE_UP
2019-02-22 19:20:46.779 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: Command Class COMMAND_CLASS_WAKE_UP is NOT required to be secured
2019-02-22 19:20:46.781 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@1fe760b
2019-02-22 19:20:46.786 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Bump transaction 16428 priority from Immediate to Immediate
2019-02-22 19:20:46.788 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Adding to device queue
2019-02-22 19:20:46.790 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Added 16428 to queue - size 40
2019-02-22 19:20:46.792 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-02-22 19:20:46.804 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 52 02 84 08 25 75 69
2019-02-22 19:20:46.809 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 82: Sending REQUEST Message = 01 09 00 13 52 02 84 08 25 75 69
2019-02-22 19:20:46.811 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2019-02-22 19:20:46.813 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2019-02-22 19:20:46.813 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 16428: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 117
2019-02-22 19:20:46.815 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2019-02-22 19:20:46.818 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2019-02-22 19:20:46.820 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 16428: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 117
2019-02-22 19:20:46.821 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2019-02-22 19:20:46.821 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2019-02-22 19:20:46.822 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-02-22 19:20:46.824 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-02-22 19:20:46.824 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-02-22 19:20:46.825 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-02-22 19:20:46.826 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 16428: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 117
2019-02-22 19:20:46.827 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2019-02-22 19:20:46.828 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 16428: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 117
2019-02-22 19:20:46.830 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-02-22 19:20:46.831 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 82: sentData successfully placed on stack.
2019-02-22 19:20:46.832 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 16428: Advanced to WAIT_REQUEST
2019-02-22 19:20:46.834 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: TID 16428: Transaction not completed
2019-02-22 19:20:46.835 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-02-22 19:20:46.836 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-02-22 19:20:46.836 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 75 00 00 02 9C
2019-02-22 19:20:46.840 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=117, payload=75 00 00 02
2019-02-22 19:20:46.842 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=117, payload=75 00 00 02
2019-02-22 19:20:46.843 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 16428: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 117
2019-02-22 19:20:46.844 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2019-02-22 19:20:46.845 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 16428: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 117
2019-02-22 19:20:46.847 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 16428: (Callback 117)
2019-02-22 19:20:46.849 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2019-02-22 19:20:46.850 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 16428: callback 117
2019-02-22 19:20:46.851 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=117, payload=75 00 00 02
2019-02-22 19:20:46.853 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 82: SendData Request. CallBack ID = 117, Status = Transmission complete and ACK received(0)
2019-02-22 19:20:46.854 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: resetResendCount initComplete=true isDead=false
2019-02-22 19:20:46.854 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 16428: Transaction COMPLETED
2019-02-22 19:20:46.855 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Response processed after 42ms
2019-02-22 19:20:46.856 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: TID 16428: Transaction completed
2019-02-22 19:20:46.857 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: notifyTransactionResponse TID:16428 DONE
2019-02-22 19:20:46.858 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 82: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2019-02-22 19:20:46.859 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-02-22 19:20:46.859 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 16428: Transaction event listener: DONE: DONE ->
2019-02-22 19:20:46.860 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-02-22 19:20:46.860 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: Went to sleep COMPLETE
2019-02-22 19:20:47.541 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 08 00 04 00 52 02 84 07 20
2019-02-22 19:20:47.544 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=82, callback=0, payload=00 52 02 84 07
2019-02-22 19:20:47.545 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=82, callback=0, payload=00 52 02 84 07
2019-02-22 19:20:47.546 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2019-02-22 19:20:47.547 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Application Command Request (ALIVE:DONE)
2019-02-22 19:20:47.548 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: resetResendCount initComplete=true isDead=false
2019-02-22 19:20:47.549 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: Is awake with 0 messages in the queue
2019-02-22 19:20:47.549 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: Start sleep timer at 1000ms
2019-02-22 19:20:47.550 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 82: Got an event from Z-Wave network: ZWaveNodeStatusEvent
2019-02-22 19:20:47.562 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 82: Node Status event - Node is AWAKE
2019-02-22 19:20:47.563 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Commands processed 1.
2019-02-22 19:20:47.564 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@ee7bd4.
2019-02-22 19:20:47.564 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2019-02-22 19:20:47.565 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2019-02-22 19:20:47.566 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-02-22 19:20:47.567 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-02-22 19:20:48.051 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: WakeupTimerTask 0 Messages waiting, state DONE
2019-02-22 19:20:48.551 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: WakeupTimerTask 0 Messages waiting, state DONE
2019-02-22 19:20:48.553 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: No more messages, go back to sleep
2019-02-22 19:20:48.554 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 82: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
2019-02-22 19:20:48.555 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: SECURITY NOT required on COMMAND_CLASS_WAKE_UP
2019-02-22 19:20:48.556 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: Command Class COMMAND_CLASS_WAKE_UP is NOT required to be secured
2019-02-22 19:20:48.557 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@edae91
2019-02-22 19:20:48.559 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Bump transaction 16429 priority from Immediate to Immediate
2019-02-22 19:20:48.563 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Adding to device queue
2019-02-22 19:20:48.565 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Added 16429 to queue - size 40
2019-02-22 19:20:48.567 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-02-22 19:20:48.571 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 52 02 84 08 25 76 6A
2019-02-22 19:20:48.574 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 82: Sending REQUEST Message = 01 09 00 13 52 02 84 08 25 76 6A
2019-02-22 19:20:48.576 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2019-02-22 19:20:48.577 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 16429: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 118
2019-02-22 19:20:48.577 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2019-02-22 19:20:48.579 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2019-02-22 19:20:48.581 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2019-02-22 19:20:48.582 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 16429: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 118
2019-02-22 19:20:48.583 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2019-02-22 19:20:48.584 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-02-22 19:20:48.585 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2019-02-22 19:20:48.585 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-02-22 19:20:48.587 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-02-22 19:20:48.589 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-02-22 19:20:48.590 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 16429: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 118
2019-02-22 19:20:48.591 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2019-02-22 19:20:48.592 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 16429: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 118
2019-02-22 19:20:48.593 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-02-22 19:20:48.593 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 82: sentData successfully placed on stack.
2019-02-22 19:20:48.594 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 16429: Advanced to WAIT_REQUEST
2019-02-22 19:20:48.594 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: TID 16429: Transaction not completed
2019-02-22 19:20:48.595 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-02-22 19:20:48.595 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-02-22 19:20:48.600 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 76 00 00 03 9E
2019-02-22 19:20:48.602 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=118, payload=76 00 00 03
2019-02-22 19:20:48.603 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=118, payload=76 00 00 03
2019-02-22 19:20:48.603 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 16429: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 118
2019-02-22 19:20:48.604 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2019-02-22 19:20:48.605 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 16429: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 118
2019-02-22 19:20:48.605 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 16429: (Callback 118)
2019-02-22 19:20:48.606 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2019-02-22 19:20:48.606 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 16429: callback 118
2019-02-22 19:20:48.607 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=118, payload=76 00 00 03
2019-02-22 19:20:48.608 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 82: SendData Request. CallBack ID = 118, Status = Transmission complete and ACK received(0)
2019-02-22 19:20:48.609 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: resetResendCount initComplete=true isDead=false
2019-02-22 19:20:48.609 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 16429: Transaction COMPLETED
2019-02-22 19:20:48.610 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Response processed after 33ms
2019-02-22 19:20:48.610 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: TID 16429: Transaction completed
2019-02-22 19:20:48.611 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: notifyTransactionResponse TID:16429 DONE
2019-02-22 19:20:48.612 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 82: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2019-02-22 19:20:48.612 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-02-22 19:20:48.612 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 16429: Transaction event listener: DONE: DONE ->
2019-02-22 19:20:48.613 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-02-22 19:20:48.613 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: Went to sleep COMPLETE
2019-02-22 19:20:49.225 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 08 00 04 00 52 02 84 07 20
2019-02-22 19:20:49.228 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=82, callback=0, payload=00 52 02 84 07
2019-02-22 19:20:49.230 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=82, callback=0, payload=00 52 02 84 07
2019-02-22 19:20:49.231 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2019-02-22 19:20:49.232 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Application Command Request (ALIVE:DONE)
2019-02-22 19:20:49.233 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: resetResendCount initComplete=true isDead=false
2019-02-22 19:20:49.235 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: Is awake with 0 messages in the queue
2019-02-22 19:20:49.236 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: Start sleep timer at 1000ms
2019-02-22 19:20:49.237 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 82: Got an event from Z-Wave network: ZWaveNodeStatusEvent
2019-02-22 19:20:49.254 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 82: Node Status event - Node is AWAKE
2019-02-22 19:20:49.254 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Commands processed 1.
2019-02-22 19:20:49.255 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1bfcf2a.
2019-02-22 19:20:49.256 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2019-02-22 19:20:49.257 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-02-22 19:20:49.257 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-02-22 19:20:49.738 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: WakeupTimerTask 0 Messages waiting, state DONE
2019-02-22 19:20:50.239 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: WakeupTimerTask 0 Messages waiting, state DONE
2019-02-22 19:20:50.241 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: No more messages, go back to sleep
2019-02-22 19:20:50.242 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 82: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
2019-02-22 19:20:50.243 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: SECURITY NOT required on COMMAND_CLASS_WAKE_UP
2019-02-22 19:20:50.243 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: Command Class COMMAND_CLASS_WAKE_UP is NOT required to be secured
2019-02-22 19:20:50.244 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@135eb07
2019-02-22 19:20:50.245 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Bump transaction 16430 priority from Immediate to Immediate
2019-02-22 19:20:50.246 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Adding to device queue
2019-02-22 19:20:50.247 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Added 16430 to queue - size 40
2019-02-22 19:20:50.247 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-02-22 19:20:50.249 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 52 02 84 08 25 77 6B
2019-02-22 19:20:50.251 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 82: Sending REQUEST Message = 01 09 00 13 52 02 84 08 25 77 6B
2019-02-22 19:20:50.252 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2019-02-22 19:20:50.253 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 16430: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 119
2019-02-22 19:20:50.253 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2019-02-22 19:20:50.254 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2019-02-22 19:20:50.255 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2019-02-22 19:20:50.255 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 16430: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 119
2019-02-22 19:20:50.256 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2019-02-22 19:20:50.256 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-02-22 19:20:50.257 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-02-22 19:20:50.260 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2019-02-22 19:20:50.261 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-02-22 19:20:50.262 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-02-22 19:20:50.263 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 16430: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 119
2019-02-22 19:20:50.264 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2019-02-22 19:20:50.265 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 16430: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 119
2019-02-22 19:20:50.266 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-02-22 19:20:50.267 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 82: sentData successfully placed on stack.
2019-02-22 19:20:50.267 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 16430: Advanced to WAIT_REQUEST
2019-02-22 19:20:50.268 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: TID 16430: Transaction not completed
2019-02-22 19:20:50.268 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-02-22 19:20:50.269 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-02-22 19:20:50.277 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 77 00 00 02 9E
2019-02-22 19:20:50.279 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=119, payload=77 00 00 02
2019-02-22 19:20:50.280 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=119, payload=77 00 00 02
2019-02-22 19:20:50.281 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 16430: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 119
2019-02-22 19:20:50.281 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2019-02-22 19:20:50.282 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 16430: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 119
2019-02-22 19:20:50.283 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 16430: (Callback 119)
2019-02-22 19:20:50.284 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2019-02-22 19:20:50.285 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 16430: callback 119
2019-02-22 19:20:50.286 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=119, payload=77 00 00 02
2019-02-22 19:20:50.287 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 82: SendData Request. CallBack ID = 119, Status = Transmission complete and ACK received(0)
2019-02-22 19:20:50.288 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: resetResendCount initComplete=true isDead=false
2019-02-22 19:20:50.288 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 16430: Transaction COMPLETED
2019-02-22 19:20:50.289 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Response processed after 37ms
2019-02-22 19:20:50.290 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: TID 16430: Transaction completed
2019-02-22 19:20:50.291 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: notifyTransactionResponse TID:16430 DONE
2019-02-22 19:20:50.293 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 82: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2019-02-22 19:20:50.294 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-02-22 19:20:50.294 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-02-22 19:20:50.299 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 16430: Transaction event listener: DONE: DONE ->
2019-02-22 19:20:50.300 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: Went to sleep COMPLETE
2019-02-22 19:21:06.766 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0A 00 04 00 4D 04 30 03 00 0C 87
2019-02-22 19:21:06.769 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=77, callback=0, payload=00 4D 04 30 03 00 0C
2019-02-22 19:21:06.770 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=77, callback=0, payload=00 4D 04 30 03 00 0C
2019-02-22 19:21:06.771 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2019-02-22 19:21:06.772 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 77: Application Command Request (ALIVE:DONE)
2019-02-22 19:21:06.773 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 77: resetResendCount initComplete=true isDead=false
2019-02-22 19:21:06.773 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 77: Incoming command class COMMAND_CLASS_SENSOR_BINARY, endpoint 0
2019-02-22 19:21:06.774 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 77: SECURITY NOT required on COMMAND_CLASS_SENSOR_BINARY
2019-02-22 19:21:06.774 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 77: Received COMMAND_CLASS_SENSOR_BINARY V2 SENSOR_BINARY_REPORT
2019-02-22 19:21:06.775 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - Processing Sensor Type 12
2019-02-22 19:21:06.776 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - Sensor Type is MOTION
2019-02-22 19:21:06.776 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 77: Sensor Binary report, type=Motion, value=0
2019-02-22 19:21:06.778 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 77: Got an event from Z-Wave network: ZWaveBinarySensorValueEvent
2019-02-22 19:21:06.778 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 77: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_SENSOR_BINARY, value = 0
2019-02-22 19:21:06.779 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 77: Updating channel state zwave:device:15a7a49f3a6:node77:sensor_binary to OFF [OnOffType]
2019-02-22 19:21:06.780 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 77: Commands processed 1.
2019-02-22 19:21:06.781 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 77: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@56c77c.
2019-02-22 19:21:06.782 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2019-02-22 19:21:06.783 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-02-22 19:21:06.784 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-02-22 19:21:10.377 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 56: Polling...
